Gobbelix
WinSCP for Linux
Site Admin -
- 43,224
- Prague, Czechia
Re: WinSCP for Linux
Gobbelix
Site Admin -
snowman
Krusader
In Linux I use Krusader which works great
Site Admin -
Issue 161 – Linux version
Willem
SecPanel
I had trouble to run WinSCP under Wine, but disabling netapi32.dll got it to work.
- Guest
- Guest
In my opinion, Wine compatibility is a kind of quality certification of Windows application versions – and of course, WinSCP is there! :-)
jspash
Donor - Joined:
- 1
- London, England
This application is so useful to me and my day job, that I keep a virtual machine with XP on it for the sole purpose of running WinSCP! Thanks so much for a great app.
- Guest
Re: SecPanel
Belisarius
How: In Konqueror where current directory is listed type:
fish://{username}@{server-name}/{path-on-remote-server}-
Belisarius
I meant to add my thanks for WinSCP to my comments above. I have used your program for several years and it has made my work easier.
Thanks again!
Sujan
WinSCP like...
Just go to tools addons, search --> FireFTP --> Install and then enjoy.
This can be a good alternative to excellent software in WinSCP.
- Guest
syddel
WinSCP alternative in Linux
- If the address bar is not showing, press the icon that looks like a pencil and piece of paper. This will display the address bar (editable textbox).
- In the address bar, enter:
sftp://server.comorsftp://ip_address.
- Enter your username and password.
- rec9140
- 5
Native Linux, YES, please, wine, red yes, other no thanks.
This would make life a lot better.
No thanks, on running on Wine as I don't allow WinAPI on SECURE Linux OS. May as well run Win and invite the virus and other crap to tag along. No thanks.
asb
Migrating users to Ubuntu
I'm the IT guy for a small office on a univ. campus – supporting two dozen Wintel users who have used a Samba fileserver for years, since before my time, and are very comfortable with WinSCP for remote access to their shared filesystem using home PCs. (This says quite a bit for the quality of WinSCP, by the way.) I have a good chance of introducing some of them to Ubuntu using some old laptops – if I can give them a WinSCP-like GUI for SCP access to the fileserver, hopefully including drag & drop file actions. I don't think anything that's been mentioned is really able to come up to the level of WinSCP in terms of ease of use – I haven't tried some of these in years, and will do so again, but I'd like to encourage you to think about this a bit. A LinSCP is not a ridiculous idea, exactly because WinSCP is so successful. Doesn't have to be identical or complete, just close enough to be familiar – someday I might paste something up with Python if there isn't already a good alternative.
Alex Brown <Alexander_Brown at uml dot edu >
phibes
WinSCP's feature set just doesn't have a Lin quivalent
remote file editing using gvim (or another editor)
- yes, I know I can do this using existing tools, but they are not as responsive
- nautilus is slow, as is gvim's grafted in editing via scp
- neither of the above is as forgiving when network connections drop.
- I like being able to right click on a file and run a custom shell script.
I rarely use the synchro feature in WinSCP, but when I do, it's nice to have.
And, yeah, if I wanted to use the command line, I could, and I do often. However, that's not always what I want out of life.
WinSCP is simply better than the Lin graphical SCP/SFTP clients.
- Guest
FileZilla
Greetings,
Michael
kcn_viper
Winscp works with Wine OR use sshfs-fuse
More timetaking but better solution: install sshfs-fuse
What I did to install?
Get fuse-2.7.4.tar.gz and sshfs-fuse-2.2.tar.gz.
Tried installing sshfs-fuse directly, gave the error: "C compiler cannot create executables"
Installed g++ to remove above error:
sudo apt-get install g++
Installed fuse.
Installed libglib2.0-dev for the other two package requirements as above:
sudo apt-get install libglib2.0-dev
sudo sshfs user@host: local_folder -o allow_otherAdvertisement
- Guest
Please port it to LINUX
Deliveri
Guest2
Does someone have a good suggestion for a WinSCP look-a-like for Gnome?
Jaroslav K.
Why don't use mc (midnight commander)?
mc is good for that (uses fish protocol).
If you need that: Right (or Left) -> Shell link...
