synchronizing within my computer
defernex
Hi-
I was wondering if it is possible to use WinSCP to synchronize directories within the same computer (e.g., from C: to E:). I tried but couldn't figure out how to open a session between the two directories (I don't know what to put as "host name" to open E:).
Thank you in advance for your help!
Tommaso
Re: synchronizing within my computer
WinSCP cannot work as a filemanager (having local directory in both panels). Of course, if you install local SSH/SFTP server, you can synchronize through it. However I think you should better use any filemanager for that.
