List of devices cleared.
fault1
Hi everyone, I new in this forum and I would like to you can help me.
The situation is:
I have installed WinSCP on my XP machine, but for some reason my list of devices disappear, after map my drive and the run from a remote machine WinSCP.exe. I tried to find the solution without luck..
Thanks for any help.
Re: List of devices cleared.
What list of devices? Where do you run the WinSCP? From your XP machine or from remote machine? It is not clear.
