Keyboard-interactive Prompt truncated. How to view it full?
CV
Hi
How does one view the full prompt during Keyboard-interactive login? There was apparently a button before for Full prompt which doesn't seem to exist anymore. Any alternative ways?
Thanks in advance,
Chet Vora
Re: Keyboard-interactive Prompt truncated. How to view it full?
What version of WinSCP are you using? Can you send a screenshot of the prompt? Or even better can I have a test account on the server? Probably only address may help, as I guess I should be able to see the prompt even without account.
Hi
I'm using WinSCP 4.0.3 (build 345).
I have send you the prompt in a separate email. This is basically the prompt issued by our own server which provides an interactive menu to the user to choose from.
Thanks for your help,
CV
