EStackOverflow, Invalid Access to Memory, EAccessViolation
GrATeFuL^DeAD
I get all of this when I try to upload a file to my FTP. It only happens on the larger files. When i start it says EStackOverflow, press ok, then says Ivalid Access to memory a few time before finished, i press ok each time, Then at the end it says EAccessViolation.
Im new to WinSCP so take that into consideration.
THANKS!
Re: EStackOverflow, Invalid Access to Memory, EAccessViolation
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find it (if you log in) in my forum profile. Thanks.
chasba wrote:
I am also seeing this problem (with version 4.1.0 (Build 375)).
Good. So can I get your address?
chasba
I have sent you an email to your private address found on your website as I didn't find any on your profile page (even tho I'm logged in).
If you haven't received anything, let me know.
Tongka
I found this problem on WinSCP 4.3.2
as title ,
the problem still occur in the latest version of Winscp
any idea ?
Re: I found this problem on WinSCP 4.3.2
