Some files are invisible in WinSCP
_MMX_
Some files, that are visible by "ls -la" command are invisible in WinSCP.
I am logging in as "root" and switching to "/u01/dms-tek-backup" in WinSCP. I can see filses there. But i can see not all of the files. I can't see 2 of them-
-rw-r--r-- 1 oracle dba 9205596274 Dec 24 21:35 db.dms.backup.20071224.dmp.Z
-rw-r--r-- 1 oracle dba 9215776129 Dec 25 21:35 db.dms.backup.20071225.dmp.Z
Then I start console from WinSCP, logging in as "root" and run the following commands:
/u01/dms-tek-backup$ id
uid=0(root) gid=1(other)
/u01/dms-tek-backup$ ls -la
total 36852090
drwxrwxrwx 3 isida isida 1024 Dec 25 22:11 .
drwxrwxrwx 10 isida isida 512 Nov 8 2006 ..
drwxr-xr-x 3 oracle dba 512 Dec 24 18:02 backup-2007-12-21
-rw------- 1 oracle dba 1524196 Dec 18 14:43 core
-rw-r--r-- 1 oracle dba 0 Aug 3 2005 d.log
-rw-r--r-- 1 oracle dba 32827094 Dec 25 22:11 db.backup.err.log
-rw-r--r-- 1 oracle dba 28997827 Oct 11 2006 db.backup.err.log.old
-rw-r--r-- 1 oracle dba 66792 Dec 25 21:35 db.backup.log
-rw-r--r-- 1 oracle dba 0 Aug 8 2005 db.backup.stout.log
-rw-r--r-- 1 isida isida 63771136 Oct 1 02:00 isidalog_01.10.07.tar
-rw-r--r-- 1 isida isida 62493184 Sep 8 02:01 isidalog_08.09.07.tar
-rw-r--r-- 1 isida isida 83539456 Dec 15 02:02 isidalog_15.12.07.tar
-rw-r--r-- 1 isida isida 80908288 Nov 22 02:02 isidalog_22.11.07.tar
-rw-r--r-- 1 isida isida 83411456 Oct 29 02:01 isidalog_29.10.07.tar
Here I can see all the files. Why 2 files are invisible in NortonCommander mode? I use WinSCP 4.0.5 build 354.
_MMX_
Server and protocol information:
Session protocol = SSH-2
SSH implementation = OpenSSH_2.9p2
Encryption algorithm = aes
Compression = No
File transfer protocol = SFTP-3
Server host key fingerprint
ssh-rsa 1024 xxxxxxxxxxxxxxxxxxxxxxxx
Can change permissions = Yes
Can change owner/group = No
Can execute arbitrary command = No
Can create symlink/hardlink = Yes/No
Can lookup user groups = No
Can duplicate remote files = No
Can check available space = No
Can calculate file checksum = No
Native text (ASCII) mode transfers = No
Additional information
The server does not support any SFTP extension.
_MMX_
Here is the log (Debug1) where I am logging in, switching to "/u01/dms-tek-backup" and disconnecting from server.
. 2008-01-14 18:14:42.345 --------------------------------------------------------------------------
. 2008-01-14 18:14:42.345 WinSCP Version 4.0.5 (Build 354) (OS 5.0.2195 Service Pack 4)
. 2008-01-14 18:14:42.345 Login time: Monday, January 14, 2008 6:14:42 PM
. 2008-01-14 18:14:42.345 Session name: root@192.168.2.12
. 2008-01-14 18:14:42.345 Host name: 192.168.2.12 (Port: 22)
. 2008-01-14 18:14:42.345 User name: root (Password: No, Key file: No)
. 2008-01-14 18:14:42.345 Tunnel: No
. 2008-01-14 18:14:42.345 Transfer Protocol: SFTP (SCP)
. 2008-01-14 18:14:42.345 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-01-14 18:14:42.345 Proxy: none
. 2008-01-14 18:14:42.345 SSH protocol version: 2; Compression: No
. 2008-01-14 18:14:42.345 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-01-14 18:14:42.345 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-01-14 18:14:42.345 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-01-14 18:14:42.345 SFTP Bugs: -,-,-
. 2008-01-14 18:14:42.345 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-01-14 18:14:42.345 Shell: default, EOL: 0
. 2008-01-14 18:14:42.345 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-01-14 18:14:42.345 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-01-14 18:14:42.345 Local directory: C:\Documents and Settings\khomyakovma\My Documents, Remote directory: /, Update: No, Cache: Yes
. 2008-01-14 18:14:42.345 Cache directory changes: Yes, Permanent: Yes
. 2008-01-14 18:14:42.345 DST mode: 1
. 2008-01-14 18:14:42.376 Looking up host "192.168.2.12"
. 2008-01-14 18:14:42.376 Connecting to 192.168.2.12 port 22
. 2008-01-14 18:14:42.391 Waiting for the server to continue with the initialisation
. 2008-01-14 18:14:42.391 Detected network event
. 2008-01-14 18:14:42.391 Server version: SSH-1.99-OpenSSH_2.9p2
. 2008-01-14 18:14:42.391 We believe remote version has SSH-2 RSA padding bug
. 2008-01-14 18:14:42.391 We claim version: SSH-2.0-WinSCP_release_4.0.5
. 2008-01-14 18:14:42.391 Using SSH protocol version 2
. 2008-01-14 18:14:42.391 Doing Diffie-Hellman group exchange
. 2008-01-14 18:14:42.485 Detected network event
. 2008-01-14 18:14:42.485 Doing Diffie-Hellman key exchange
. 2008-01-14 18:14:42.673 Waiting for the server to continue with the initialisation
. 2008-01-14 18:14:42.735 Detected network event
. 2008-01-14 18:14:42.954 Host key fingerprint is:
. 2008-01-14 18:14:42.954 ssh-rsa 1024 b3:a5:fe:2f:5b:60:39:13:0a:6a:71:a9:c3:cc:6f:b3
. 2008-01-14 18:14:42.954 Initialised AES-256 client->server encryption
. 2008-01-14 18:14:42.954 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-01-14 18:14:42.954 Initialised AES-256 server->client encryption
. 2008-01-14 18:14:42.954 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-01-14 18:14:42.954 Waiting for the server to continue with the initialisation
. 2008-01-14 18:14:43.048 Detected network event
! 2008-01-14 18:14:43.048 Using username "root".
