integrate complete putty...
Asterix
I like to use one app for all ... ssh & scp.
could you integrate a greater command line tool such like putty it self.
thanks for the nice app. it is the best scp-client Ive ever seen.
Asterix :D
guest
Re: integrate complete putty...
Asterix :D
this is "sorta" implimented with the command line option, though take that up a notch ALLOWING commands that want feedback, so i dont have to switch between putty and winscp for creating a .tar.gz of my site, and then downloading it for a backup in winscp
this would be sweet
It is not possible to allow commend with user feedback in WinSCP session. The protocol does not allows this.
