Limited Logging
Babbage
Limited Logging
Is there any way to only log certain information?
Im running a /script in a command line, and basically im after just the equivalent output you see in the /console being put into a file.
/log has waaaay to much information in it :) As the console pops up in a seperate window to my command line I cant redirect the output to a file.
Any ideas? (Or a way to reduce the categories logged by the /log option?)
many thanks
Re: Limited Logging
This issue is being tracked already.
Use winscp.com.
