WinSCP will not transfer files with a "$" in the name
Jeff
Is it a bug that WinSCP can not transfer files with a $ in the name of the file?
Is there a workaround for this?
Jeff
Re: WinSCP will not transfer files with a "$" in the name
I works for me, both with SCP and SFTP. Can you post a log file? Do you use SFTP or SCP? If you use SCP, do you have BASH shell?
