Command line 'Synch' copies files and then deletes them
Very strange behaviour here
I've got a script that syncs a remote directory tree to a local one for backup purposes.
One particular sub directory of this tree is full of PHP temp files that change periodically. However, the command line synch behaves erratically when working on this directory.
If my local copy of this remote sub-directory doesnt contain the PHP files, The script runs and retreives all the remote PHP files as expected.
Once complete, if i run the script again (the source files unchanged), the exact same set of PHP files are deleted from the local directory, even though they clearly still exist in the source! This leaves the Local directory almost empty.
Running the script a 3rd time will then copy the PHP files back as expected.
Once again, with the directory now fully synchronised, running the script a 4th time will delete the files again.
Here is the relevant console output when the script runs without the PHP files existing locally, Therefor performing a succesfull synch
Local 'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\Zend\Translate\Adapter' <= Remote '/D/WebPub/WWW/secure/MGRP/LOS/include/Zend/Translate/Adapter
Local 'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\Zend\Uri' <= Remote '/D/WebPub/WWW/secure/MGRP/LOS/include/Zend/Uri'
Local 'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\Zend\Validate\Hostname' <= Remote '/D/WebPub/WWW/secure/MGRP/LOS/include/Zend/Validate/Hostname
Local 'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\Zend\View' <= Remote '/D/WebPub/WWW/secure/MGRP/LOS/include/Zend/View'
Local 'D:\SYNC\WebPub\WWW\secure\MUMI\PrintPricePlatform\Reports\SupplierPresentations' <= Remote '/D/WebPub/WWW/secure/MUMI/PrintPricePlatform/Reports/Sup
Local 'D:\SYNC\WebPub\WWW\secure\MUMI\PrintPricePlatform\Reports\Suppliers' <= Remote '/D/WebPub/WWW/secure/MUMI/PrintPricePlatform/Reports/Suppliers'
Local 'D:\SYNC\WebPub\WWW\secure\XYZv1\Buyer\Upload' <= Remote '/D/WebPub/WWW/secure/XYZv1/Buyer/Upload'
Synchronizing...
Local 'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c' <= Remote '/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c'
%%01^011^01174532%%form.t | 2 KiB | 0.0 KiB/s | binary | 100%
%%08^082^082DDF17%%edit.t | 0 KiB | 52.3 KiB/s | binary | 100%
%%0E^0E4^0E407559%%footer | 0 KiB | 69.0 KiB/s | binary | 100%
%%1F^1F7^1F78B256%%breadc | 1 KiB | 65.9 KiB/s | binary | 100%
%%27^277^277B0EE4%%index. | 5 KiB | 152.2 KiB/s | binary | 100%
%%39^39E^39E915E8%%index. | 3 KiB | 222.8 KiB/s | binary | 100%
%%3E^3E0^3E08FA01%%index. | 0 KiB | 180.4 KiB/s | binary | 100%
%%40^40F^40F2F7E4%%create | 0 KiB | 154.5 KiB/s | binary | 100%
%%47^47C^47C41053%%index. | 2 KiB | 152.1 KiB/s | binary | 100%
%%57^570^570340C1%%index. | 2 KiB | 58.3 KiB/s | binary | 100%
%%60^605^6051ECA6%%index. | 3 KiB | 67.7 KiB/s | binary | 100%
%%65^65C^65C7D16F%%index. | 2 KiB | 73.5 KiB/s | binary | 100%
%%68^689^68964653%%head.t | 2 KiB | 76.9 KiB/s | binary | 100%
%%6A^6A9^6A9E784A%%main.t | 3 KiB | 88.1 KiB/s | binary | 100%
%%6E^6E0^6E038A3B%%index. | 0 KiB | 86.9 KiB/s | binary | 100%
%%80^804^80448BA5%%form.t | 5 KiB | 97.5 KiB/s | binary | 100%
%%89^897^897E1180%%edit.t | 0 KiB | 95.9 KiB/s | binary | 100%
%%8A^8A6^8A6EEBBC%%pagina | 3 KiB | 105.0 KiB/s | binary | 100%
%%8B^8BA^8BA52638%%goodsi | 2 KiB | 108.3 KiB/s | binary | 100%
%%8C^8CA^8CA044D0%%menu.t | 0 KiB | 106.1 KiB/s | binary | 100%
%%8C^8CC^8CCC361F%%order_ | 0 KiB | 104.7 KiB/s | binary | 100%
%%96^965^965C8BF6%%form.t | 3 KiB | 82.7 KiB/s | binary | 100%
%%9C^9CA^9CA4A7D7%%error. | 0 KiB | 81.1 KiB/s | binary | 100%
%%B6^B66^B6692D6D%%index. | 2 KiB | 82.9 KiB/s | binary | 100%
%%BA^BA3^BA328305%%orderc | 0 KiB | 81.6 KiB/s | binary | 100%
%%C8^C80^C8024708%%index. | 1 KiB | 82.6 KiB/s | binary | 100%
%%CB^CB9^CB9D0DA6%%index. | 2 KiB | 87.1 KiB/s | binary | 100%
%%D1^D16^D164EF6B%%create | 0 KiB | 86.2 KiB/s | binary | 100%
%%DC^DC3^DC3DB833%%ordere | 0 KiB | 85.1 KiB/s | binary | 100%
%%F4^F44^F4499389%%index. | 2 KiB | 87.2 KiB/s | binary | 100%
%%F7^F7F^F7F34188%%header | 0 KiB | 86.6 KiB/s | binary | 100%
%%FA^FAA^FAAB3352%%basket | 3 KiB | 91.1 KiB/s | binary | 100%
%%FB^FB6^FB625FE9%%index. | 2 KiB | 92.5 KiB/s | binary | 100%
winscp>
Here's the log output when the script is run again. This time, as syou can see, the script deletes the files at the end of the sync.
Synchronizing...
%%08^082^082DDF17%%edit.t | 0 KiB | 0.0 KiB/s | binary | 100%
%%0E^0E4^0E407559%%footer | 0 KiB | 73.6 KiB/s | binary | 100%
%%1F^1F7^1F78B256%%breadc | 1 KiB | 140.7 KiB/s | binary | 100%
%%27^277^277B0EE4%%index. | 5 KiB | 230.8 KiB/s | binary | 100%
%%39^39E^39E915E8%%index. | 3 KiB | 337.8 KiB/s | binary | 100%
%%3E^3E0^3E08FA01%%index. | 0 KiB | 241.8 KiB/s | binary | 100%
%%40^40F^40F2F7E4%%create | 0 KiB | 259.7 KiB/s | binary | 100%
%%47^47C^47C41053%%index. | 2 KiB | 230.7 KiB/s | binary | 100%
%%57^570^570340C1%%index. | 2 KiB | 265.2 KiB/s | binary | 100%
%%60^605^6051ECA6%%index. | 3 KiB | 107.5 KiB/s | binary | 100%
%%65^65C^65C7D16F%%index. | 2 KiB | 113.3 KiB/s | binary | 100%
%%68^689^68964653%%head.t | 2 KiB | 124.6 KiB/s | binary | 100%
%%6A^6A9^6A9E784A%%main.t | 3 KiB | 132.4 KiB/s | binary | 100%
%%6E^6E0^6E038A3B%%index. | 0 KiB | 136.5 KiB/s | binary | 100%
%%80^804^80448BA5%%form.t | 5 KiB | 150.1 KiB/s | binary | 100%
%%89^897^897E1180%%edit.t | 0 KiB | 153.7 KiB/s | binary | 100%
%%8A^8A6^8A6EEBBC%%pagina | 3 KiB | 157.5 KiB/s | binary | 100%
%%8B^8BA^8BA52638%%goodsi | 2 KiB | 169.3 KiB/s | binary | 100%
%%8C^8CA^8CA044D0%%menu.t | 0 KiB | 163.0 KiB/s | binary | 100%
%%8C^8CC^8CCC361F%%order_ | 0 KiB | 166.7 KiB/s | binary | 100%
%%96^965^965C8BF6%%form.t | 3 KiB | 170.5 KiB/s | binary | 100%
%%9C^9CA^9CA4A7D7%%error. | 0 KiB | 171.4 KiB/s | binary | 100%
%%B6^B66^B6692D6D%%index. | 2 KiB | 104.4 KiB/s | binary | 100%
%%BA^BA3^BA328305%%orderc | 0 KiB | 102.0 KiB/s | binary | 100%
%%C8^C80^C8024708%%index. | 1 KiB | 105.9 KiB/s | binary | 100%
%%CB^CB9^CB9D0DA6%%index. | 2 KiB | 20.6 KiB/s | binary | 100%
%%D1^D16^D164EF6B%%create | 0 KiB | 21.0 KiB/s | binary | 100%
%%DC^DC3^DC3DB833%%ordere | 0 KiB | 21.0 KiB/s | binary | 100%
%%F4^F44^F4499389%%index. | 2 KiB | 22.1 KiB/s | binary | 100%
%%F7^F7F^F7F34188%%header | 0 KiB | 22.3 KiB/s | binary | 100%
%%FA^FAA^FAAB3352%%basket | 3 KiB | 23.5 KiB/s | binary | 100%
%%FB^FB6^FB625FE9%%index. | 2 KiB | 24.2 KiB/s | binary | 100%
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2501^011^01174532%25%25form.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2508^082^082DDF17%25%25edit.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%250E^0E4^0E407559%25%25footer.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%251F^1F7^1F78B256%25%25breadcrumbs.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2527^277^277B0EE4%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2539^39E^39E915E8%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%253E^3E0^3E08FA01%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2540^40F^40F2F7E4%25%25create.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2547^47C^47C41053%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2557^570^570340C1%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2560^605^6051ECA6%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2565^65C^65C7D16F%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2568^689^68964653%25%25head.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%256A^6A9^6A9E784A%25%25main.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%256E^6E0^6E038A3B%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2580^804^80448BA5%25%25form.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2589^897^897E1180%25%25edit.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%258A^8A6^8A6EEBBC%25%25pagination.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%258B^8BA^8BA52638%25%25goodsin.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%258C^8CA^8CA044D0%25%25menu.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%258C^8CC^8CCC361F%25%25order_confirmation.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%2596^965^965C8BF6%25%25form.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%259C^9CA^9CA4A7D7%25%25error.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25B6^B66^B6692D6D%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25BA^BA3^BA328305%25%25orderconfirmation.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25C8^C80^C8024708%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25CB^CB9^CB9D0DA6%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25D1^D16^D164EF6B%25%25create.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25DC^DC3^DC3DB833%25%25orderer_selector.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25F4^F44^F4499389%25%25index.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25F7^F7F^F7F34188%25%25header.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25FA^FAA^FAAB3352%25%25basket.tpl.php' deleted
'D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\%25%25FB^FB6^FB625FE9%25%25index.tpl.php' deleted
winscp>
Can anyone shed any light on this? Why is WinSCP deleteing the local copies as though they no longer exist on the source?
