Finnish
kuideon
finnish translation
hi,
can someone do this for latest release? because the one with the installer does NOT work.
is there a file that I can translate to finnish??
kuideon
finnish
ok,
I tryed it to 4.19 version... but it seems work only with beta
when are you including finnish in beta/new installation process?
Re: finnish
Finnish translation for 4.1.9 is included in installation package.
tpeland
Translator
Finland
Re: finnish
Just a quick note.
None of the translations in 4.1.9 or 4.1.7 work in Windows 7 64-bit. The same files work in Windows Vista 64-bit.
Winscp 4.2.3 translations do work in Windows 7.
Both are tested with a clean Windows 7 (enterprise 64-bit english) installation without any other programs.
At start of winscp:
File: 'C:\Users\atk-top\Desktop\WinSCP419\WinSCP.FI' does not contain translation for this product version.
Please remove the file. Otherwise the application will not work correctly.
<OK>
When trying to change language to Swedish:
File 'C:\Users\atk-top\Desktop\WinSCP419\WinSCP.SV' does not contain translation for this product version.
<OK> <Help>
Re: finnish
tpeland wrote:
Just a quick note.
Translations work on Windows 7 since 4.2.2 only. See tracker.
J.T.
Käännöskukkanen
Hienoa, että ohjelma on käännetty suomeksi :wink:
Voisitteko kuitenkin korjata käännöksen "Lähtetetään" kuten se oikeasti suomeksi kírjoitetaan; "Lähetetään".
tpeland
Translator
Finland
Re: Käännöskukkanen
Typo korjattu käännökseen.
Voit joko odottaa seuraavaa winscp:n versiota tai ladata uuden
käännöksen sivulta https://winscp.net/eng/translations.php
6sto
Translator
Finland
I would like to translate
Hi.
I would like to participate and translate WinSCP in Finnish. :!:
Re: I would like to translate
Thanks for your offer. Let me contact the current translator first. I'll come back to you.
6sto
Translator
Re: Käännöskukkanen
Morjensta. Tämä on nyt ilmoitettu ettenpäin ja korjaus tullee seuraavaan versioon. Kiitos ilmoituksesta!
Re: Translation
eem wrote:
I want to help you with translating into Finnish.
Thanks for your offer. Though we have a reliable Finnish translator and the Finish translation is complete.