. 2008-01-14 18:14:43.048 Waiting for the server to continue with the initialisation
. 2008-01-14 18:14:43.048 Keyboard-interactive authentication refused
. 2008-01-14 18:14:43.048 Session password prompt (root@192.168.2.12's password: )
. 2008-01-14 18:14:47.501 Sent password
. 2008-01-14 18:14:47.501 Waiting for the server to continue with the initialisation
. 2008-01-14 18:14:47.501 Detected network event
. 2008-01-14 18:14:47.501 Access granted
. 2008-01-14 18:14:47.501 Opened channel for session
. 2008-01-14 18:14:47.501 Started a shell/command
. 2008-01-14 18:14:47.516 --------------------------------------------------------------------------
. 2008-01-14 18:14:47.516 Using SFTP protocol.
. 2008-01-14 18:14:47.516 Doing startup conversation with host.
> 2008-01-14 18:14:47.516 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2008-01-14 18:14:47.516 Sent 9 bytes
. 2008-01-14 18:14:47.516 There are 0 bytes remaining in the send buffer
. 2008-01-14 18:14:47.516 Waiting for another 4 bytes
. 2008-01-14 18:14:47.516 Detected network event
. 2008-01-14 18:14:47.516 Received 9 bytes (0)
. 2008-01-14 18:14:47.516 Read 4 bytes (5 pending)
. 2008-01-14 18:14:47.516 Read 5 bytes (0 pending)
< 2008-01-14 18:14:47.516 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2008-01-14 18:14:47.516 SFTP version 3 negotiated.
. 2008-01-14 18:14:47.516 We believe the server has signed timestamps bug
. 2008-01-14 18:14:47.516 We will use UTF-8 strings for status messages only
. 2008-01-14 18:14:47.516 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2008-01-14 18:14:47.516 Changing directory to "/".
. 2008-01-14 18:14:47.516 Getting real path for '/'
> 2008-01-14 18:14:47.516 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
. 2008-01-14 18:14:47.516 Sent 14 bytes
. 2008-01-14 18:14:47.516 Received 27 bytes (0)
. 2008-01-14 18:14:47.516 Read 4 bytes (23 pending)
. 2008-01-14 18:14:47.516 Read 23 bytes (0 pending)
< 2008-01-14 18:14:47.516 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2008-01-14 18:14:47.516 Real path is '/'
. 2008-01-14 18:14:47.516 Trying to open directory "/".
> 2008-01-14 18:14:47.516 Type: SSH_FXP_LSTAT, Size: 10, Number: 263
. 2008-01-14 18:14:47.516 Received 41 bytes (0)
. 2008-01-14 18:14:47.516 Read 4 bytes (37 pending)
. 2008-01-14 18:14:47.516 Read 37 bytes (0 pending)
< 2008-01-14 18:14:47.516 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2008-01-14 18:14:47.516 Getting current directory name.
. 2008-01-14 18:14:47.516 Listing directory "/".
> 2008-01-14 18:14:47.516 Type: SSH_FXP_OPENDIR, Size: 10, Number: 523
. 2008-01-14 18:14:47.516 Received 17 bytes (0)
. 2008-01-14 18:14:47.516 Read 4 bytes (13 pending)
. 2008-01-14 18:14:47.516 Read 13 bytes (0 pending)
< 2008-01-14 18:14:47.516 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
> 2008-01-14 18:14:47.516 Type: SSH_FXP_READDIR, Size: 13, Number: 780
. 2008-01-14 18:14:47.516 Sent 17 bytes
. 2008-01-14 18:14:47.532 Detected network event
. 2008-01-14 18:14:47.532 Waiting for another 4 bytes
. 2008-01-14 18:14:47.532 Received 5781 bytes (0)
. 2008-01-14 18:14:47.532 Read 4 bytes (5777 pending)
. 2008-01-14 18:14:47.532 Read 5777 bytes (0 pending)
< 2008-01-14 18:14:47.532 Type: SSH_FXP_NAME, Size: 5777, Number: 780
> 2008-01-14 18:14:47.532 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
. 2008-01-14 18:14:47.532 Sent 17 bytes
. 2008-01-14 18:14:47.532 There are 0 bytes remaining in the send buffer
. 2008-01-14 18:14:47.532 Reading symlink "bin".
> 2008-01-14 18:14:47.532 Type: SSH_FXP_READLINK, Size: 13, Number: 1299
> 2008-01-14 18:14:47.532 Type: SSH_FXP_STAT, Size: 13, Number: 1553
. 2008-01-14 18:14:47.532 Received 32 bytes (0)
. 2008-01-14 18:14:47.532 Read 4 bytes (28 pending)
. 2008-01-14 18:14:47.532 Read 28 bytes (0 pending)
< 2008-01-14 18:14:47.532 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
. 2008-01-14 18:14:47.532 Storing reserved response
. 2008-01-14 18:14:47.532 Received 43 bytes (0)
. 2008-01-14 18:14:47.532 Read 4 bytes (39 pending)
. 2008-01-14 18:14:47.532 Read 39 bytes (0 pending)
< 2008-01-14 18:14:47.532 Type: SSH_FXP_NAME, Size: 39, Number: 1299
. 2008-01-14 18:14:47.532 Received 41 bytes (0)
. 2008-01-14 18:14:47.532 Read 4 bytes (37 pending)
. 2008-01-14 18:14:47.532 Read 37 bytes (0 pending)
< 2008-01-14 18:14:47.548 Type: SSH_FXP_ATTRS, Size: 37, Number: 1553
. 2008-01-14 18:14:47.548 Reading symlink "lib".
> 2008-01-14 18:14:47.548 Type: SSH_FXP_READLINK, Size: 13, Number: 1811
. 2008-01-14 18:14:47.548 Sent 17 bytes
. 2008-01-14 18:14:47.548 There are 0 bytes remaining in the send buffer
> 2008-01-14 18:14:47.548 Type: SSH_FXP_STAT, Size: 13, Number: 2065
. 2008-01-14 18:14:47.548 Waiting for another 4 bytes
. 2008-01-14 18:14:47.548 Detected network event
. 2008-01-14 18:14:47.548 Received 43 bytes (0)
. 2008-01-14 18:14:47.548 Read 4 bytes (39 pending)
. 2008-01-14 18:14:47.548 Read 39 bytes (0 pending)
< 2008-01-14 18:14:47.548 Type: SSH_FXP_NAME, Size: 39, Number: 1811
. 2008-01-14 18:14:47.548 Received 41 bytes (0)
. 2008-01-14 18:14:47.548 Read 4 bytes (37 pending)
. 2008-01-14 18:14:47.548 Read 37 bytes (0 pending)
< 2008-01-14 18:14:47.548 Type: SSH_FXP_ATTRS, Size: 37, Number: 2065
< 2008-01-14 18:14:47.548 Status/error code: 1
> 2008-01-14 18:14:47.548 Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
. 2008-01-14 18:14:47.548 Startup conversation with host finished.