I'm not seeing this problem anywhere else in the direcory tree i'm synching. It only seems to affect the specific php files in this specific directory. But I really dont understand whats going on here.
boxing_surfer
LONDON
The log Files are pretty long - i've tried to chop out most of the superfluous stuff
Run #1: Local DIR unsynched |
Synch works OK |
Files on local are synced with source.|
Missing files are copied locally. |
. 2008-04-16 11:42:13.663 --------------------------------------------------------------------------
. 2008-04-16 11:42:13.663 WinSCP Version 4.1.0 (Build 375) (OS 5.1.2600 Service Pack 2)
. 2008-04-16 11:42:13.663 Login time: 16 April 2008 11:42:13
. 2008-04-16 11:42:13.663 Session name: xxxxxxx@web-02
. 2008-04-16 11:42:13.663 Host name: web-02 (Port: 22)
. 2008-04-16 11:42:13.663 User name: xxxxxxxx (Password: Yes, Key file: No)
. 2008-04-16 11:42:13.663 Tunnel: No
. 2008-04-16 11:42:13.663 Transfer Protocol: SFTP (SCP)
. 2008-04-16 11:42:13.663 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-04-16 11:42:13.663 Proxy: none
. 2008-04-16 11:42:13.663 SSH protocol version: 2; Compression: No
. 2008-04-16 11:42:13.663 Bypass authentication: No
. 2008-04-16 11:42:13.663 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-04-16 11:42:13.663 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2008-04-16 11:42:13.663 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-04-16 11:42:13.663 SFTP Bugs: -,-
. 2008-04-16 11:42:13.663 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-04-16 11:42:13.663 Shell: default, EOL: 1
. 2008-04-16 11:42:13.663 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-04-16 11:42:13.663 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2008-04-16 11:42:13.663 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-04-16 11:42:13.663 Cache directory changes: Yes, Permanent: Yes
. 2008-04-16 11:42:13.663 DST mode: 0
. 2008-04-16 11:42:13.663 Looking up host "web-02"
. 2008-04-16 11:42:13.663 Connecting to 10.x.x.27 port 22
. 2008-04-16 11:42:13.678 Server version: SSH-2.0-VShell_3_0_3_632 VShell
. 2008-04-16 11:42:13.678 We claim version: SSH-2.0-WinSCP_release_4.1
. 2008-04-16 11:42:13.678 SSPI: acquired credentials for: xxxxxxxxxxxxxx
. 2008-04-16 11:42:13.678 Constructed service principal name 'host/web-02'
. 2008-04-16 11:42:13.678 GSSKEX disabled: The specified target is unknown or unreachable
. 2008-04-16 11:42:13.678 Using SSH protocol version 2
. 2008-04-16 11:42:13.678 Doing Diffie-Hellman group exchange
. 2008-04-16 11:42:13.819 Doing Diffie-Hellman key exchange with hash SHA-1
. 2008-04-16 11:42:14.131 Host key fingerprint is:
. 2008-04-16 11:42:14.131 ssh-dss 1024 84:65:c1:fb:8c:81:3b:93:2c:0d:27:5f:08:a3:b3:97
. 2008-04-16 11:42:14.131 Initialised AES-256 CBC client->server encryption
. 2008-04-16 11:42:14.131 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-04-16 11:42:14.131 Initialised AES-256 CBC server->client encryption
. 2008-04-16 11:42:14.131 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-04-16 11:42:14.319 Using username "inc0n515t3nt".
. 2008-04-16 11:42:14.319 Prompt (6, SSH password, , &Password: )
. 2008-04-16 11:42:14.319 Using stored password.
. 2008-04-16 11:42:14.319 Sent password
. 2008-04-16 11:42:14.319 Access granted
. 2008-04-16 11:42:14.335 Opened channel for session
. 2008-04-16 11:42:14.335 Started a shell/command
. 2008-04-16 11:42:14.335 --------------------------------------------------------------------------
. 2008-04-16 11:42:14.335 Using SFTP protocol.
. 2008-04-16 11:42:14.335 Doing startup conversation with host.
> 2008-04-16 11:42:14.335 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-04-16 11:42:14.335 Type: SSH_FXP_VERSION, Size: 768, Number: -1
. 2008-04-16 11:42:14.335 SFTP version 4 negotiated.
. 2008-04-16 11:42:14.335 Unknown server extension newline@vandyke.com=0x000000020D0A
. 2008-04-16 11:42:14.335 Server requests EOL sequence 0x0D0A.
. 2008-04-16 11:42:14.335 Unknown server extension default-fs-attribs@vandyke.com=
. 2008-04-16 11:42:14.335 Server support information:
. 2008-04-16 11:42:14.335 Attribute mask: 800003F9, Attribute bits: 17, Open flags: 83F
. 2008-04-16 11:42:14.335 Access mask: 1F01FF, Open block masks: 0, Block masks: 0, Max read size: 32768
. 2008-04-16 11:42:14.335 Attribute extensions (0)
. 2008-04-16 11:42:14.335 Extensions (5)
. 2008-04-16 11:42:14.335 text-seek
. 2008-04-16 11:42:14.335 fs-multiple-roots-supported@vandyke.com
. 2008-04-16 11:42:14.335 space-available
. 2008-04-16 11:42:14.335 version-select
. 2008-04-16 11:42:14.335 vendor-id
. 2008-04-16 11:42:14.335 Access mask: 1F01FF, Open block masks: FFFFFFFF, Block masks: 0, Max read size: 32768
. 2008-04-16 11:42:14.335 Server software: VShell 3.0.3 (build 632 Unicode) (632) by VanDyke Software, Inc.
. 2008-04-16 11:42:14.335 SFTP versions supported by the server: 3,4,draft-ietf-secsh-filexfer-11@vandyke.com,partial-v6@vandyke.com
> 2008-04-16 11:42:14.335 Type: SSH_FXP_EXTENDED, Size: 61, Number: 968
. 2008-04-16 11:42:14.335 We will use UTF-8 strings when appropriate
. 2008-04-16 11:42:14.335 Getting current directory name.
. 2008-04-16 11:42:14.335 Getting real path for '.'
> 2008-04-16 11:42:14.335 Type: SSH_FXP_REALPATH, Size: 10, Number: 1040
< 2008-04-16 11:42:14.350 Type: SSH_FXP_STATUS, Size: 57, Number: 968
. 2008-04-16 11:42:14.350 Discarding reserved response
< 2008-04-16 11:42:14.366 Type: SSH_FXP_NAME, Size: 19, Number: 1040
. 2008-04-16 11:42:14.366 Real path is '/'
. 2008-04-16 11:42:14.366 Startup conversation with host finished.
. 2008-04-16 11:43:48.615 Collecting synchronization list for local directory '"D:\SYNC\WebPub' and remote directory '/D/InetPub', mode = 1, params = 5123
. 2008-04-16 11:43:48.615 Listing directory "/D/InetPub".
> 2008-04-16 11:43:48.615 Type: SSH_FXP_OPENDIR, Size: 19, Number: 1291
< 2008-04-16 11:43:48.615 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
> 2008-04-16 11:43:48.615 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
< 2008-04-16 11:43:48.615 Type: SSH_FXP_NAME, Size: 154, Number: 1548
> 2008-04-16 11:43:48.615 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
< 2008-04-16 11:43:48.615 Type: SSH_FXP_STATUS, Size: 44, Number: 1804
< 2008-04-16 11:43:48.615 Status/error code: 1
> 2008-04-16 11:43:48.615 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
. 2008-04-16 11:43:48.615 Collecting synchronization list for local directory '"D:\SYNC\WebPub\WWW' and remote directory '/D/InetPub/WWW', mode = 1, params = 5123
. 2008-04-16 11:43:48.615 Listing directory "/D/InetPub/WWW".
> 2008-04-16 11:43:48.615 Type: SSH_FXP_OPENDIR, Size: 27, Number: 2315
< 2008-04-16 11:43:48.615 Type: SSH_FXP_STATUS, Size: 34, Number: 2052
. 2008-04-16 11:43:48.615 Discarding reserved response
< 2008-04-16 11:43:48.615 Type: SSH_FXP_HANDLE, Size: 13, Number: 2315
> 2008-04-16 11:43:48.615 Type: SSH_FXP_READDIR, Size: 13, Number: 2572
< 2008-04-16 11:43:48.615 Type: SSH_FXP_NAME, Size: 211, Number: 2572
> 2008-04-16 11:43:48.615 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
< 2008-04-16 11:43:48.615 Type: SSH_FXP_STATUS, Size: 44, Number: 2828
> 2008-04-16 11:43:48.615 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
-----EDIT-----
> 2008-04-16 11:44:05.881 Type: SSH_FXP_CLOSE, Size: 13, Number: 1444868
< 2008-04-16 11:44:06.068 Type: SSH_FXP_STATUS, Size: 48, Number: 1444357
< 2008-04-16 11:44:06.068 Type: SSH_FXP_STATUS, Size: 48, Number: 1444613
. 2008-04-16 11:44:06.068 Synchronizing local directory '"D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\' with remote directory '/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/', params = 5123
. 2008-04-16 11:44:06.068 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%01^011^01174532%%form.tpl.php"
. 2008-04-16 11:44:06.068 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%01^011^01174532%%form.tpl.php" to local directory started.
