Date mismatch on download
rakella
When a file is downloaded the time stamp on the downloaded is set back to 12/20/1899 at 12:00 AM. Verified all settings to be fine. The date and time are completely missing when I look at the file properties using Windows explorer.
Re: Date mismatch on download
What protocol are you using? Can you post how local directory listing looks like (using dir command in windows shell). Also sample of remote directory may be useful.
Protocol SSH
Directory of folder
12/30/1899  12:00 AM           713,934 filename.ext
               1 File(s)        713,934 bytes
               0 Dir(s)  131,710,103,552 bytes free