. 2008-01-14 18:14:48.235 Session upkeep
. 2008-01-14 18:14:48.235 Detected network event
. 2008-01-14 18:14:48.235 Received 28 bytes (0)
. 2008-01-14 18:14:48.735 Session upkeep
. 2008-01-14 18:14:49.235 Session upkeep
. 2008-01-14 18:14:49.735 Session upkeep
. 2008-01-14 18:14:50.235 Session upkeep
. 2008-01-14 18:14:50.735 Session upkeep
. 2008-01-14 18:14:51.235 Session upkeep
. 2008-01-14 18:14:51.735 Session upkeep
. 2008-01-14 18:14:52.235 Session upkeep
. 2008-01-14 18:14:52.735 Session upkeep
. 2008-01-14 18:14:53.282 Session upkeep
. 2008-01-14 18:14:53.735 Session upkeep
. 2008-01-14 18:14:54.235 Session upkeep
. 2008-01-14 18:14:54.735 Session upkeep
. 2008-01-14 18:14:55.251 Session upkeep
. 2008-01-14 18:14:55.735 Session upkeep
. 2008-01-14 18:14:56.235 Session upkeep
. 2008-01-14 18:14:56.735 Session upkeep
. 2008-01-14 18:14:57.235 Session upkeep
. 2008-01-14 18:14:57.735 Session upkeep
. 2008-01-14 18:14:58.235 Session upkeep
. 2008-01-14 18:14:58.735 Session upkeep
. 2008-01-14 18:14:59.235 Session upkeep
. 2008-01-14 18:14:59.735 Session upkeep
. 2008-01-14 18:15:00.235 Session upkeep
. 2008-01-14 18:15:00.563 Cached directory change via ".." to "/".
. 2008-01-14 18:15:00.563 Getting current directory name.
. 2008-01-14 18:15:00.641 Directory content loaded from cache.
. 2008-01-14 18:15:00.735 Session upkeep
. 2008-01-14 18:15:01.235 Session upkeep
. 2008-01-14 18:15:01.282 Cached directory change via ".." to "/".
. 2008-01-14 18:15:01.282 Getting current directory name.
. 2008-01-14 18:15:01.345 Directory content loaded from cache.
. 2008-01-14 18:15:01.735 Session upkeep
. 2008-01-14 18:15:01.845 Cached directory change via ".." to "/".
. 2008-01-14 18:15:01.845 Getting current directory name.
. 2008-01-14 18:15:01.907 Directory content loaded from cache.
. 2008-01-14 18:15:02.235 Session upkeep
. 2008-01-14 18:15:02.735 Session upkeep
. 2008-01-14 18:15:03.235 Session upkeep
. 2008-01-14 18:15:03.735 Session upkeep
. 2008-01-14 18:15:04.235 Session upkeep
. 2008-01-14 18:15:04.735 Session upkeep
. 2008-01-14 18:15:05.235 Session upkeep
. 2008-01-14 18:15:05.282 Cached directory change via "u01" to "/u01".
. 2008-01-14 18:15:05.282 Getting current directory name.
. 2008-01-14 18:15:05.282 Listing directory "/u01".
> 2008-01-14 18:15:05.282 Type: SSH_FXP_OPENDIR, Size: 13, Number: 2571
. 2008-01-14 18:15:05.282 Sent 17 bytes
. 2008-01-14 18:15:05.282 There are 0 bytes remaining in the send buffer
. 2008-01-14 18:15:05.282 Read 4 bytes (24 pending)
. 2008-01-14 18:15:05.282 Read 24 bytes (0 pending)
< 2008-01-14 18:15:05.282 Type: SSH_FXP_STATUS, Size: 24, Number: 2308
. 2008-01-14 18:15:05.282 Discarding reserved response
. 2008-01-14 18:15:05.282 Waiting for another 4 bytes
. 2008-01-14 18:15:05.282 Detected network event
. 2008-01-14 18:15:05.282 Received 17 bytes (0)
. 2008-01-14 18:15:05.282 Read 4 bytes (13 pending)
. 2008-01-14 18:15:05.282 Read 13 bytes (0 pending)
< 2008-01-14 18:15:05.282 Type: SSH_FXP_HANDLE, Size: 13, Number: 2571
> 2008-01-14 18:15:05.282 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
. 2008-01-14 18:15:05.298 Detected network event
. 2008-01-14 18:15:05.298 Received 1129 bytes (0)
. 2008-01-14 18:15:05.298 Read 4 bytes (1125 pending)
. 2008-01-14 18:15:05.298 Read 1125 bytes (0 pending)
< 2008-01-14 18:15:05.298 Type: SSH_FXP_NAME, Size: 1125, Number: 2828
> 2008-01-14 18:15:05.298 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
. 2008-01-14 18:15:05.298 Sent 17 bytes
. 2008-01-14 18:15:05.298 There are 0 bytes remaining in the send buffer
. 2008-01-14 18:15:05.298 Waiting for another 4 bytes
. 2008-01-14 18:15:05.298 Received 32 bytes (0)
. 2008-01-14 18:15:05.298 Read 4 bytes (28 pending)
. 2008-01-14 18:15:05.298 Read 28 bytes (0 pending)
< 2008-01-14 18:15:05.298 Type: SSH_FXP_STATUS, Size: 28, Number: 3084
< 2008-01-14 18:15:05.298 Status/error code: 1
> 2008-01-14 18:15:05.298 Type: SSH_FXP_CLOSE, Size: 13, Number: 3332
. 2008-01-14 18:15:05.735 Session upkeep
. 2008-01-14 18:15:05.735 Detected network event
. 2008-01-14 18:15:05.735 Received 28 bytes (0)
. 2008-01-14 18:15:06.235 Session upkeep
. 2008-01-14 18:15:06.735 Session upkeep
. 2008-01-14 18:15:07.016 Cached directory change via "dms-tek-backup" to "/u01/dms-tek-backup".