. 2008-04-16 11:44:06.068 Ascii transfer mode selected.
. 2008-04-16 11:44:06.068 Opening remote file.
> 2008-04-16 11:44:06.068 Type: SSH_FXP_OPEN, Size: 114, Number: 1445123
< 2008-04-16 11:44:06.068 Type: SSH_FXP_STATUS, Size: 34, Number: 1444868
. 2008-04-16 11:44:06.068 Discarding reserved response
< 2008-04-16 11:44:06.068 Type: SSH_FXP_HANDLE, Size: 13, Number: 1445123
> 2008-04-16 11:44:06.068 Type: SSH_FXP_FSTAT, Size: 17, Number: 1445384
> 2008-04-16 11:44:06.068 Type: SSH_FXP_READ, Size: 25, Number: 1445637
< 2008-04-16 11:44:06.068 Type: SSH_FXP_ATTRS, Size: 58, Number: 1445384
. 2008-04-16 11:44:06.068 Storing reserved response
< 2008-04-16 11:44:06.084 Status/error code: 1
. 2008-04-16 11:44:06.084 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.084 Type: SSH_FXP_CLOSE, Size: 13, Number: 1446148
. 2008-04-16 11:44:06.084 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%08^082^082DDF17%%edit.tpl.php"
. 2008-04-16 11:44:06.084 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%08^082^082DDF17%%edit.tpl.php" to local directory started.
. 2008-04-16 11:44:06.084 Ascii transfer mode selected.
. 2008-04-16 11:44:06.084 Opening remote file.
> 2008-04-16 11:44:06.084 Type: SSH_FXP_OPEN, Size: 114, Number: 1446403
< 2008-04-16 11:44:06.084 Type: SSH_FXP_STATUS, Size: 34, Number: 1446148
. 2008-04-16 11:44:06.084 Discarding reserved response
< 2008-04-16 11:44:06.084 Type: SSH_FXP_HANDLE, Size: 13, Number: 1446403
> 2008-04-16 11:44:06.084 Type: SSH_FXP_FSTAT, Size: 17, Number: 1446664
> 2008-04-16 11:44:06.084 Type: SSH_FXP_READ, Size: 25, Number: 1446917
< 2008-04-16 11:44:06.084 Type: SSH_FXP_ATTRS, Size: 58, Number: 1446664
. 2008-04-16 11:44:06.084 Storing reserved response
> 2008-04-16 11:44:06.084 Type: SSH_FXP_CLOSE, Size: 13, Number: 1447428
. 2008-04-16 11:44:06.099 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%0E^0E4^0E407559%%footer.tpl.php"
. 2008-04-16 11:44:06.099 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%0E^0E4^0E407559%%footer.tpl.php" to local directory started.
. 2008-04-16 11:44:06.099 Ascii transfer mode selected.
. 2008-04-16 11:44:06.099 Opening remote file.
> 2008-04-16 11:44:06.099 Type: SSH_FXP_OPEN, Size: 116, Number: 1447683
< 2008-04-16 11:44:06.099 Type: SSH_FXP_STATUS, Size: 34, Number: 1447428
. 2008-04-16 11:44:06.099 Discarding reserved response
< 2008-04-16 11:44:06.099 Type: SSH_FXP_HANDLE, Size: 13, Number: 1447683
> 2008-04-16 11:44:06.099 Type: SSH_FXP_FSTAT, Size: 17, Number: 1447944
> 2008-04-16 11:44:06.099 Type: SSH_FXP_READ, Size: 25, Number: 1448197
< 2008-04-16 11:44:06.099 Type: SSH_FXP_ATTRS, Size: 58, Number: 1447944
. 2008-04-16 11:44:06.099 Storing reserved response
< 2008-04-16 11:44:06.099 Status/error code: 1
. 2008-04-16 11:44:06.099 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.099 Type: SSH_FXP_CLOSE, Size: 13, Number: 1448708
. 2008-04-16 11:44:06.099 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%1F^1F7^1F78B256%%breadcrumbs.tpl.php"
. 2008-04-16 11:44:06.099 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%1F^1F7^1F78B256%%breadcrumbs.tpl.php" to local directory started.
> 2008-04-16 11:44:06.099 Type: SSH_FXP_OPEN, Size: 121, Number: 1448963
< 2008-04-16 11:44:06.099 Type: SSH_FXP_STATUS, Size: 34, Number: 1448708
< 2008-04-16 11:44:06.099 Type: SSH_FXP_HANDLE, Size: 13, Number: 1448963
> 2008-04-16 11:44:06.099 Type: SSH_FXP_FSTAT, Size: 17, Number: 1449224
> 2008-04-16 11:44:06.099 Type: SSH_FXP_READ, Size: 25, Number: 1449477
< 2008-04-16 11:44:06.099 Type: SSH_FXP_ATTRS, Size: 58, Number: 1449224
< 2008-04-16 11:44:06.115 Status/error code: 1
. 2008-04-16 11:44:06.115 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.115 Type: SSH_FXP_CLOSE, Size: 13, Number: 1449988
. 2008-04-16 11:44:06.115 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%27^277^277B0EE4%%index.tpl.php"
. 2008-04-16 11:44:06.115 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%27^277^277B0EE4%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.115 Ascii transfer mode selected.
. 2008-04-16 11:44:06.115 Opening remote file.
> 2008-04-16 11:44:06.115 Type: SSH_FXP_OPEN, Size: 115, Number: 1450243
< 2008-04-16 11:44:06.115 Type: SSH_FXP_STATUS, Size: 34, Number: 1449988
. 2008-04-16 11:44:06.115 Discarding reserved response
< 2008-04-16 11:44:06.115 Type: SSH_FXP_HANDLE, Size: 13, Number: 1450243
> 2008-04-16 11:44:06.115 Type: SSH_FXP_FSTAT, Size: 17, Number: 1450504
> 2008-04-16 11:44:06.115 Type: SSH_FXP_READ, Size: 25, Number: 1450757
< 2008-04-16 11:44:06.115 Type: SSH_FXP_ATTRS, Size: 58, Number: 1450504
. 2008-04-16 11:44:06.115 Storing reserved response
> 2008-04-16 11:44:06.115 Type: SSH_FXP_CLOSE, Size: 13, Number: 1451268
. 2008-04-16 11:44:06.131 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%39^39E^39E915E8%%index.tpl.php"
. 2008-04-16 11:44:06.131 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%39^39E^39E915E8%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.131 Ascii transfer mode selected.
. 2008-04-16 11:44:06.131 Opening remote file.
> 2008-04-16 11:44:06.131 Type: SSH_FXP_OPEN, Size: 115, Number: 1451523
< 2008-04-16 11:44:06.131 Type: SSH_FXP_STATUS, Size: 34, Number: 1451268
. 2008-04-16 11:44:06.131 Discarding reserved response
< 2008-04-16 11:44:06.131 Type: SSH_FXP_HANDLE, Size: 13, Number: 1451523
> 2008-04-16 11:44:06.131 Type: SSH_FXP_FSTAT, Size: 17, Number: 1451784
> 2008-04-16 11:44:06.131 Type: SSH_FXP_READ, Size: 25, Number: 1452037
< 2008-04-16 11:44:06.131 Type: SSH_FXP_ATTRS, Size: 58, Number: 1451784
. 2008-04-16 11:44:06.131 Storing reserved response
< 2008-04-16 11:44:06.131 Status/error code: 1
. 2008-04-16 11:44:06.131 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.131 Type: SSH_FXP_CLOSE, Size: 13, Number: 1452548
. 2008-04-16 11:44:06.131 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%3E^3E0^3E08FA01%%index.tpl.php"
. 2008-04-16 11:44:06.131 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%3E^3E0^3E08FA01%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.146 Ascii transfer mode selected.
. 2008-04-16 11:44:06.146 Opening remote file.
> 2008-04-16 11:44:06.146 Type: SSH_FXP_OPEN, Size: 115, Number: 1452803
< 2008-04-16 11:44:06.146 Type: SSH_FXP_STATUS, Size: 34, Number: 1452548
. 2008-04-16 11:44:06.146 Discarding reserved response
< 2008-04-16 11:44:06.146 Type: SSH_FXP_HANDLE, Size: 13, Number: 1452803
> 2008-04-16 11:44:06.146 Type: SSH_FXP_FSTAT, Size: 17, Number: 1453064
> 2008-04-16 11:44:06.146 Type: SSH_FXP_READ, Size: 25, Number: 1453317
< 2008-04-16 11:44:06.146 Type: SSH_FXP_ATTRS, Size: 58, Number: 1453064
. 2008-04-16 11:44:06.146 Storing reserved response
< 2008-04-16 11:44:06.146 Status/error code: 1
. 2008-04-16 11:44:06.146 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.146 Type: SSH_FXP_CLOSE, Size: 13, Number: 1453828
. 2008-04-16 11:44:06.146 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%40^40F^40F2F7E4%%create.tpl.php"
. 2008-04-16 11:44:06.146 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%40^40F^40F2F7E4%%create.tpl.php" to local directory started.
> 2008-04-16 11:44:06.146 Type: SSH_FXP_OPEN, Size: 116, Number: 1454083
< 2008-04-16 11:44:06.146 Type: SSH_FXP_STATUS, Size: 34, Number: 1453828
< 2008-04-16 11:44:06.146 Type: SSH_FXP_HANDLE, Size: 13, Number: 1454083
> 2008-04-16 11:44:06.146 Type: SSH_FXP_FSTAT, Size: 17, Number: 1454344
> 2008-04-16 11:44:06.146 Type: SSH_FXP_READ, Size: 25, Number: 1454597
< 2008-04-16 11:44:06.146 Type: SSH_FXP_ATTRS, Size: 58, Number: 1454344
< 2008-04-16 11:44:06.162 Status/error code: 1
. 2008-04-16 11:44:06.162 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.162 Type: SSH_FXP_CLOSE, Size: 13, Number: 1455108
. 2008-04-16 11:44:06.162 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%47^47C^47C41053%%index.tpl.php"
. 2008-04-16 11:44:06.162 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%47^47C^47C41053%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.162 Ascii transfer mode selected.
