Host does not exist - cannot find the reason for this error.
rysiekmus
Manchester UK
I am very familiar with sftp on my UNIX boxes. I have a fully working environment, so an SSH daemon running. I can connect to my remote server from all my UNIX boxes.
I went through all the documents, FAQ's, searched google and I still have this problem.
I have a Windows PC, I can connect manually using the syntax (my server name is "myserver"):
c:\home\sftp>winscp sftp:@myserver
Searching for host...
Connecting to host...
Authenticating...
'myserver' session username: suprd_ho
'myserver' session password:
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] myserver
No problem at all, I can connect and send files.
I tried to run a batch:
winscp.com /console script=test.txt mylogin@myserver
winscp.com sftp /console script=test.txt suprd_ho@myserver
I am not running this from the scheduler, just the same command prompt (Windows XP) and the same windows session.
I tried the fully qualified server name and IP address and I cannot connect, here is my attempt:
c:\home\sftp>winscp.com /console script=test.txt suprd_ho@myserver
Host does not exist
I also created the public/private key and transferred it to my remote server. Still the same.
This is my batch:
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect using a password
# open user:password@example.com
# Change remote directory
cd /tmp
# Force binary mode transfer
# option transfer binary
put text.txt
# Disconnect
close
# Exit WinSCP
What am I doing wrong?
Regards,
Richard
PS. This WinSCP is really nice, and very good documentation, I must admit, great job done :)
Re: Host does not exist - cannot find the reason for this error.
It is strange.
What if you try:
c:\home\sftp>winscp sftp://suprd_ho@myserver
rysiekmus
Manchester UK
No Prikryl,
unfortunately still the same:
C:\home\sftp>winscp.com /console script=sftp_script.txt sftp://suprd_ho@myserver
Host does not exist
Maybe I am doing something wrong with the passphraze files, so I will check again during the day.
Thanks for the hint.
Regards,
Richard
So this works:
and this not?
It cannot be anything with passphrase as you do not even establish connection to the host.
rysiekmus
Manchester UK
I think I have a problem connecting to my SSH server, so I will have to find out that first. Probably that's where the problem is.
I will keep the thread updated.
Thanks,
Richard