Problem is only with custom ssh port. You can:
- use a fix (have not tried it): https://github.com/MidnightCommander/mc/issues/118
- or add ssh alias in
~/.ssh/config(or/etc/ssh/ssh_config).
Host mymachinealias Hostname mymachine.lt Port 9022 HostKeyAlias mymachinealias
UBUNTU
UBUNTU
dood
reply
Problem is I lost a lot of my data my like Windows 7 and the WinSCP installed folder
and since I can't install it on Wine I can't use it anymore so what I need is a copy of the folder that's created by installing WinSCP on Windows.
PachoV
- Connect through SSH tunnel
- Private key authentication (both for the SSH tunnel and the Session)
Thank you!
PachoV
DUKA
winscp on ubuntu
WinSCP, right click on WinSCP.exe SCRIPT>RUN>GUI App-as root. And is running. I didn't mentioned that I have Wine on my pc
BR
Duka
p.s.
sorry for my bad english
someone
come on
DILIP
krusader can do it !
fish://<user>@<server>:<path> in the address bar. ENJOY!
-Dilip
guestlz
zCarver
a port for linux
it's a quite old topic... but anyway.
Tools like winscp or putty are so good because of Windows OS.
This does not mean Windows is a superior OS. It means, that windows badly lack
of good admin tools and also lack of good admins.
And it's very standardized (users "know" a whatever program should look like a windows app).
Ok, so there's obviously absolutly no need for winscp or putty running on Linux.
Because everything is already here in all distros. But sometimes just in command lines.
Want a ssh session? Just type ssh.
The "problem" comes with GUI front end or gui apps. Because there's so much choice...
What is the good one? You are free to decide.
The argument... "I do not switch because of Photoshop or games or music progams" is understandable... "I do not switch because of winscp" sounds crazy. Just a lack of knowledge or too much lazyness.
I mean WinSCP is a very good app for windows. A perfectly redondant useless app for Linux.
So... the thing about wine and secure. A lack of understanding of both what is linux security and what is WINE.
And about the port.
It can be ported in less than one day without any problem. All libraries are here but VCL wich is ex borland / ex inprise / Codegear. But it's just a question of visuals.
Qt looks like VCL.
Anyway, there's a RAD called LAZARUS, and it can use Borland / whatever.dfm (forms files). It also have a very rich VCL like component palette with a very good compatibility. Porting from C++ to O.O. pascal is straight forward. And i ask my self if the last RAD from CodeGear (XE3 i think) can not compile directly for the linux target. (mac os and i-device i'm sure).
The point is... Why the hell? Another SSH/sftp and so on client? Who really cares in the real linux world.
This program is great because it gives windows users what linux users have for eons.
Keep it running on Windows or browse internet for a client that meets your needs on linux.
Good work anyway.
pha3z
So ??
What is the good one? You are free to decide. "
You talk a good game but you didn't list anything. You just waved your hands around.
So the epic thing that everyone knows rocks about WinSCP is that you can easily browse to any folder and double click a file and the file will load into your editor of choice based on extension masking. It also runs VERY fast with a low memory footprint.
Can you please direct us to the equivalent Linux tool that is very fast and makes client-side file editing a snap? Something that doesn't require you to click any prompt dialog boxes when you save back to the server. It should be seamless just like WinSCP client-side editing.
Obviously, evangelism is necessary. If you've got a rock solid suggestion to evangelize on Linux, then do it. Look at FileZilla for instance. Everyone evangelizes that tool and so everyone else uses it. Sad fact is that FileZilla is garbage for anyone who wants a streamlined way to edit server-side files locally. It just goes to show that its all in your ability to direct people to the tools.
NABA
run WinSCP under Linux
To run WinSCP under Linux (Ubuntu 12.04), follow these steps:
sudo apt-get install wine(run this one time only, to getwinein your system, if you haven't it)
- download "Portable executable" from https://winscp.net/eng/download.php
- make a folder and put the content of zip file in this folder
- open a terminal
- type
sudo su
- type
wine WinSCP.exe
Best regards.
pramil
Re: Krusader
oldunixguy
winscp on linux IS important
First, it pairs very well with putty. putty is very good for many reasons. But the most important to me is the fabulous support of digital certificates. I support MANY remote linux systems and we only allow remote access with digital certificates and NOT usernames/passwords.
winscp besides having a very good view of both local and remote files supports the same digital certificates one uses in putty! This makes configuring winscp very easy when using certificates.
