copy failure with "<" char in the filename.
AndrewD
Following filename sample fails to copy
"711407-<WORKING"
since I'm not under control of the filename convention generated by some idiots :evil:, these unusial char's are being used all over the place in filenames.
Would be nice if WinSCP would support the copy any filename string.
WinSCP Version currently in use : 3.1.0 (build 165)
Re: copy failure with "<" char in the filename.
Next version of WinSCP will have option to replace all characters invalid in Windows file names with underscore.
