Swedish
Sara
country specific password
Hello, do I need the country specific plugin in order to use country specific characters in the login password?
Kind Regards
Sara
Re: country specific password
Generally no. Though the answer is more complicated. Are you having some problem? What protocol?
Hello, thank you for your answer.
Yes, if I use a password containing the Swedish characters å,ä,ö
connection is refused. I have checked that the password is set correctly on the server.
Still, it could be a server side issue?
Again, what protocol?
farrington
Skövde, Sweden
If anybody wonder about the answer to Swedish characters in passwords, check out this topic:
https://winscp.net/forum/viewtopic.php?t=8265
(Swedish)
Och för att ta det på svenska, om någon undrar så fungerar det inte alls att använda svenska tecken i lösenorden. Bugg i WinSCP, men man jobbar på det... men problemet är inte helt lätt att lösa vad jag förstår det som. Se tråden jag länkade till ovan.