Many of the other posters here missed this most important feature. For example, filezilla is a pain in the backside to try and use it for digital certs. I stopped using it on windows LONG ago in leiu of winscp. I will not use it on linux for the same reasons.
So there are no good equivalents of winscp on linux. that is why we need a linux port.
oldunixguy
- Guest
Re: run WinSCP under Linux
There has to be a simple trick to overcome this...?Wine: cannot find L"C\\windows\\system32\\WinSCP.exe
Any help will be apreciated.
- Guest
harry8227
Luis Veiga
WinSCP Linux
then create the winscp.desktop file in the folder and add the following content:
[Desktop Entry] Version = 1.0 Encoding = UTF-8 Name = WinSCP Type = Application Exec = wine / folder path winscp / WinSCP.exe Terminal = false Icon = // folder path winscp / icon.png Comment = WinSCP Categories = Applications; StartupNotify = true
/usr/share/applications/
give the permission to the file and just execute it
saud
Donor -
- 13
- Earth
Eduard
Donor - Joined:
- 2
I haven't done anything with it, but it got my attention because I have also worked on Delphi VCL projects in my life, apart from being primarily a C# .NET developer (and also a big Linux fan these days).
Might it be possible to port WinSCP to that?
Site Admin -
TCB13
Donor -
- 2
Thank you.
Site Admin -
Though, it's not about money (only). We do not have experience and capacity to build and maintain a Linux version.
TCB13
Donor -
Meanwhile WinSCP is indeed a very well coded tool, totally worth it.
victor10us
- Guest
- Guest
- Freitag
- 80
I found this tutorial on setting that up
https://github.com/JavaScriptDude/WinSCP_On_Wine
- fatop
- 3
Runs perfectly on Wine for me
A bit of LLM help and you I could setup SSH authentication and custom editor too
for custom editor on edit files, use this command:
C:\windows\command\start.exe /Unix /home/YOUR_USERNAME/.wine/launch_editor.sh !.!
#!/bin/bash # Convert the Windows path (assuming it starts with something like 'C:\') unix_path=$(echo "$1" | sed -e 's/\\/\//g' -e 's/^C://') # Launch gedit with the converted path /opt/sublime_text/sublime_text "/home/YOUR_USERNAME/.wine/drive_c$unix_path" &
#!/bin/bash # Convert the Windows path (assuming it starts with something like 'C:\') unix_path=$(echo "$1" | sed -e 's/\\/\//g' -e 's/^C://') # Launch zeditor "/home/YOUR_USERNAME/.wine/drive_c$unix_path" &
for ssh authentication:
in the SSH > Authentication for a server set private key file to
Z:\home\YOUR_USERNAME\.ssh\putty.ppk
then install PuTTY via your package manager and inside your
.ssh dir do this with your key
puttygen id_rsa -o putty.ppk
The only issue you might have is that it will not behave nicely with "stealing" focus when you open file via WinSCP (normally the icon of your editor would start blinking), but if you install something that lets apps take focus it works fine. For example, on Gnome you could get https://extensions.gnome.org/extension/3843/just-perfection/ extension, or https://extensions.gnome.org/extension/5410/grand-theft-focus/. What's annoying about WinSCP itself though is that it will popup notification on every server disconnect, so you have to
Alt+Tab from that (seriously, that popup was never helpful win Windows neither, I have no idea why is it a popup). But there's already voting for making this configurable so let's hope that one day it will get implemented Issue 2360 – Optionally do not show error message when connection is lost while idle.
By the way now that Linux is going more and more into mainstream since latest Windows is a privacy nightmare I expect more and more people asking for Linux native version lol.
Site Admin -
Re: Runs perfectly on Wine for me
tetra
Donor - Joined:
- 3
- Buffalo, USA
Re: come on
https://winscp.net/eng/donate.phpdo some work and get this coded for linux systems so we can use it under gnome
man's gotta eat! cough up or shut up.
Site Admin -
AFSAR BASHA
Need WinSCP
- skjerns
- 1
snap install winscpHope that makes things easier.
Site Admin -
99ecarvalho
magix01
nixscp.com