. 2008-04-16 11:44:06.162 Opening remote file.
> 2008-04-16 11:44:06.162 Type: SSH_FXP_OPEN, Size: 115, Number: 1455363
< 2008-04-16 11:44:06.162 Type: SSH_FXP_STATUS, Size: 34, Number: 1455108
. 2008-04-16 11:44:06.162 Discarding reserved response
< 2008-04-16 11:44:06.162 Type: SSH_FXP_HANDLE, Size: 13, Number: 1455363
> 2008-04-16 11:44:06.162 Type: SSH_FXP_FSTAT, Size: 17, Number: 1455624
> 2008-04-16 11:44:06.162 Type: SSH_FXP_READ, Size: 25, Number: 1455877
< 2008-04-16 11:44:06.162 Type: SSH_FXP_ATTRS, Size: 58, Number: 1455624
. 2008-04-16 11:44:06.162 Storing reserved response
> 2008-04-16 11:44:06.162 Type: SSH_FXP_CLOSE, Size: 13, Number: 1456388
. 2008-04-16 11:44:06.162 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%57^570^570340C1%%index.tpl.php"
. 2008-04-16 11:44:06.162 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%57^570^570340C1%%index.tpl.php" to local directory started.
> 2008-04-16 11:44:06.178 Type: SSH_FXP_OPEN, Size: 115, Number: 1456643
< 2008-04-16 11:44:06.178 Type: SSH_FXP_STATUS, Size: 34, Number: 1456388
. 2008-04-16 11:44:06.178 Discarding reserved response
< 2008-04-16 11:44:06.178 Type: SSH_FXP_HANDLE, Size: 13, Number: 1456643
> 2008-04-16 11:44:06.178 Type: SSH_FXP_FSTAT, Size: 17, Number: 1456904
> 2008-04-16 11:44:06.178 Type: SSH_FXP_READ, Size: 25, Number: 1457157
< 2008-04-16 11:44:06.178 Type: SSH_FXP_ATTRS, Size: 58, Number: 1456904
. 2008-04-16 11:44:06.178 Storing reserved response
< 2008-04-16 11:44:06.178 Status/error code: 1
. 2008-04-16 11:44:06.178 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.178 Type: SSH_FXP_CLOSE, Size: 13, Number: 1457668
. 2008-04-16 11:44:06.178 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%60^605^6051ECA6%%index.tpl.php"
. 2008-04-16 11:44:06.178 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%60^605^6051ECA6%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.178 Ascii transfer mode selected.
. 2008-04-16 11:44:06.178 Opening remote file.
> 2008-04-16 11:44:06.178 Type: SSH_FXP_OPEN, Size: 115, Number: 1457923
< 2008-04-16 11:44:06.178 Type: SSH_FXP_STATUS, Size: 34, Number: 1457668
< 2008-04-16 11:44:06.178 Type: SSH_FXP_HANDLE, Size: 13, Number: 1457923
> 2008-04-16 11:44:06.178 Type: SSH_FXP_FSTAT, Size: 17, Number: 1458184
> 2008-04-16 11:44:06.178 Type: SSH_FXP_READ, Size: 25, Number: 1458437
< 2008-04-16 11:44:06.193 Type: SSH_FXP_ATTRS, Size: 58, Number: 1458184
. 2008-04-16 11:44:06.193 Storing reserved response
< 2008-04-16 11:44:06.365 Status/error code: 1
. 2008-04-16 11:44:06.365 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.365 Type: SSH_FXP_CLOSE, Size: 13, Number: 1458948
. 2008-04-16 11:44:06.365 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%65^65C^65C7D16F%%index.tpl.php"
. 2008-04-16 11:44:06.365 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%65^65C^65C7D16F%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.365 Ascii transfer mode selected.
. 2008-04-16 11:44:06.365 Opening remote file.
> 2008-04-16 11:44:06.365 Type: SSH_FXP_OPEN, Size: 115, Number: 1459203
< 2008-04-16 11:44:06.365 Type: SSH_FXP_STATUS, Size: 34, Number: 1458948
. 2008-04-16 11:44:06.365 Discarding reserved response
< 2008-04-16 11:44:06.381 Type: SSH_FXP_HANDLE, Size: 13, Number: 1459203
> 2008-04-16 11:44:06.381 Type: SSH_FXP_FSTAT, Size: 17, Number: 1459464
> 2008-04-16 11:44:06.381 Type: SSH_FXP_READ, Size: 25, Number: 1459717
< 2008-04-16 11:44:06.381 Type: SSH_FXP_ATTRS, Size: 58, Number: 1459464
. 2008-04-16 11:44:06.381 Storing reserved response
< 2008-04-16 11:44:06.381 Status/error code: 1
. 2008-04-16 11:44:06.381 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.381 Type: SSH_FXP_CLOSE, Size: 13, Number: 1460228
. 2008-04-16 11:44:06.381 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%68^689^68964653%%head.tpl.php"
. 2008-04-16 11:44:06.381 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%68^689^68964653%%head.tpl.php" to local directory started.
. 2008-04-16 11:44:06.381 Ascii transfer mode selected.
. 2008-04-16 11:44:06.381 Opening remote file.
> 2008-04-16 11:44:06.381 Type: SSH_FXP_OPEN, Size: 114, Number: 1460483
< 2008-04-16 11:44:06.381 Type: SSH_FXP_STATUS, Size: 34, Number: 1460228
. 2008-04-16 11:44:06.381 Discarding reserved response
< 2008-04-16 11:44:06.381 Type: SSH_FXP_HANDLE, Size: 13, Number: 1460483
> 2008-04-16 11:44:06.381 Type: SSH_FXP_FSTAT, Size: 17, Number: 1460744
> 2008-04-16 11:44:06.396 Type: SSH_FXP_READ, Size: 25, Number: 1460997
< 2008-04-16 11:44:06.396 Type: SSH_FXP_ATTRS, Size: 58, Number: 1460744
. 2008-04-16 11:44:06.396 Storing reserved response
< 2008-04-16 11:44:06.396 Status/error code: 1
. 2008-04-16 11:44:06.396 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.396 Type: SSH_FXP_CLOSE, Size: 13, Number: 1461508
. 2008-04-16 11:44:06.396 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%6A^6A9^6A9E784A%%main.tpl.php"
. 2008-04-16 11:44:06.396 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%6A^6A9^6A9E784A%%main.tpl.php" to local directory started.
. 2008-04-16 11:44:06.396 Ascii transfer mode selected.
. 2008-04-16 11:44:06.396 Opening remote file.
> 2008-04-16 11:44:06.396 Type: SSH_FXP_OPEN, Size: 114, Number: 1461763
< 2008-04-16 11:44:06.396 Type: SSH_FXP_STATUS, Size: 34, Number: 1461508
. 2008-04-16 11:44:06.396 Discarding reserved response
< 2008-04-16 11:44:06.396 Type: SSH_FXP_HANDLE, Size: 13, Number: 1461763
> 2008-04-16 11:44:06.396 Type: SSH_FXP_FSTAT, Size: 17, Number: 1462024
> 2008-04-16 11:44:06.396 Type: SSH_FXP_READ, Size: 25, Number: 1462277
< 2008-04-16 11:44:06.396 Type: SSH_FXP_ATTRS, Size: 58, Number: 1462024
< 2008-04-16 11:44:06.412 Status/error code: 1
. 2008-04-16 11:44:06.412 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.412 Type: SSH_FXP_CLOSE, Size: 13, Number: 1462788
. 2008-04-16 11:44:06.412 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%6E^6E0^6E038A3B%%index.tpl.php"
. 2008-04-16 11:44:06.412 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%6E^6E0^6E038A3B%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.412 Ascii transfer mode selected.
. 2008-04-16 11:44:06.412 Opening remote file.
> 2008-04-16 11:44:06.412 Type: SSH_FXP_OPEN, Size: 115, Number: 1463043
< 2008-04-16 11:44:06.412 Type: SSH_FXP_STATUS, Size: 34, Number: 1462788
. 2008-04-16 11:44:06.412 Discarding reserved response
< 2008-04-16 11:44:06.412 Type: SSH_FXP_HANDLE, Size: 13, Number: 1463043
> 2008-04-16 11:44:06.412 Type: SSH_FXP_FSTAT, Size: 17, Number: 1463304
> 2008-04-16 11:44:06.412 Type: SSH_FXP_READ, Size: 25, Number: 1463557
< 2008-04-16 11:44:06.412 Type: SSH_FXP_ATTRS, Size: 58, Number: 1463304
. 2008-04-16 11:44:06.412 Storing reserved response
< 2008-04-16 11:44:06.428 Status/error code: 1
. 2008-04-16 11:44:06.428 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.428 Type: SSH_FXP_CLOSE, Size: 13, Number: 1464068
. 2008-04-16 11:44:06.428 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%80^804^80448BA5%%form.tpl.php"
. 2008-04-16 11:44:06.428 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%80^804^80448BA5%%form.tpl.php" to local directory started.
. 2008-04-16 11:44:06.428 Ascii transfer mode selected.
. 2008-04-16 11:44:06.428 Opening remote file.
> 2008-04-16 11:44:06.428 Type: SSH_FXP_OPEN, Size: 114, Number: 1464323
< 2008-04-16 11:44:06.428 Type: SSH_FXP_STATUS, Size: 34, Number: 1464068
. 2008-04-16 11:44:06.428 Discarding reserved response
< 2008-04-16 11:44:06.428 Type: SSH_FXP_HANDLE, Size: 13, Number: 1464323
> 2008-04-16 11:44:06.428 Type: SSH_FXP_FSTAT, Size: 17, Number: 1464584
> 2008-04-16 11:44:06.428 Type: SSH_FXP_READ, Size: 25, Number: 1464837
< 2008-04-16 11:44:06.428 Type: SSH_FXP_ATTRS, Size: 58, Number: 1464584
. 2008-04-16 11:44:06.428 Storing reserved response
> 2008-04-16 11:44:06.428 Type: SSH_FXP_CLOSE, Size: 13, Number: 1465348
. 2008-04-16 11:44:06.443 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%89^897^897E1180%%edit.tpl.php"
. 2008-04-16 11:44:06.443 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%89^897^897E1180%%edit.tpl.php" to local directory started.
