unix -> windows text transfer dropping embedded Ctrl-M
alfp
The University of Melbourne
When transferring a text file which contained an embedded Ctrl-M character not associated with any line terminator from unix to windows with SFTP protocol, the Ctrl-M character gets dropped. This does not occur when doing a text transfer on a similar file from windows to unix. I would have expected that Ctrl-M characters would only be stripped in a text transfer if associated with a line terminator, and then only for a transfer from windows to unix. Is this expected behaviour or is this a bug?
I am using WinSCP 4.0.6 (build 358) which I believe is the latest. I cannot verify if this also happens with FTP protocol as our unix hosts only accept SFTP connections.
ransue
Re: unix -> windows text transfer dropping embedded Ctrl-M
This has been fixed already. See tracker entry.
I get a "You do not have permission to access this document." from that page. Can you explain how to set up so ^Ms are not showing up on the unix side? I am on version 4.0.3 Build 345
Thx
mikew
This has been fixed in 4.1 beta.
This is still happening for me. version 4.1.7
alfp
I have just re-tested my original case with SFTP protocol using both versions 4.1.6 & 4.1.7, and the Ctrl-M is not being dropped. Which protocol are you using?
Alf.
Devendra Narvariya
CTRL+M char issue, WINSCP 4.3.5
When I transfer any file from windows to my AIX server CTRL+M character is displayed in every editable file when opened with VI editor. ALso such file do not get executed because of presence of this character, why CTRl+M character pops up while transferring the file. Is there any reason for this or its just a BUG.
Re: CTRL+M char issue, WINSCP 4.3.5
Is the character present in the source file? Depending on that, do you want WinSCP to transfer file intact (i.e. you believe WinSCP is adding the character [this is unlikely])? Or do you want WinSCP to strip the character when uploading? For that see:
https://winscp.net/eng/docs/transfer_mode
Devendra Narvariya
I checked the files on Windows XP with various editors but CTRL+M character is not shown. But after file transfer those CTRL+M character appears when I use VI editor.
Regards
Devendra Narvariya
Have you tried some binary viewer?
Devendra Narvariya
No. The editors I tried on Windows XP were Notepad,Notepad++,Windows 2003 office, WordPad.
nooneinparticular
script to remove control M from files that Windows editors add to the end of every line
#!/bin/ksh
if [ "$1" = "" ]
then echo ""
echo "Parm 1 FileName (required)"
echo ""
return
else FileName="$1"
fi
cat ${FileName} | sed 's/.$//g' > ${FileName}.txt
chmod 770 ${FileName}.txt
mv ${FileName}.txt ${FileName}
