not just scp,sftp ... why not use the tool for explorer (alternative)
FORESTHUS
:lol: :roll: :?:
Re: not just scp,sftp ... why not use the tool for explorer (alternative)
Sorry, but I do not understand what you mean :oops:
FORESTHUS
well I meant if it possible to have 2 windows in your tool with 2 diff paths on the windows-pc. or even if it possible 2 get 2 connections of sftp.
that would be real cool.
:wink: :lol:
You may open second instance of WinSCP. Anyway next version will enable you to open as many connections you need and select between them.
zabak
I understand what he meant: WinSCP might be a great tool to replace FAR or Total Commander if we were able to use two local sessions instead of one local and one remote - same as Far with WinSCP plug-in.