. 2008-01-14 18:15:07.016 Getting current directory name.
. 2008-01-14 18:15:07.016 Listing directory "/u01/dms-tek-backup".
> 2008-01-14 18:15:07.016 Type: SSH_FXP_OPENDIR, Size: 28, Number: 3595
. 2008-01-14 18:15:07.016 Sent 32 bytes
. 2008-01-14 18:15:07.016 There are 0 bytes remaining in the send buffer
. 2008-01-14 18:15:07.016 Read 4 bytes (24 pending)
. 2008-01-14 18:15:07.016 Read 24 bytes (0 pending)
< 2008-01-14 18:15:07.016 Type: SSH_FXP_STATUS, Size: 24, Number: 3332
. 2008-01-14 18:15:07.016 Discarding reserved response
. 2008-01-14 18:15:07.016 Waiting for another 4 bytes
. 2008-01-14 18:15:07.016 Detected network event
. 2008-01-14 18:15:07.016 Received 17 bytes (0)
. 2008-01-14 18:15:07.016 Read 4 bytes (13 pending)
. 2008-01-14 18:15:07.016 Read 13 bytes (0 pending)
< 2008-01-14 18:15:07.016 Type: SSH_FXP_HANDLE, Size: 13, Number: 3595
> 2008-01-14 18:15:07.016 Type: SSH_FXP_READDIR, Size: 13, Number: 3852
. 2008-01-14 18:15:07.016 Sent 17 bytes
. 2008-01-14 18:15:07.032 Detected network event
. 2008-01-14 18:15:07.032 Received 1903 bytes (0)
. 2008-01-14 18:15:07.032 Read 4 bytes (1899 pending)
. 2008-01-14 18:15:07.032 Read 1899 bytes (0 pending)
< 2008-01-14 18:15:07.032 Type: SSH_FXP_NAME, Size: 1899, Number: 3852
> 2008-01-14 18:15:07.032 Type: SSH_FXP_READDIR, Size: 13, Number: 4108
. 2008-01-14 18:15:07.032 Sent 17 bytes
. 2008-01-14 18:15:07.032 There are 0 bytes remaining in the send buffer
. 2008-01-14 18:15:07.032 Waiting for another 4 bytes
. 2008-01-14 18:15:07.032 Received 32 bytes (0)
. 2008-01-14 18:15:07.032 Read 4 bytes (28 pending)
. 2008-01-14 18:15:07.032 Read 28 bytes (0 pending)
< 2008-01-14 18:15:07.032 Type: SSH_FXP_STATUS, Size: 28, Number: 4108
< 2008-01-14 18:15:07.032 Status/error code: 1
> 2008-01-14 18:15:07.032 Type: SSH_FXP_CLOSE, Size: 13, Number: 4356
. 2008-01-14 18:15:07.235 Session upkeep
. 2008-01-14 18:15:07.235 Detected network event
. 2008-01-14 18:15:07.235 Received 28 bytes (0)
. 2008-01-14 18:15:07.735 Session upkeep
. 2008-01-14 18:15:08.235 Session upkeep
. 2008-01-14 18:15:08.735 Session upkeep
. 2008-01-14 18:15:09.235 Session upkeep
. 2008-01-14 18:15:09.735 Session upkeep
. 2008-01-14 18:15:10.235 Session upkeep
. 2008-01-14 18:15:10.735 Session upkeep
. 2008-01-14 18:15:11.235 Session upkeep
. 2008-01-14 18:15:11.735 Session upkeep
. 2008-01-14 18:15:12.235 Session upkeep
. 2008-01-14 18:15:12.735 Session upkeep
. 2008-01-14 18:15:13.235 Session upkeep
. 2008-01-14 18:15:13.735 Session upkeep
. 2008-01-14 18:15:14.235 Session upkeep
. 2008-01-14 18:15:14.735 Session upkeep
. 2008-01-14 18:15:15.235 Session upkeep
. 2008-01-14 18:15:15.735 Session upkeep
. 2008-01-14 18:15:16.235 Session upkeep
. 2008-01-14 18:15:16.735 Session upkeep
. 2008-01-14 18:15:17.235 Session upkeep
. 2008-01-14 18:15:17.735 Session upkeep
. 2008-01-14 18:15:18.235 Session upkeep
. 2008-01-14 18:15:18.735 Session upkeep
. 2008-01-14 18:15:19.235 Session upkeep
. 2008-01-14 18:15:19.735 Session upkeep
. 2008-01-14 18:15:20.235 Session upkeep
. 2008-01-14 18:15:20.735 Session upkeep
. 2008-01-14 18:15:21.235 Session upkeep
. 2008-01-14 18:15:21.735 Session upkeep
. 2008-01-14 18:15:22.235 Session upkeep
. 2008-01-14 18:15:22.735 Session upkeep
. 2008-01-14 18:15:24.626 Session upkeep
. 2008-01-14 18:15:24.735 Session upkeep
. 2008-01-14 18:15:25.235 Session upkeep
. 2008-01-14 18:15:25.735 Session upkeep
. 2008-01-14 18:15:26.235 Session upkeep
. 2008-01-14 18:15:26.735 Session upkeep
. 2008-01-14 18:15:26.891 Session upkeep
. 2008-01-14 18:15:27.173 Session upkeep
. 2008-01-14 18:15:27.235 Session upkeep
. 2008-01-14 18:15:27.735 Session upkeep
. 2008-01-14 18:15:28.235 Session upkeep
. 2008-01-14 18:15:28.438 Closing connection.
_MMX_
The same situation is in the latest release for the current moment- WinSCP 4.6 build 358. Nothng has changed about this problem.
_MMX_
Log with Debug2. I'm doing tha same old thing- logging in, switching to "/u01/dms-tek-backup" and disconnecting from server.
