Deleting files
Deleting files
I want to remove all files in a specific directory on a remote machine and I am using sftp. My code looks like :
cd load/loadIn
ls
pwd
rm *.*
and I got the following errormessage:
rm /load/loadIn/*.*: no such file or directory
I have also tried to change the last line to delete files ending with .ok by writing :
rm *.ok
rm /load/loadIn/*.ok: no such file or directory
So could anyone help me out to do this task ?
Regards
/Andreas
Re: Deleting files
SFTP protocol itself does not support wildcards, unless your client supports them. What client are you using? Why you do not try WinSCP?
Re: Deleting files
I have been told to use sftp by the client, because there are a lot of "secret" messages being sent over the net. The last step to be done is to delete the files on the remote machine that I have downloaded to the local one.
I know somehow that I have to do this recursively (i.e deleting the files), but I just dont know how ?
I have a batch-file calling the code above, but I dont know how to pass variables from it and receive them ?
Regards
/Andreas
Re: Deleting files
Well, use WinSCP :-), not sftp.