. 2008-04-16 11:44:06.443 Ascii transfer mode selected.
. 2008-04-16 11:44:06.443 Opening remote file.
> 2008-04-16 11:44:06.443 Type: SSH_FXP_OPEN, Size: 114, Number: 1465603
< 2008-04-16 11:44:06.443 Type: SSH_FXP_STATUS, Size: 34, Number: 1465348
. 2008-04-16 11:44:06.443 Discarding reserved response
< 2008-04-16 11:44:06.443 Type: SSH_FXP_HANDLE, Size: 13, Number: 1465603
> 2008-04-16 11:44:06.443 Type: SSH_FXP_FSTAT, Size: 17, Number: 1465864
> 2008-04-16 11:44:06.443 Type: SSH_FXP_READ, Size: 25, Number: 1466117
< 2008-04-16 11:44:06.443 Type: SSH_FXP_ATTRS, Size: 58, Number: 1465864
. 2008-04-16 11:44:06.443 Storing reserved response
< 2008-04-16 11:44:06.443 Status/error code: 1
. 2008-04-16 11:44:06.443 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.443 Type: SSH_FXP_CLOSE, Size: 13, Number: 1466628
. 2008-04-16 11:44:06.443 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8A^8A6^8A6EEBBC%%pagination.tpl.php"
. 2008-04-16 11:44:06.443 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8A^8A6^8A6EEBBC%%pagination.tpl.php" to local directory started.
> 2008-04-16 11:44:06.443 Type: SSH_FXP_OPEN, Size: 120, Number: 1466883
< 2008-04-16 11:44:06.443 Type: SSH_FXP_STATUS, Size: 34, Number: 1466628
< 2008-04-16 11:44:06.443 Type: SSH_FXP_HANDLE, Size: 13, Number: 1466883
> 2008-04-16 11:44:06.443 Type: SSH_FXP_FSTAT, Size: 17, Number: 1467144
> 2008-04-16 11:44:06.443 Type: SSH_FXP_READ, Size: 25, Number: 1467397
< 2008-04-16 11:44:06.459 Type: SSH_FXP_ATTRS, Size: 58, Number: 1467144
. 2008-04-16 11:44:06.459 Storing reserved response
< 2008-04-16 11:44:06.459 Status/error code: 1
. 2008-04-16 11:44:06.459 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.459 Type: SSH_FXP_CLOSE, Size: 13, Number: 1467908
. 2008-04-16 11:44:06.459 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8B^8BA^8BA52638%%goodsin.tpl.php"
. 2008-04-16 11:44:06.459 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8B^8BA^8BA52638%%goodsin.tpl.php" to local directory started.
. 2008-04-16 11:44:06.459 Ascii transfer mode selected.
. 2008-04-16 11:44:06.459 Opening remote file.
> 2008-04-16 11:44:06.459 Type: SSH_FXP_OPEN, Size: 117, Number: 1468163
< 2008-04-16 11:44:06.459 Type: SSH_FXP_STATUS, Size: 34, Number: 1467908
. 2008-04-16 11:44:06.459 Discarding reserved response
< 2008-04-16 11:44:06.459 Type: SSH_FXP_HANDLE, Size: 13, Number: 1468163
> 2008-04-16 11:44:06.459 Type: SSH_FXP_FSTAT, Size: 17, Number: 1468424
> 2008-04-16 11:44:06.459 Type: SSH_FXP_READ, Size: 25, Number: 1468677
< 2008-04-16 11:44:06.459 Type: SSH_FXP_ATTRS, Size: 58, Number: 1468424
< 2008-04-16 11:44:06.474 Status/error code: 1
. 2008-04-16 11:44:06.474 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.474 Type: SSH_FXP_CLOSE, Size: 13, Number: 1469188
. 2008-04-16 11:44:06.474 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8C^8CA^8CA044D0%%menu.tpl.php"
. 2008-04-16 11:44:06.474 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8C^8CA^8CA044D0%%menu.tpl.php" to local directory started.
. 2008-04-16 11:44:06.474 Ascii transfer mode selected.
. 2008-04-16 11:44:06.474 Opening remote file.
> 2008-04-16 11:44:06.474 Type: SSH_FXP_OPEN, Size: 114, Number: 1469443
< 2008-04-16 11:44:06.474 Type: SSH_FXP_STATUS, Size: 34, Number: 1469188
. 2008-04-16 11:44:06.474 Discarding reserved response
< 2008-04-16 11:44:06.474 Type: SSH_FXP_HANDLE, Size: 13, Number: 1469443
> 2008-04-16 11:44:06.474 Type: SSH_FXP_FSTAT, Size: 17, Number: 1469704
> 2008-04-16 11:44:06.474 Type: SSH_FXP_READ, Size: 25, Number: 1469957
< 2008-04-16 11:44:06.474 Type: SSH_FXP_ATTRS, Size: 58, Number: 1469704
. 2008-04-16 11:44:06.474 Storing reserved response
> 2008-04-16 11:44:06.474 Type: SSH_FXP_CLOSE, Size: 13, Number: 1470468
. 2008-04-16 11:44:06.490 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8C^8CC^8CCC361F%%order_confirmation.tpl.php"
. 2008-04-16 11:44:06.490 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%8C^8CC^8CCC361F%%order_confirmation.tpl.php" to local directory started.
. 2008-04-16 11:44:06.490 Ascii transfer mode selected.
. 2008-04-16 11:44:06.490 Opening remote file.
> 2008-04-16 11:44:06.490 Type: SSH_FXP_OPEN, Size: 128, Number: 1470723
< 2008-04-16 11:44:06.490 Type: SSH_FXP_STATUS, Size: 34, Number: 1470468
. 2008-04-16 11:44:06.490 Discarding reserved response
< 2008-04-16 11:44:06.490 Type: SSH_FXP_HANDLE, Size: 13, Number: 1470723
> 2008-04-16 11:44:06.490 Type: SSH_FXP_FSTAT, Size: 17, Number: 1470984
> 2008-04-16 11:44:06.490 Type: SSH_FXP_READ, Size: 25, Number: 1471237
< 2008-04-16 11:44:06.490 Type: SSH_FXP_ATTRS, Size: 58, Number: 1470984
. 2008-04-16 11:44:06.490 Storing reserved response
< 2008-04-16 11:44:06.490 Status/error code: 1
. 2008-04-16 11:44:06.490 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.490 Type: SSH_FXP_CLOSE, Size: 13, Number: 1471748
. 2008-04-16 11:44:06.490 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%96^965^965C8BF6%%form.tpl.php"
. 2008-04-16 11:44:06.490 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%96^965^965C8BF6%%form.tpl.php" to local directory started.
> 2008-04-16 11:44:06.490 Type: SSH_FXP_OPEN, Size: 114, Number: 1472003
< 2008-04-16 11:44:06.490 Type: SSH_FXP_STATUS, Size: 34, Number: 1471748
< 2008-04-16 11:44:06.490 Type: SSH_FXP_HANDLE, Size: 13, Number: 1472003
> 2008-04-16 11:44:06.490 Type: SSH_FXP_FSTAT, Size: 17, Number: 1472264
> 2008-04-16 11:44:06.490 Type: SSH_FXP_READ, Size: 25, Number: 1472517
< 2008-04-16 11:44:06.490 Type: SSH_FXP_ATTRS, Size: 58, Number: 1472264
< 2008-04-16 11:44:06.506 Status/error code: 1
. 2008-04-16 11:44:06.506 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.506 Type: SSH_FXP_CLOSE, Size: 13, Number: 1473028
. 2008-04-16 11:44:06.506 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%9C^9CA^9CA4A7D7%%error.tpl.php"
. 2008-04-16 11:44:06.506 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%9C^9CA^9CA4A7D7%%error.tpl.php" to local directory started.
. 2008-04-16 11:44:06.506 Ascii transfer mode selected.
. 2008-04-16 11:44:06.506 Opening remote file.
> 2008-04-16 11:44:06.506 Type: SSH_FXP_OPEN, Size: 115, Number: 1473283
< 2008-04-16 11:44:06.506 Type: SSH_FXP_STATUS, Size: 34, Number: 1473028
. 2008-04-16 11:44:06.506 Discarding reserved response
< 2008-04-16 11:44:06.506 Type: SSH_FXP_HANDLE, Size: 13, Number: 1473283
> 2008-04-16 11:44:06.506 Type: SSH_FXP_FSTAT, Size: 17, Number: 1473544
> 2008-04-16 11:44:06.506 Type: SSH_FXP_READ, Size: 25, Number: 1473797
< 2008-04-16 11:44:06.506 Type: SSH_FXP_ATTRS, Size: 58, Number: 1473544
. 2008-04-16 11:44:06.506 Storing reserved response
> 2008-04-16 11:44:06.506 Type: SSH_FXP_CLOSE, Size: 13, Number: 1474308
. 2008-04-16 11:44:06.521 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%B6^B66^B6692D6D%%index.tpl.php"
. 2008-04-16 11:44:06.521 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%B6^B66^B6692D6D%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.521 Ascii transfer mode selected.
. 2008-04-16 11:44:06.521 Opening remote file.