. 2008-01-17 16:50:07.055 --------------------------------------------------------------------------
. 2008-01-17 16:50:07.055 WinSCP Version 4.0.6 (Build 358) (OS 5.0.2195 Service Pack 4)
. 2008-01-17 16:50:07.055 Login time: Thursday, January 17, 2008 4:50:07 PM
. 2008-01-17 16:50:07.055 Session name: root@192.168.2.12
. 2008-01-17 16:50:07.055 Host name: 192.168.2.12 (Port: 22)
. 2008-01-17 16:50:07.055 User name: root (Password: No, Key file: No)
. 2008-01-17 16:50:07.055 Tunnel: No
. 2008-01-17 16:50:07.055 Transfer Protocol: SFTP (SCP)
. 2008-01-17 16:50:07.055 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-01-17 16:50:07.055 Proxy: none
. 2008-01-17 16:50:07.055 SSH protocol version: 2; Compression: No
. 2008-01-17 16:50:07.055 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-01-17 16:50:07.055 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-01-17 16:50:07.055 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-01-17 16:50:07.055 SFTP Bugs: -,-,-
. 2008-01-17 16:50:07.055 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-01-17 16:50:07.055 Shell: default, EOL: 0
. 2008-01-17 16:50:07.055 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-01-17 16:50:07.055 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-01-17 16:50:07.055 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-01-17 16:50:07.055 Cache directory changes: Yes, Permanent: Yes
. 2008-01-17 16:50:07.055 DST mode: 1
. 2008-01-17 16:50:07.070 Looking up host "192.168.2.12"
. 2008-01-17 16:50:07.070 Connecting to 192.168.2.12 port 22
. 2008-01-17 16:50:07.070 Selecting events 63 for socket 732
. 2008-01-17 16:50:07.070 Waiting for the server to continue with the initialisation
. 2008-01-17 16:50:07.070 Looking for incoming data
. 2008-01-17 16:50:07.070 Looking for network events
. 2008-01-17 16:50:07.070 Detected network event
. 2008-01-17 16:50:07.070 Enumerating network events for socket 732
. 2008-01-17 16:50:07.070 Enumerated 18 network events making 18 cumulative events for socket 732
. 2008-01-17 16:50:07.070 Handling network write event on socket 732 with error 0
. 2008-01-17 16:50:07.070 Handling network connect event on socket 732 with error 0
. 2008-01-17 16:50:07.070 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:07.070 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:07.070 Server version: SSH-1.99-OpenSSH_2.9p2
. 2008-01-17 16:50:07.070 We believe remote version has SSH-2 RSA padding bug
. 2008-01-17 16:50:07.070 We claim version: SSH-2.0-WinSCP_release_4.0.6
. 2008-01-17 16:50:07.070 Using SSH protocol version 2
. 2008-01-17 16:50:07.070 Doing Diffie-Hellman group exchange
. 2008-01-17 16:50:07.164 Detected network event
. 2008-01-17 16:50:07.164 Enumerating network events for socket 732
. 2008-01-17 16:50:07.164 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:07.164 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:07.164 Doing Diffie-Hellman key exchange
. 2008-01-17 16:50:07.351 Waiting for the server to continue with the initialisation
. 2008-01-17 16:50:07.351 Looking for incoming data
. 2008-01-17 16:50:07.351 Looking for network events
. 2008-01-17 16:50:07.414 Detected network event
. 2008-01-17 16:50:07.414 Enumerating network events for socket 732
. 2008-01-17 16:50:07.414 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:07.414 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:07.633 Selecting events 63 for socket 732
. 2008-01-17 16:50:07.633 Host key fingerprint is:
. 2008-01-17 16:50:07.633 ssh-rsa 1024 b3:a5:fe:2f:5b:60:39:13:0a:6a:71:a9:c3:cc:6f:b3
. 2008-01-17 16:50:07.633 Initialised AES-256 client->server encryption
. 2008-01-17 16:50:07.633 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-01-17 16:50:07.633 Initialised AES-256 server->client encryption
. 2008-01-17 16:50:07.633 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-01-17 16:50:07.633 Waiting for the server to continue with the initialisation
. 2008-01-17 16:50:07.633 Looking for incoming data
. 2008-01-17 16:50:07.633 Looking for network events
. 2008-01-17 16:50:07.726 Detected network event
. 2008-01-17 16:50:07.726 Enumerating network events for socket 732
. 2008-01-17 16:50:07.726 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:07.726 Handling network read event on socket 732 with error 0
! 2008-01-17 16:50:07.726 Using username "root".
. 2008-01-17 16:50:07.742 Waiting for the server to continue with the initialisation
. 2008-01-17 16:50:07.742 Looking for incoming data
. 2008-01-17 16:50:07.742 Looking for network events
. 2008-01-17 16:50:07.742 Detected network event
. 2008-01-17 16:50:07.742 Enumerating network events for socket 732
. 2008-01-17 16:50:07.742 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:07.742 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:07.742 Keyboard-interactive authentication refused
. 2008-01-17 16:50:07.742 Session password prompt (root@192.168.2.12's password: )
. 2008-01-17 16:50:15.008 Sent password
. 2008-01-17 16:50:15.008 Waiting for the server to continue with the initialisation
. 2008-01-17 16:50:15.008 Looking for incoming data
. 2008-01-17 16:50:15.008 Looking for network events
. 2008-01-17 16:50:15.023 Detected network event
. 2008-01-17 16:50:15.023 Enumerating network events for socket 732
. 2008-01-17 16:50:15.023 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:15.023 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:15.023 Access granted
. 2008-01-17 16:50:15.023 Waiting for the server to continue with the initialisation
. 2008-01-17 16:50:15.023 Looking for incoming data
. 2008-01-17 16:50:15.023 Looking for network events
. 2008-01-17 16:50:15.023 Opened channel for session
. 2008-01-17 16:50:15.023 Started a shell/command
. 2008-01-17 16:50:15.023 --------------------------------------------------------------------------
. 2008-01-17 16:50:15.023 Using SFTP protocol.
. 2008-01-17 16:50:15.023 Doing startup conversation with host.
> 2008-01-17 16:50:15.023 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2008-01-17 16:50:15.023 01,00,00,00,05,
. 2008-01-17 16:50:15.023 Sent 9 bytes
. 2008-01-17 16:50:15.023 There are 0 bytes remaining in the send buffer
. 2008-01-17 16:50:15.023 Timeout waiting for network events
. 2008-01-17 16:50:15.023 Waiting for another 4 bytes
. 2008-01-17 16:50:15.023 Received 9 bytes (0)
. 2008-01-17 16:50:15.023 Read 4 bytes (5 pending)
. 2008-01-17 16:50:15.023 Read 5 bytes (0 pending)
< 2008-01-17 16:50:15.023 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2008-01-17 16:50:15.023 02,00,00,00,03,
. 2008-01-17 16:50:15.023 SFTP version 3 negotiated.
