Copy/Paste feature to Remote Directory Panel
At the moment there is a possibility to copy files using drag and drop technology. Copy path can also include the UNC path. However, there is no possibility to copy the file using Copy/Paste commands from the shortcut menu (same way as you do in Windows Explorer - through the clipboard mechanism). However, I believe using Copy/Paste commands is much more convenient than drag-and-drop and therefore request this feature to be added.
Re: Re: Copy/Paste feature to Remote Directory Panel
Please look picture from zip