> 2008-04-16 11:44:06.521 Type: SSH_FXP_OPEN, Size: 115, Number: 1474563
< 2008-04-16 11:44:06.521 Type: SSH_FXP_STATUS, Size: 34, Number: 1474308
. 2008-04-16 11:44:06.521 Discarding reserved response
< 2008-04-16 11:44:06.521 Type: SSH_FXP_HANDLE, Size: 13, Number: 1474563
> 2008-04-16 11:44:06.521 Type: SSH_FXP_FSTAT, Size: 17, Number: 1474824
> 2008-04-16 11:44:06.521 Type: SSH_FXP_READ, Size: 25, Number: 1475077
< 2008-04-16 11:44:06.521 Type: SSH_FXP_ATTRS, Size: 58, Number: 1474824
. 2008-04-16 11:44:06.521 Storing reserved response
< 2008-04-16 11:44:06.662 Status/error code: 1
. 2008-04-16 11:44:06.662 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.662 Type: SSH_FXP_CLOSE, Size: 13, Number: 1475588
. 2008-04-16 11:44:06.678 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%BA^BA3^BA328305%%orderconfirmation.tpl.php"
. 2008-04-16 11:44:06.678 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%BA^BA3^BA328305%%orderconfirmation.tpl.php" to local directory started.
. 2008-04-16 11:44:06.678 Ascii transfer mode selected.
. 2008-04-16 11:44:06.678 Opening remote file.
> 2008-04-16 11:44:06.678 Type: SSH_FXP_OPEN, Size: 127, Number: 1475843
< 2008-04-16 11:44:06.678 Type: SSH_FXP_STATUS, Size: 34, Number: 1475588
. 2008-04-16 11:44:06.678 Discarding reserved response
< 2008-04-16 11:44:06.678 Type: SSH_FXP_HANDLE, Size: 13, Number: 1475843
> 2008-04-16 11:44:06.678 Type: SSH_FXP_FSTAT, Size: 17, Number: 1476104
> 2008-04-16 11:44:06.678 Type: SSH_FXP_READ, Size: 25, Number: 1476357
< 2008-04-16 11:44:06.678 Type: SSH_FXP_ATTRS, Size: 58, Number: 1476104
. 2008-04-16 11:44:06.678 Storing reserved response
< 2008-04-16 11:44:06.678 Status/error code: 1
. 2008-04-16 11:44:06.678 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.678 Type: SSH_FXP_CLOSE, Size: 13, Number: 1476868
. 2008-04-16 11:44:06.678 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%C8^C80^C8024708%%index.tpl.php"
. 2008-04-16 11:44:06.678 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%C8^C80^C8024708%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.693 Opening remote file.
> 2008-04-16 11:44:06.693 Type: SSH_FXP_OPEN, Size: 115, Number: 1477123
< 2008-04-16 11:44:06.693 Type: SSH_FXP_STATUS, Size: 34, Number: 1476868
. 2008-04-16 11:44:06.693 Discarding reserved response
< 2008-04-16 11:44:06.693 Type: SSH_FXP_HANDLE, Size: 13, Number: 1477123
> 2008-04-16 11:44:06.693 Type: SSH_FXP_FSTAT, Size: 17, Number: 1477384
> 2008-04-16 11:44:06.693 Type: SSH_FXP_READ, Size: 25, Number: 1477637
< 2008-04-16 11:44:06.693 Type: SSH_FXP_ATTRS, Size: 58, Number: 1477384
. 2008-04-16 11:44:06.693 Storing reserved response
< 2008-04-16 11:44:06.709 Status/error code: 1
. 2008-04-16 11:44:06.709 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.709 Type: SSH_FXP_CLOSE, Size: 13, Number: 1478148
. 2008-04-16 11:44:06.709 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%CB^CB9^CB9D0DA6%%index.tpl.php"
. 2008-04-16 11:44:06.709 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%CB^CB9^CB9D0DA6%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.709 Ascii transfer mode selected.
. 2008-04-16 11:44:06.709 Opening remote file.
> 2008-04-16 11:44:06.709 Type: SSH_FXP_OPEN, Size: 115, Number: 1478403
< 2008-04-16 11:44:06.709 Type: SSH_FXP_STATUS, Size: 34, Number: 1478148
. 2008-04-16 11:44:06.709 Discarding reserved response
< 2008-04-16 11:44:06.709 Type: SSH_FXP_HANDLE, Size: 13, Number: 1478403
> 2008-04-16 11:44:06.709 Type: SSH_FXP_FSTAT, Size: 17, Number: 1478664
> 2008-04-16 11:44:06.709 Type: SSH_FXP_READ, Size: 25, Number: 1478917
< 2008-04-16 11:44:06.709 Type: SSH_FXP_ATTRS, Size: 58, Number: 1478664
. 2008-04-16 11:44:06.709 Storing reserved response
< 2008-04-16 11:44:06.724 Status/error code: 1
. 2008-04-16 11:44:06.724 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.724 Type: SSH_FXP_CLOSE, Size: 13, Number: 1479428
. 2008-04-16 11:44:06.724 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%D1^D16^D164EF6B%%create.tpl.php"
. 2008-04-16 11:44:06.724 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%D1^D16^D164EF6B%%create.tpl.php" to local directory started.
. 2008-04-16 11:44:06.724 Ascii transfer mode selected.
. 2008-04-16 11:44:06.724 Opening remote file.
> 2008-04-16 11:44:06.724 Type: SSH_FXP_OPEN, Size: 116, Number: 1479683
< 2008-04-16 11:44:06.724 Type: SSH_FXP_STATUS, Size: 34, Number: 1479428
. 2008-04-16 11:44:06.724 Discarding reserved response
< 2008-04-16 11:44:06.724 Type: SSH_FXP_HANDLE, Size: 13, Number: 1479683
> 2008-04-16 11:44:06.724 Type: SSH_FXP_FSTAT, Size: 17, Number: 1479944
> 2008-04-16 11:44:06.724 Type: SSH_FXP_READ, Size: 25, Number: 1480197
< 2008-04-16 11:44:06.724 Type: SSH_FXP_ATTRS, Size: 58, Number: 1479944
. 2008-04-16 11:44:06.724 Storing reserved response
> 2008-04-16 11:44:06.724 Type: SSH_FXP_CLOSE, Size: 13, Number: 1480708
. 2008-04-16 11:44:06.740 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%DC^DC3^DC3DB833%%orderer_selector.tpl.php"
. 2008-04-16 11:44:06.740 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%DC^DC3^DC3DB833%%orderer_selector.tpl.php" to local directory started.
. 2008-04-16 11:44:06.740 Ascii transfer mode selected.
. 2008-04-16 11:44:06.740 Opening remote file.
> 2008-04-16 11:44:06.740 Type: SSH_FXP_OPEN, Size: 126, Number: 1480963
< 2008-04-16 11:44:06.740 Type: SSH_FXP_STATUS, Size: 34, Number: 1480708
. 2008-04-16 11:44:06.740 Discarding reserved response
< 2008-04-16 11:44:06.740 Type: SSH_FXP_HANDLE, Size: 13, Number: 1480963
> 2008-04-16 11:44:06.740 Type: SSH_FXP_FSTAT, Size: 17, Number: 1481224
> 2008-04-16 11:44:06.740 Type: SSH_FXP_READ, Size: 25, Number: 1481477
< 2008-04-16 11:44:06.740 Type: SSH_FXP_ATTRS, Size: 58, Number: 1481224
. 2008-04-16 11:44:06.740 Storing reserved response
< 2008-04-16 11:44:06.740 Status/error code: 1
. 2008-04-16 11:44:06.740 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.740 Type: SSH_FXP_CLOSE, Size: 13, Number: 1481988
. 2008-04-16 11:44:06.740 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%F4^F44^F4499389%%index.tpl.php"
. 2008-04-16 11:44:06.740 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%F4^F44^F4499389%%index.tpl.php" to local directory started.
. 2008-04-16 11:44:06.756 Opening remote file.
> 2008-04-16 11:44:06.756 Type: SSH_FXP_OPEN, Size: 115, Number: 1482243
< 2008-04-16 11:44:06.756 Type: SSH_FXP_STATUS, Size: 34, Number: 1481988
. 2008-04-16 11:44:06.756 Discarding reserved response
< 2008-04-16 11:44:06.756 Type: SSH_FXP_HANDLE, Size: 13, Number: 1482243
> 2008-04-16 11:44:06.756 Type: SSH_FXP_FSTAT, Size: 17, Number: 1482504
> 2008-04-16 11:44:06.756 Type: SSH_FXP_READ, Size: 25, Number: 1482757
< 2008-04-16 11:44:06.756 Type: SSH_FXP_ATTRS, Size: 58, Number: 1482504
. 2008-04-16 11:44:06.756 Storing reserved response
< 2008-04-16 11:44:06.771 Status/error code: 1
. 2008-04-16 11:44:06.771 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.771 Type: SSH_FXP_CLOSE, Size: 13, Number: 1483268
. 2008-04-16 11:44:06.771 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%F7^F7F^F7F34188%%header.tpl.php"
. 2008-04-16 11:44:06.771 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%F7^F7F^F7F34188%%header.tpl.php" to local directory started.
. 2008-04-16 11:44:06.771 Ascii transfer mode selected.
. 2008-04-16 11:44:06.771 Opening remote file.
> 2008-04-16 11:44:06.771 Type: SSH_FXP_OPEN, Size: 116, Number: 1483523
< 2008-04-16 11:44:06.771 Type: SSH_FXP_STATUS, Size: 34, Number: 1483268
. 2008-04-16 11:44:06.771 Discarding reserved response
< 2008-04-16 11:44:06.771 Type: SSH_FXP_HANDLE, Size: 13, Number: 1483523
> 2008-04-16 11:44:06.771 Type: SSH_FXP_FSTAT, Size: 17, Number: 1483784
> 2008-04-16 11:44:06.771 Type: SSH_FXP_READ, Size: 25, Number: 1484037
< 2008-04-16 11:44:06.771 Type: SSH_FXP_ATTRS, Size: 58, Number: 1483784
. 2008-04-16 11:44:06.771 Storing reserved response
< 2008-04-16 11:44:06.787 Status/error code: 1
. 2008-04-16 11:44:06.787 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.787 Type: SSH_FXP_CLOSE, Size: 13, Number: 1484548
. 2008-04-16 11:44:06.787 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%FA^FAA^FAAB3352%%basket.tpl.php"
. 2008-04-16 11:44:06.787 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%FA^FAA^FAAB3352%%basket.tpl.php" to local directory started.