. 2008-01-17 16:50:15.023 We believe the server has signed timestamps bug
. 2008-01-17 16:50:15.023 We will use UTF-8 strings for status messages only
. 2008-01-17 16:50:15.023 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2008-01-17 16:50:15.023 Getting current directory name.
. 2008-01-17 16:50:15.023 Getting real path for '.'
> 2008-01-17 16:50:15.023 Type: SSH_FXP_REALPATH, Size: 10, Number: 2320
> 2008-01-17 16:50:15.023 10,00,00,09,10,00,00,00,01,2E,
. 2008-01-17 16:50:15.023 Sent 14 bytes
. 2008-01-17 16:50:15.039 Looking for incoming data
. 2008-01-17 16:50:15.039 Looking for network events
. 2008-01-17 16:50:15.039 Detected network event
. 2008-01-17 16:50:15.039 Enumerating network events for socket 732
. 2008-01-17 16:50:15.039 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:15.039 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:15.039 Received 27 bytes (0)
. 2008-01-17 16:50:15.039 Read 4 bytes (23 pending)
. 2008-01-17 16:50:15.039 Read 23 bytes (0 pending)
< 2008-01-17 16:50:15.039 Type: SSH_FXP_NAME, Size: 23, Number: 2320
< 2008-01-17 16:50:15.039 68,00,00,09,10,00,00,00,01,00,00,00,01,2F,00,00,00,01,2F,00,00,00,00,
. 2008-01-17 16:50:15.039 Real path is '/'
. 2008-01-17 16:50:15.039 Listing directory "/".
> 2008-01-17 16:50:15.039 Type: SSH_FXP_OPENDIR, Size: 10, Number: 2571
> 2008-01-17 16:50:15.039 0B,00,00,0A,0B,00,00,00,01,2F,
. 2008-01-17 16:50:15.039 Sent 14 bytes
. 2008-01-17 16:50:15.039 There are 0 bytes remaining in the send buffer
. 2008-01-17 16:50:15.039 Timeout waiting for network events
. 2008-01-17 16:50:15.039 Waiting for another 4 bytes
. 2008-01-17 16:50:15.039 Received 17 bytes (0)
. 2008-01-17 16:50:15.039 Read 4 bytes (13 pending)
. 2008-01-17 16:50:15.039 Read 13 bytes (0 pending)
< 2008-01-17 16:50:15.039 Type: SSH_FXP_HANDLE, Size: 13, Number: 2571
< 2008-01-17 16:50:15.039 66,00,00,0A,0B,00,00,00,04,00,00,00,00,
> 2008-01-17 16:50:15.039 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
> 2008-01-17 16:50:15.039 0C,00,00,0B,0C,00,00,00,04,00,00,00,00,
. 2008-01-17 16:50:15.039 Sent 17 bytes
. 2008-01-17 16:50:15.055 Received 5781 bytes (0)
. 2008-01-17 16:50:15.055 Read 4 bytes (5777 pending)
. 2008-01-17 16:50:15.055 Read 5777 bytes (0 pending)
< 2008-01-17 16:50:15.055 Type: SSH_FXP_NAME, Size: 5777, Number: 2828
< 2008-01-17 16:50:15.117 68,00,00,0B,0C,00,00,00,35,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,
< 2008-01-17 16:50:15.117 72,2D,78,20,20,20,33,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,31,30,32,34,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,2E,
< 2008-01-17 16:50:15.117 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,47,
< 2008-01-17 16:50:15.117 8F,5B,FE,47,6B,8D,DD,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,78,72,
< 2008-01-17 16:50:15.117 2D,78,20,20,20,33,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,31,30,32,34,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,2E,2E,
< 2008-01-17 16:50:15.117 8F,5B,FE,47,6B,8D,DD,00,00,00,0A,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,42,
< 2008-01-17 16:50:15.117 64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,
< 2008-01-17 16:50:15.117 72,6F,6F,74,20,20,20,20,20,20,20,20,20,38,31,39,32,20,4A,75,6C,20,32,32,20,
< 2008-01-17 16:50:15.117 20,32,30,30,32,20,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,0F,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,20,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,C9,64,43,3D,3B,DB,A7,00,00,
< 2008-01-17 16:50:15.117 00,03,76,61,72,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,33,30,20,
< 2008-01-17 16:50:15.117 72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,
< 2008-01-17 16:50:15.117 32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,76,61,72,00,00,00,0F,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,71,0A,39,3D,3B,E2,E9,
< 2008-01-17 16:50:15.117 00,00,00,03,75,73,72,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,33,
< 2008-01-17 16:50:15.117 34,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,31,
< 2008-01-17 16:50:15.117 30,32,34,20,4D,61,79,20,31,35,20,20,32,30,30,33,20,75,73,72,00,00,00,0F,00,
< 2008-01-17 16:50:15.117 00,00,00,00,00,04,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,71,0A,2F,3E,C3,
< 2008-01-17 16:50:15.117 A0,E1,00,00,00,03,65,74,63,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,
< 2008-01-17 16:50:15.117 20,34,32,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,33,35,38,34,20,4A,61,6E,20,31,34,20,31,37,3A,35,35,20,65,74,63,00,00,00,
< 2008-01-17 16:50:15.117 0F,00,00,00,00,00,00,0E,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,84,9A,F9,
< 2008-01-17 16:50:15.117 47,8B,77,FE,00,00,00,03,62,69,6E,00,00,00,3B,6C,72,77,78,72,77,78,72,77,78,
< 2008-01-17 16:50:15.117 20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,39,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,62,69,6E,00,
< 2008-01-17 16:50:15.117 00,00,0F,00,00,00,00,00,00,00,09,00,00,00,00,00,00,00,00,00,00,A1,FF,47,8F,
< 2008-01-17 16:50:15.117 5B,B2,3D,3B,DC,5E,00,00,00,03,64,65,76,00,00,00,3B,64,72,77,78,72,2D,78,72,
