Invalid access to memory. Authentication failed.
Re: Invalid access to memory. Authentication failed.
Can you provide me you email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find it in my forum profile (if you log in). Thanks.
mrclay
I also get this
I also get this when I should be prompted for my password. In my situation I *want* WinSCP to prompt for the password but it won't. This is what I get:
Authenticating...
Using username "sclay".
This happens using the "open" command in script or specifying the URL on the command line. Identical error.
Re: I also get this
What version of WinSCP are you using? Have you tried the latest one? If you have, please provide me your email address as mentioned in my previous post.