. 2008-04-16 11:44:06.787 Ascii transfer mode selected.
. 2008-04-16 11:44:06.787 Opening remote file.
> 2008-04-16 11:44:06.787 Type: SSH_FXP_OPEN, Size: 116, Number: 1484803
< 2008-04-16 11:44:06.787 Type: SSH_FXP_STATUS, Size: 34, Number: 1484548
. 2008-04-16 11:44:06.787 Discarding reserved response
< 2008-04-16 11:44:06.787 Type: SSH_FXP_HANDLE, Size: 13, Number: 1484803
> 2008-04-16 11:44:06.787 Type: SSH_FXP_FSTAT, Size: 17, Number: 1485064
> 2008-04-16 11:44:06.787 Type: SSH_FXP_READ, Size: 25, Number: 1485317
< 2008-04-16 11:44:06.787 Type: SSH_FXP_ATTRS, Size: 58, Number: 1485064
. 2008-04-16 11:44:06.787 Storing reserved response
> 2008-04-16 11:44:06.787 Type: SSH_FXP_CLOSE, Size: 13, Number: 1485828
. 2008-04-16 11:44:06.787 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%FB^FB6^FB625FE9%%index.tpl.php"
. 2008-04-16 11:44:06.787 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%FB^FB6^FB625FE9%%index.tpl.php" to local directory started.
> 2008-04-16 11:44:06.787 Type: SSH_FXP_OPEN, Size: 115, Number: 1486083
< 2008-04-16 11:44:06.803 Type: SSH_FXP_STATUS, Size: 34, Number: 1485828
. 2008-04-16 11:44:06.803 Discarding reserved response
< 2008-04-16 11:44:06.803 Type: SSH_FXP_HANDLE, Size: 13, Number: 1486083
> 2008-04-16 11:44:06.803 Type: SSH_FXP_FSTAT, Size: 17, Number: 1486344
> 2008-04-16 11:44:06.803 Type: SSH_FXP_READ, Size: 25, Number: 1486597
< 2008-04-16 11:44:06.803 Type: SSH_FXP_ATTRS, Size: 58, Number: 1486344
. 2008-04-16 11:44:06.803 Storing reserved response
< 2008-04-16 11:44:06.803 Status/error code: 1
. 2008-04-16 11:44:06.803 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:44:06.803 Type: SSH_FXP_CLOSE, Size: 13, Number: 1487108
. 2008-04-16 11:44:13.865 Closing connection.
Run #2: Local DIR synched |
Synch breaks. |
Files on local are deleted when they still exist on source.|
. 2008-04-16 11:44:49.318 --------------------------------------------------------------------------
. 2008-04-16 11:44:49.318 WinSCP Version 4.1.0 (Build 375) (OS 5.1.2600 Service Pack 2)
. 2008-04-16 11:44:49.318 Login time: 16 April 2008 11:44:49
. 2008-04-16 11:44:49.318 Session name: xxxxxxxxxxxxxxxxxx
. 2008-04-16 11:44:49.318 Host name: web-02 (Port: 22)
. 2008-04-16 11:44:49.318 User name: xxxxxxx (Password: Yes, Key file: No)
. 2008-04-16 11:44:49.318 Tunnel: No
. 2008-04-16 11:44:49.318 Transfer Protocol: SFTP (SCP)
. 2008-04-16 11:44:49.318 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-04-16 11:44:49.318 Proxy: none
. 2008-04-16 11:44:49.318 SSH protocol version: 2; Compression: No
. 2008-04-16 11:44:49.318 Bypass authentication: No
. 2008-04-16 11:44:49.318 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-04-16 11:44:49.318 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2008-04-16 11:44:49.318 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-04-16 11:44:49.318 SFTP Bugs: -,-
. 2008-04-16 11:44:49.318 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-04-16 11:44:49.318 Shell: default, EOL: 1
. 2008-04-16 11:44:49.318 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-04-16 11:44:49.318 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2008-04-16 11:44:49.318 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-04-16 11:44:49.318 Cache directory changes: Yes, Permanent: Yes
. 2008-04-16 11:44:49.318 DST mode: 0
. 2008-04-16 11:44:49.318 Looking up host "web-02"
. 2008-04-16 11:44:49.318 Connecting to xx.xx.1.27 port 22
. 2008-04-16 11:44:49.318 Server version: SSH-2.0-VShell_3_0_3_632 VShell
. 2008-04-16 11:44:49.318 We claim version: SSH-2.0-WinSCP_release_4.1
. 2008-04-16 11:44:49.318 SSPI: acquired credentials for: xxxxxxxxxxxxxxxxxxxxx
. 2008-04-16 11:44:49.318 Constructed service principal name 'host/web-02'
. 2008-04-16 11:44:49.318 GSSKEX disabled: The specified target is unknown or unreachable
. 2008-04-16 11:44:49.318 Using SSH protocol version 2
. 2008-04-16 11:44:49.318 Doing Diffie-Hellman group exchange
. 2008-04-16 11:44:49.459 Doing Diffie-Hellman key exchange with hash SHA-1
. 2008-04-16 11:44:49.755 Host key fingerprint is:
. 2008-04-16 11:44:49.755 ssh-dss 1024 84:65:c1:fb:8c:81:3b:93:2c:0d:27:5f:08:a3:b3:97
. 2008-04-16 11:44:49.755 Initialised AES-256 CBC client->server encryption
. 2008-04-16 11:44:49.755 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-04-16 11:44:49.755 Initialised AES-256 CBC server->client encryption
. 2008-04-16 11:44:49.755 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-04-16 11:44:49.959 Using username "inc0n515t3nt".
. 2008-04-16 11:44:49.959 Prompt (6, SSH password, , &Password: )
. 2008-04-16 11:44:49.959 Using stored password.
. 2008-04-16 11:44:49.959 Sent password
. 2008-04-16 11:44:49.974 Access granted
. 2008-04-16 11:44:49.974 Opened channel for session
. 2008-04-16 11:44:49.974 Started a shell/command
. 2008-04-16 11:44:49.974 --------------------------------------------------------------------------
. 2008-04-16 11:44:49.974 Using SFTP protocol.
. 2008-04-16 11:44:49.974 Doing startup conversation with host.
> 2008-04-16 11:44:49.974 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2008-04-16 11:44:49.990 Type: SSH_FXP_VERSION, Size: 768, Number: -1
. 2008-04-16 11:44:49.990 SFTP version 4 negotiated.
. 2008-04-16 11:44:49.990 Unknown server extension newline@vandyke.com=0x000000020D0A
. 2008-04-16 11:44:49.990 Server requests EOL sequence 0x0D0A.
. 2008-04-16 11:44:49.990 Unknown server extension default-fs-attribs@vandyke.com=
. 2008-04-16 11:44:49.990 Server support information:
. 2008-04-16 11:44:49.990 Attribute mask: 800003F9, Attribute bits: 17, Open flags: 83F
. 2008-04-16 11:44:49.990 Access mask: 1F01FF, Open block masks: 0, Block masks: 0, Max read size: 32768
. 2008-04-16 11:44:49.990 Attribute extensions (0)
. 2008-04-16 11:44:49.990 Extensions (5)
. 2008-04-16 11:44:49.990 text-seek
. 2008-04-16 11:44:49.990 fs-multiple-roots-supported@vandyke.com
. 2008-04-16 11:44:49.990 space-available
. 2008-04-16 11:44:49.990 version-select
. 2008-04-16 11:44:49.990 vendor-id
. 2008-04-16 11:44:49.990 Access mask: 1F01FF, Open block masks: FFFFFFFF, Block masks: 0, Max read size: 32768
. 2008-04-16 11:44:49.990 Server software: VShell 3.0.3 (build 632 Unicode) (632) by VanDyke Software, Inc.
. 2008-04-16 11:44:49.990 SFTP versions supported by the server: 3,4,draft-ietf-secsh-filexfer-11@vandyke.com,partial-v6@vandyke.com
> 2008-04-16 11:44:49.990 Type: SSH_FXP_EXTENDED, Size: 61, Number: 1487560
. 2008-04-16 11:44:49.990 We will use UTF-8 strings when appropriate
. 2008-04-16 11:44:49.990 Getting current directory name.
. 2008-04-16 11:44:49.990 Getting real path for '.'
> 2008-04-16 11:44:49.990 Type: SSH_FXP_REALPATH, Size: 10, Number: 1487632
< 2008-04-16 11:44:49.990 Type: SSH_FXP_STATUS, Size: 57, Number: 1487560
. 2008-04-16 11:44:49.990 Discarding reserved response
< 2008-04-16 11:44:50.005 Type: SSH_FXP_NAME, Size: 19, Number: 1487632
. 2008-04-16 11:44:50.005 Real path is '/'
. 2008-04-16 11:44:50.005 Startup conversation with host finished.
. 2008-04-16 11:44:54.568 Collecting synchronization list for local directory '"D:\SYNC\WebPub' and remote directory '/D/WebPub', mode = 1, params = 5123
. 2008-04-16 11:44:54.568 Listing directory "/D/WebPub".
> 2008-04-16 11:44:54.568 Type: SSH_FXP_OPENDIR, Size: 19, Number: 1487883
< 2008-04-16 11:44:54.568 Type: SSH_FXP_HANDLE, Size: 13, Number: 1487883
> 2008-04-16 11:44:54.568 Type: SSH_FXP_READDIR, Size: 13, Number: 1488140
< 2008-04-16 11:44:54.584 Type: SSH_FXP_NAME, Size: 154, Number: 1488140
> 2008-04-16 11:44:54.584 Type: SSH_FXP_READDIR, Size: 13, Number: 1488396
< 2008-04-16 11:44:54.584 Type: SSH_FXP_STATUS, Size: 44, Number: 1488396
< 2008-04-16 11:44:54.584 Status/error code: 1
> 2008-04-16 11:44:54.584 Type: SSH_FXP_CLOSE, Size: 13, Number: 1488644
. 2008-04-16 11:44:54.584 Collecting synchronization list for local directory '"D:\SYNC\WebPub\WWW' and remote directory '/D/WebPub/WWW', mode = 1, params = 5123
. 2008-04-16 11:44:54.584 Listing directory "/D/WebPub/WWW".