< 2008-01-17 16:50:15.117 2D,78,20,20,20,31,34,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,35,31,32,30,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,64,65,
< 2008-01-17 16:50:15.117 76,00,00,00,0F,00,00,00,00,00,00,14,00,00,00,00,00,00,00,00,03,00,00,41,ED,
< 2008-01-17 16:50:15.117 47,6B,8E,02,47,6B,8D,D8,00,00,00,07,64,65,76,69,63,65,73,00,00,00,3F,64,72,
< 2008-01-17 16:50:15.117 77,78,72,2D,78,72,2D,78,20,20,20,20,36,20,72,6F,6F,74,20,20,20,20,20,73,79,
< 2008-01-17 16:50:15.117 73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,
< 2008-01-17 16:50:15.117 30,30,32,20,64,65,76,69,63,65,73,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,00,03,00,00,41,ED,46,DD,3F,14,3D,3B,DF,B0,00,00,00,06,6B,65,72,
< 2008-01-17 16:50:15.117 6E,65,6C,00,00,00,3E,64,72,77,78,72,2D,78,72,2D,78,20,20,20,31,31,20,72,6F,
< 2008-01-17 16:50:15.117 6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,
< 2008-01-17 16:50:15.117 4A,75,6C,20,32,33,20,20,32,30,30,32,20,6B,65,72,6E,65,6C,00,00,00,0F,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,71,01,F5,3D,3C,FE,
< 2008-01-17 16:50:15.117 FF,00,00,00,03,6C,69,62,00,00,00,3B,6C,72,77,78,72,77,78,72,77,78,20,20,20,
< 2008-01-17 16:50:15.117 20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,39,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,6C,69,62,00,00,00,0F,
< 2008-01-17 16:50:15.117 00,00,00,00,00,00,00,09,00,00,00,00,00,00,00,00,00,00,A1,FF,47,8F,5B,B2,3D,
< 2008-01-17 16:50:15.117 3B,DC,5F,00,00,00,03,6D,6E,74,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,
< 2008-01-17 16:50:15.117 20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,35,31,32,20,4A,75,6E,20,32,38,20,20,32,30,30,34,20,6D,6E,74,00,00,
< 2008-01-17 16:50:15.117 00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,84,9A,
< 2008-01-17 16:50:15.117 F6,40,E0,19,B4,00,00,00,03,6F,70,74,00,00,00,3B,64,72,77,78,72,77,78,72,2D,
< 2008-01-17 16:50:15.117 78,20,20,20,20,37,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,35,31,32,20,4A,75,6E,20,32,34,20,20,32,30,30,35,20,6F,70,74,
< 2008-01-17 16:50:15.117 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,FD,44,
< 2008-01-17 16:50:15.117 76,E7,45,42,BB,A6,05,00,00,00,04,70,72,6F,63,00,00,00,3C,64,72,2D,78,72,2D,
< 2008-01-17 16:50:15.117 78,72,2D,78,20,20,20,36,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,36,31,31,32,30,20,4A,61,6E,20,31,37,20,31,36,3A,34,35,20,
< 2008-01-17 16:50:15.117 70,72,6F,63,00,00,00,0F,00,00,00,00,00,00,EE,C0,00,00,00,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,41,6D,47,8F,5B,FE,47,8F,5B,FE,00,00,00,04,73,62,69,6E,00,00,00,3C,64,72,
< 2008-01-17 16:50:15.117 77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,73,79,
< 2008-01-17 16:50:15.117 73,20,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4F,63,74,20,31,38,20,20,32,
< 2008-01-17 16:50:15.117 30,30,32,20,73,62,69,6E,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,00,03,00,00,41,ED,47,61,2F,EC,3D,B0,04,F2,00,00,00,03,74,6D,70,00,00,00,
< 2008-01-17 16:50:15.117 3B,64,72,77,78,72,77,78,72,77,74,20,20,20,20,34,20,72,6F,6F,74,20,20,20,20,
< 2008-01-17 16:50:15.117 20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,32,37,32,20,4A,61,6E,20,31,37,
< 2008-01-17 16:50:15.117 20,30,33,3A,33,30,20,74,6D,70,00,00,00,0F,00,00,00,00,00,00,01,10,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,03,00,00,43,FF,47,6B,8E,02,47,8E,A1,88,00,00,00,04,62,6F,6F,74,
< 2008-01-17 16:50:15.117 00,00,00,3C,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,34,20,72,6F,6F,74,20,
< 2008-01-17 16:50:15.117 20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,4A,75,6C,
< 2008-01-17 16:50:15.117 20,32,32,20,20,32,30,30,32,20,62,6F,6F,74,00,00,00,0F,00,00,00,00,00,00,02,
< 2008-01-17 16:50:15.117 00,00,00,00,00,00,00,00,03,00,00,41,ED,46,1A,08,B3,3D,3B,DC,B8,00,00,00,08,
< 2008-01-17 16:50:15.117 70,6C,61,74,66,6F,72,6D,00,00,00,40,64,72,77,78,72,2D,78,72,2D,78,20,20,20,
< 2008-01-17 16:50:15.117 20,34,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,70,6C,61,74,66,6F,72,
< 2008-01-17 16:50:15.117 6D,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,
< 2008-01-17 16:50:15.117 47,84,9A,F0,3D,3B,DC,D4,00,00,00,03,6E,65,74,00,00,00,3B,64,72,2D,78,72,2D,
< 2008-01-17 16:50:15.117 78,72,2D,78,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,20,20,20,31,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,
< 2008-01-17 16:50:15.117 6E,65,74,00,00,00,0F,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 41,6D,47,6B,8D,DC,47,6B,8D,DC,00,00,00,06,65,78,70,6F,72,74,00,00,00,3E,64,
< 2008-01-17 16:50:15.117 72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,73,
< 2008-01-17 16:50:15.117 79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,20,35,20,20,
< 2008-01-17 16:50:15.117 32,30,30,32,20,65,78,70,6F,72,74,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,00,03,00,00,41,ED,47,8E,FC,6F,3D,4E,6F,65,00,00,00,04,68,6F,6D,
< 2008-01-17 16:50:15.117 65,00,00,00,3C,64,72,2D,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,6F,6F,74,
< 2008-01-17 16:50:15.117 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,31,20,44,65,
