Select Network Interface
tony
Is it possible to select which Network Interface WinSCP will use on the client computer when there are more than one Network Interfaces available?
tony
Thank you for the quick response.
Would this be something that could be added to the wish list?
We have two connections to the INTERNET and would like to select which interface to use while running in stand-a-lone mode.
Thank you for your consideration.
