- vartaxe
- 23
- Portugal
Winrar Drag&Drop Support
i would love to drag&drop files directly from a *.rar archive to winscp :D
Site Admin -
- 42,963
- Prague, Czechia
Re: Winrar Drag&Drop Support
It does work, doesn't it?
no :( i can't drag files from within a winrar archive using winrar 3.71... also is there no way to do auto refresh? also i would love a feature to search through ftp :mrgreen:
Site Admin -
- 42,963
- Prague, Czechia
It works for me (with winrar 3.70). Where do you exactly drag the files from? And where do you drop them to? What happens once your drop? What version of WinSCP and Windows are you using?no :( i can't drag files from within a winrar archive using winrar 3.71...
This issue is being tracked already.lso is there no way to do auto refresh?
This issue is also being tracked already.also i would love a feature to search through ftp :mrgreen:
win xp pro sp2 x86, winrar 3.71, winscp 4.0.7
<invalid hyperlink removed by admin> (<invalid hyperlink removed by admin>)
to get this done i have to extract the files to a folder and then from explorer drag and drop it...
Site Admin -
- 42,963
- Prague, Czechia
Are you able to drag to windows explorer (desktop)?
WinRAR uses the same mechanism to allow drag&drop to other application as WinSCP does (see documentation). Hence you need to have the RarExt.dll shell extension installed and loaded. Maybe you have not installed/registered it. Or you have not restarted your computer yet since installation.
i can drag from winscp to desktop and from winrar to desktop too! (desktop = windows explorer)
so it's kinda weird what's happening here :mrgreen:
Site Admin -
Sorry, I do not know how to help you :-(
- vartaxe
- 23
- Portugal
a few minutes ago i downoaded the latest winscp here in a pc from a friend and it won't drag&drop with winrar just like it happens to me at home weird.
i will now try on another pc running vista...
also to bad winscp don't autorefresh... like when im working on a ftp folder and someone else add files there too i won't see them until i refresh every folder...
Site Admin -
I have fixed bug related to drag&drop on Vista recently. Maybe it is related to your problem...
PeterMoon
Use SmartFTP
Hello
You can use SmartFTP to do this task. It works with WinRAR.
https://www.smartftp.com/
Best Regards,
Peter
Best Regards,
Peter
- ozzytheking
- 35
- TURKEY
winscp to 7-zip and winrar, drag & drop works
Drag and drop from Winscp to 7-zip v4.65 and Winrar v3.70 works as it should. If there is a problem, it is not about Winscp.
My
OS: Vista x86
Winscp: 4.2.4 beta
My
OS: Vista x86
Winscp: 4.2.4 beta
Justin Schmidt
drag and drop now disabled since I downloaded winRar
If anyone knows how to help me fix this problem I'd be most appreciative to hear your advice. Ever since I installed WinRar on my computer to be able to some recently purchased video clips I have no longer been able to drag files around on my desktop or within any programs. I can still move around open windows once I click on files, but I can no longer move around items on my desktop, or much worse, I can no longer move around audio files with my music production software. Big problem. Any advice is most appreciated. I have already tried removing WinRAR and it didn't help. Please reply to williamwolfgangschmidt@gmail.com if you have any advice
- vartaxe
- 23
- Portugal
just wanted to say i still have this issue :?
just installed winscp in a another laptop from a friend a it's exactly the same problem :cry:
it's just weird i can't get this to work... winscp fault or winrar fault i don't lnow but every pc i try it's the same problem... with xp vista seven 32 or 64 bits... stable winrar beta version... ive tested everything
- vartaxe
- 23
- Portugal
i got a response from eugene/winrar dev team
btw i had to edit the quote cause i couldn't post it as it should be. the forum replied with can't use "/\nal*" but the word "/\nalyze" doesn't have anything todo with that...
hope this may help further investigation
> then there is something very annoying i actively use winscp as a
> ftp client when i drag and drop from winscp to desktop everything
> goes fine and from desktop to winscp too but when i open a archive
> with winrar and select a few files and drag and drop them to winscp
> it won't happen anything...
Now I tried to find a reason of this problem and failed to do it. DoDragDrop just returns DRAGDROP_S_CANCEL, which means that drag and drop operation is cancelled. WinRAR drag and drop works well with all other programs, which I tested. It may require to /\nalyze a lot of WinScp source code to find out the reason of problem. Maybe we'll do it sometimes, though I am not sure about it now. Sorry.
Site Admin -
I have sent you an email with request for contact to Eugene/WinRar dev team.i got a response from eugene/winrar dev team...
dev@rarlab.com
Site Admin -
Thank. But can you forward the email you've quoted, so I can follow it?
done
Site Admin -
Thanks. I've received email from Eugene already.
tebs
drag and drop bug
hi,
i have been having this issue for a while and would like your help.
everytime I open a winrar file saved in a folder, say folder A, and drag and drop the file to any folder, say folder B, as a shortcut for extracting, all the other contents of folder A including the contents of the winrar file gets 'extracted' to folder B. so if the winrar file is saved in a temp folder and i drag and drop the contents to any folder as a way of extracting it, the entire temp folder contents gets copied to that said folder. someone might have the same problem as me and i really need to have this fixed. thanks.
Site Admin -
- 42,963
- Prague, Czechia
Re: drag and drop bug
I do not see a relation to WinSCP.everytime I open a winrar file saved in a folder, say folder A, and drag and drop the file to any folder, say folder B, as a shortcut for extracting, all the other contents of folder A including the contents of the winrar file gets 'extracted' to folder B. so if the winrar file is saved in a temp folder and i drag and drop the contents to any folder as a way of extracting it, the entire temp folder contents gets copied to that said folder. someone might have the same problem as me and i really need to have this fixed. thanks.