> 2008-04-16 11:44:54.584 Type: SSH_FXP_OPENDIR, Size: 27, Number: 1488907
< 2008-04-16 11:44:54.584 Type: SSH_FXP_STATUS, Size: 34, Number: 1488644
. 2008-04-16 11:44:54.584 Discarding reserved response
< 2008-04-16 11:44:54.584 Type: SSH_FXP_HANDLE, Size: 13, Number: 1488907
> 2008-04-16 11:44:54.584 Type: SSH_FXP_READDIR, Size: 13, Number: 1489164
< 2008-04-16 11:44:54.584 Type: SSH_FXP_NAME, Size: 211, Number: 1489164
> 2008-04-16 11:44:54.584 Type: SSH_FXP_READDIR, Size: 13, Number: 1489420
< 2008-04-16 11:44:54.584 Type: SSH_FXP_STATUS, Size: 44, Number: 1489420
> 2008-04-16 11:44:54.584 Type: SSH_FXP_CLOSE, Size: 13, Number: 1489668
-----------EDIT------------------------
> 2008-04-16 11:45:10.974 Type: SSH_FXP_OPENDIR, Size: 53, Number: 2894603
< 2008-04-16 11:45:10.974 Type: SSH_FXP_STATUS, Size: 34, Number: 2894340
. 2008-04-16 11:45:10.974 Discarding reserved response
< 2008-04-16 11:45:10.974 Type: SSH_FXP_HANDLE, Size: 13, Number: 2894603
> 2008-04-16 11:45:10.974 Type: SSH_FXP_READDIR, Size: 13, Number: 2894860
< 2008-04-16 11:45:10.974 Type: SSH_FXP_NAME, Size: 102, Number: 2894860
> 2008-04-16 11:45:10.974 Type: SSH_FXP_READDIR, Size: 13, Number: 2895116
< 2008-04-16 11:45:10.974 Type: SSH_FXP_STATUS, Size: 44, Number: 2895116
< 2008-04-16 11:45:10.974 Status/error code: 1
> 2008-04-16 11:45:10.974 Type: SSH_FXP_CLOSE, Size: 13, Number: 2895364
. 2008-04-16 11:45:10.990 Synchronizing local directory '"D:\SYNC\WebPub\WWW\secure\MGRP\LOS\include\smarty\template_c\' with remote directory '/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/', params = 5123
. 2008-04-16 11:45:10.990 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%01^011^01174532%%form.tpl.php"
. 2008-04-16 11:45:10.990 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%01^011^01174532%%form.tpl.php" to local directory started.
. 2008-04-16 11:45:10.990 Ascii transfer mode selected.
. 2008-04-16 11:45:10.990 Opening remote file.
> 2008-04-16 11:45:10.990 Type: SSH_FXP_OPEN, Size: 114, Number: 2895619
< 2008-04-16 11:45:10.990 Type: SSH_FXP_STATUS, Size: 34, Number: 2895364
. 2008-04-16 11:45:10.990 Discarding reserved response
< 2008-04-16 11:45:10.990 Type: SSH_FXP_HANDLE, Size: 13, Number: 2895619
> 2008-04-16 11:45:10.990 Type: SSH_FXP_FSTAT, Size: 17, Number: 2895880
> 2008-04-16 11:45:10.990 Type: SSH_FXP_READ, Size: 25, Number: 2896133
< 2008-04-16 11:45:10.990 Type: SSH_FXP_ATTRS, Size: 58, Number: 2895880
. 2008-04-16 11:45:10.990 Storing reserved response
< 2008-04-16 11:45:10.990 Status/error code: 1
. 2008-04-16 11:45:10.990 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:45:10.990 Type: SSH_FXP_CLOSE, Size: 13, Number: 2896644
. 2008-04-16 11:45:10.990 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%08^082^082DDF17%%edit.tpl.php"
. 2008-04-16 11:45:10.990 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%08^082^082DDF17%%edit.tpl.php" to local directory started.
> 2008-04-16 11:45:10.990 Type: SSH_FXP_OPEN, Size: 114, Number: 2896899
< 2008-04-16 11:45:10.990 Type: SSH_FXP_STATUS, Size: 34, Number: 2896644
< 2008-04-16 11:45:10.990 Type: SSH_FXP_HANDLE, Size: 13, Number: 2896899
> 2008-04-16 11:45:10.990 Type: SSH_FXP_FSTAT, Size: 17, Number: 2897160
> 2008-04-16 11:45:10.990 Type: SSH_FXP_READ, Size: 25, Number: 2897413
< 2008-04-16 11:45:10.990 Type: SSH_FXP_ATTRS, Size: 58, Number: 2897160
> 2008-04-16 11:45:10.990 Type: SSH_FXP_CLOSE, Size: 13, Number: 2897924
. 2008-04-16 11:45:10.990 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%0E^0E4^0E407559%%footer.tpl.php"
. 2008-04-16 11:45:10.990 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%0E^0E4^0E407559%%footer.tpl.php" to local directory started.
. 2008-04-16 11:45:11.005 Opening remote file.
> 2008-04-16 11:45:11.005 Type: SSH_FXP_OPEN, Size: 116, Number: 2898179
< 2008-04-16 11:45:11.005 Type: SSH_FXP_STATUS, Size: 34, Number: 2897924
. 2008-04-16 11:45:11.005 Discarding reserved response
< 2008-04-16 11:45:11.005 Type: SSH_FXP_HANDLE, Size: 13, Number: 2898179
> 2008-04-16 11:45:11.005 Type: SSH_FXP_FSTAT, Size: 17, Number: 2898440
> 2008-04-16 11:45:11.005 Type: SSH_FXP_READ, Size: 25, Number: 2898693
< 2008-04-16 11:45:11.005 Type: SSH_FXP_ATTRS, Size: 58, Number: 2898440
. 2008-04-16 11:45:11.005 Storing reserved response
< 2008-04-16 11:45:11.005 Status/error code: 1
. 2008-04-16 11:45:11.005 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:45:11.005 Type: SSH_FXP_CLOSE, Size: 13, Number: 2899204
. 2008-04-16 11:45:11.005 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%1F^1F7^1F78B256%%breadcrumbs.tpl.php"
. 2008-04-16 11:45:11.005 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%1F^1F7^1F78B256%%breadcrumbs.tpl.php" to local directory started.
. 2008-04-16 11:45:11.005 Ascii transfer mode selected.
> 2008-04-16 11:45:11.005 Type: SSH_FXP_OPEN, Size: 121, Number: 2899459
< 2008-04-16 11:45:11.005 Type: SSH_FXP_STATUS, Size: 34, Number: 2899204
< 2008-04-16 11:45:11.005 Type: SSH_FXP_HANDLE, Size: 13, Number: 2899459
> 2008-04-16 11:45:11.005 Type: SSH_FXP_FSTAT, Size: 17, Number: 2899720
> 2008-04-16 11:45:11.005 Type: SSH_FXP_READ, Size: 25, Number: 2899973
< 2008-04-16 11:45:11.005 Type: SSH_FXP_ATTRS, Size: 58, Number: 2899720
> 2008-04-16 11:45:11.005 Type: SSH_FXP_CLOSE, Size: 13, Number: 2900484
. 2008-04-16 11:45:11.005 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%27^277^277B0EE4%%index.tpl.php"
. 2008-04-16 11:45:11.005 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%27^277^277B0EE4%%index.tpl.php" to local directory started.
> 2008-04-16 11:45:11.005 Type: SSH_FXP_OPEN, Size: 115, Number: 2900739
< 2008-04-16 11:45:11.021 Type: SSH_FXP_STATUS, Size: 34, Number: 2900484
. 2008-04-16 11:45:11.021 Discarding reserved response
< 2008-04-16 11:45:11.021 Type: SSH_FXP_HANDLE, Size: 13, Number: 2900739
> 2008-04-16 11:45:11.021 Type: SSH_FXP_FSTAT, Size: 17, Number: 2901000
> 2008-04-16 11:45:11.021 Type: SSH_FXP_READ, Size: 25, Number: 2901253
< 2008-04-16 11:45:11.021 Type: SSH_FXP_ATTRS, Size: 58, Number: 2901000
. 2008-04-16 11:45:11.021 Storing reserved response
< 2008-04-16 11:45:11.162 Status/error code: 1
. 2008-04-16 11:45:11.162 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2008-04-16 11:45:11.162 Type: SSH_FXP_CLOSE, Size: 13, Number: 2901764
. 2008-04-16 11:45:11.162 File: "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%39^39E^39E915E8%%index.tpl.php"
. 2008-04-16 11:45:11.162 Copying "/D/WebPub/WWW/secure/MGRP/LOS/include/smarty/template_c/%%39^39E^39E915E8%%index.tpl.php" to local directory started.
. 2008-04-16 11:45:11.162 Ascii transfer mode selected.
. 2008-04-16 11:45:11.162 Opening remote file.
> 2008-04-16 11:45:11.162 Type: SSH_FXP_OPEN, Size: 115, Number: 2902019
< 2008-04-16 11:45:11.162 Type: SSH_FXP_STATUS, Size: 34, Number: 2901764
. 2008-04-16 11:45:11.162 Discarding reserved response
< 2008-04-16 11:45:11.177 Type: SSH_FXP_HANDLE, Size: 13, Number: 2902019
> 2008-04-16 11:45:11.177 Type: SSH_FXP_FSTAT, Size: 17, Nu
Re: Command line 'Synch' copies files and then deletes them
The problem is caused by the percent sign in the files names. For WinSCP percent sign has special meaning. It is used to escape the characters that are not allowed in Windows filenames. Hence the percent sign itself must be escaped. However currently WinSCP is not able to take the escaping into account. This issue is being tracked already.
Workaround is to disable the escaping. See FAQ to learn how to disable it in script.
