HELP :( "Invalid access to memory"
sexy_chick
I used to ssh my iphone without any problems, until I restored my iphone and tried to ssh again, but it gave me a notification saying: "invalid access to memory" and when I press more it says: "authentication failed". I was using version 404. so I then istalled 407 but still same problem, and also tried version 410 and still same problem also.
th file protocol was sftp and the allow scp fallback was checked!! I even tried to change the file protocol to scp and ftp, but no luck!!
what can I do??? is this a problem with winscp program or my iphone??? please help :(
Re: HELP :( "Invalid access to memory"
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find it (if you log in) in my forum profile. Thanks.
aberdeen61
I'm also getting the "Invalid access to memory" error. I'm getting it on every server I try when first starting up (all linux servers). However, if I select the same connection from the New Session menu, I don't get the error.
It happens both when SCP or SFTP are the selected protocol.
I'm using winscp 4.1.0 build 375 on Windows XP SP2.
jrynd
New York
The tracker has it marked Fixed in 4.1.1, but that doesn't help me as 4.1.1 is not available for download.
