Dutch (Nederlands)
Dutch (Nederlands)
This is the Dutch translation topic.
In dit onderwerp zijn alle opmerkingen/suggesties welkom omtrent de Nederlandse vertaling van WinSCP.
digibyte
Translator
Belgium
@Guest: Are you sure you use the latest version of the Dutch translation?
As far as I can see there's no wrong translation for "Disable".
I also don't see what you exactly mean with the other 2 suggestions. Can you be more specific? In which window did you see the wrong translation, ...
Thanks,
digibyte
Wouter
Sessie opslaan
Bij sessie opslaan staat een vakje om een vinkje te zetten om het wachtwoord te onthouden.
hierbij staat Paswoord maar dit moet natuurlijk Wachtwoord zijn.
EmmaVriezen
Translator
NL
Improving the translation
Dear reader,
I would like to contribute to the Dutch translation. While using WinSCP I have come across several grammatical errors (mainly 'dt-fouten') and other small mistakes. Also, some sentences overflow the given space, so I would like to look into that as well if that is appreciated.
With kind regards,
Emma
Nathan800
Translator
The Netherlands
Re: Improving the translation
Hi @EmmaVriezen,
Of course you can help with this, I really appreciate it. I have been responsible for Dutch translations for a few years now, but I have never been able to revise many translations from the past, as the set is simply too large for that.
How would you like to help? Would you like to take over or would you just like to point out some sentences that are wrong?
Best regards Nathan
EmmaVriezen
Translator
NL
Hi @Nathan800,
Thank you for your answer. I am glad to hear that it is appreciated!
For me it seems most convenient to make the updates myself, since there are more than just a few. If it is fine for me to take over the work, I would like to.
Kind regards, Emma
