Tunnel with automatic local port breaks x-server
Zum
While WinSCP is running a tunnel connection, any local application (eg. xterm) trying to connect to the local x-server (eg. XWin) will crash. This is because WinSCP "steals" the local port 6000 (on 127.0.0.1) which is in use by the x-server (on 0.0.0.0).
Re: Tunnel with automatic local port breaks x-server
OK, it was bad choice. I'll change the defaults. This issue has been added to tracker.
Anyway, you can choose any other port manually on Tunnel tab of Login dialog.