< 2008-01-17 16:50:15.117 63,20,32,31,20,31,32,3A,35,36,20,68,6F,6D,65,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,01,00,00,00,00,00,00,00,00,00,00,41,6D,47,6B,8D,DC,47,6B,8D,DC,00,00,00,
< 2008-01-17 16:50:15.117 02,64,74,00,00,00,3A,64,72,77,78,72,77,78,72,2D,78,20,20,20,20,32,20,72,6F,
< 2008-01-17 16:50:15.117 6F,74,20,20,20,20,20,62,69,6E,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,
< 2008-01-17 16:50:15.117 4A,75,6C,20,32,32,20,20,32,30,30,32,20,64,74,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 02,00,00,00,00,00,00,00,00,02,00,00,41,FD,46,1F,2E,D9,3D,3B,DF,7F,00,00,00,
< 2008-01-17 16:50:15.117 03,78,66,6E,00,00,00,3B,64,72,2D,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,
< 2008-01-17 16:50:15.117 6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,31,
< 2008-01-17 16:50:15.117 20,44,65,63,20,32,31,20,31,32,3A,35,36,20,78,66,6E,00,00,00,0F,00,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,01,00,00,00,00,00,00,00,00,00,00,41,6D,47,6B,8D,DC,47,6B,8D,DC,00,
< 2008-01-17 16:50:15.117 00,00,03,76,6F,6C,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,
< 2008-01-17 16:50:15.117 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,35,
< 2008-01-17 16:50:15.117 31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,76,6F,6C,00,00,00,0F,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,02,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,76,E7,7B,3D,3B,E2,
< 2008-01-17 16:50:15.117 23,00,00,00,05,54,54,5F,44,42,00,00,00,3D,64,72,77,78,72,2D,78,72,2D,78,20,
< 2008-01-17 16:50:15.117 20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,54,54,5F,44,42,
< 2008-01-17 16:50:15.117 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,
< 2008-01-17 16:50:15.117 1A,07,55,3D,3B,E2,2A,00,00,00,05,63,64,72,6F,6D,00,00,00,3D,64,72,77,78,72,
< 2008-01-17 16:50:15.117 2D,78,72,2D,78,20,20,20,20,34,20,72,6F,6F,74,20,20,20,20,20,6E,6F,62,6F,64,
< 2008-01-17 16:50:15.117 79,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,31,34,20,20,32,30,30,33,
< 2008-01-17 16:50:15.117 20,63,64,72,6F,6D,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,EA,
< 2008-01-17 16:50:15.117 61,00,00,41,ED,47,6B,E1,BB,3F,3B,96,0F,00,00,00,03,2E,64,74,00,00,00,3B,64,
< 2008-01-17 16:50:15.117 72,77,78,72,2D,78,72,2D,78,20,20,20,31,31,20,72,6F,6F,74,20,20,20,20,20,6F,
< 2008-01-17 16:50:15.117 74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,31,34,20,20,
< 2008-01-17 16:50:15.117 32,30,30,33,20,2E,64,74,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,00,01,00,00,41,ED,47,73,4E,FD,3F,3B,90,C9,00,00,00,0A,2E,64,74,70,72,6F,
< 2008-01-17 16:50:15.117 66,69,6C,65,00,00,00,42,2D,72,77,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,
< 2008-01-17 16:50:15.117 6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,35,31,31,31,
< 2008-01-17 16:50:15.117 20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,2E,64,74,70,72,6F,66,69,6C,65,00,
< 2008-01-17 16:50:15.117 00,00,0F,00,00,00,00,00,00,13,F7,00,00,00,00,00,00,00,01,00,00,81,ED,42,BB,
< 2008-01-17 16:50:15.117 A6,BD,3D,3B,E8,29,00,00,00,04,64,61,74,61,00,00,00,3C,64,72,77,78,72,2D,78,
< 2008-01-17 16:50:15.117 72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,64,
< 2008-01-17 16:50:15.117 61,74,61,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,01,00,00,
< 2008-01-17 16:50:15.117 41,ED,46,1A,08,B0,3D,3C,10,85,00,00,00,09,2E,6E,65,74,73,63,61,70,65,00,00,
< 2008-01-17 16:50:15.117 00,41,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,35,20,72,6F,6F,74,20,20,20,
< 2008-01-17 16:50:15.117 20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,20,
< 2008-01-17 16:50:15.117 35,20,20,32,30,30,32,20,2E,6E,65,74,73,63,61,70,65,00,00,00,0F,00,00,00,00,
< 2008-01-17 16:50:15.117 00,00,02,00,00,00,00,00,00,00,00,01,00,00,41,C0,43,56,4F,7B,3D,4E,50,A1,00,
< 2008-01-17 16:50:15.117 00,00,0B,2E,58,61,75,74,68,6F,72,69,74,79,00,00,00,43,2D,72,77,2D,2D,2D,2D,
< 2008-01-17 16:50:15.117 2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,32,35,35,20,41,75,67,20,31,34,20,20,32,30,30,33,20,2E,
< 2008-01-17 16:50:15.117 58,61,75,74,68,6F,72,69,74,79,00,00,00,0F,00,00,00,00,00,00,00,FF,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,01,00,00,81,80,3F,3B,90,CB,3F,3B,90,C5,00,00,00,06,6E,73,6D,61,
< 2008-01-17 16:50:15.117 69,6C,00,00,00,3E,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,
< 2008-01-17 16:50:15.117 74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,4A,
< 2008-01-17 16:50:15.117 75,6C,20,32,33,20,20,32,30,30,32,20,6E,73,6D,61,69,6C,00,00,00,0F,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,02,00,00,00,00,00,00,00,00,01,00,00,41,C0,43,56,4F,7B,3D,3C,EC,D9,
< 2008-01-17 16:50:15.117 00,00,00,0C,2E,54,54,61,75,74,68,6F,72,69,74,79,00,00,00,44,2D,72,77,2D,2D,
< 2008-01-17 16:50:15.117 2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,20,20,31,34,37,20,41,75,67,20,31,34,20,20,32,30,30,33,
< 2008-01-17 16:50:15.117 20,2E,54,54,61,75,74,68,6F,72,69,74,79,00,00,00,0F,00,00,00,00,00,00,00,93,
< 2008-01-17 16:50:15.117 00,00,00,00,00,00,00,01,00,00,81,80,3F,3B,90,CA,3F,3B,90,C9,00,00,00,04,74,
< 2008-01-17 16:50:15.117 65,6D,70,00,00,00,3C,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,
< 2008-01-17 16:50:15.117 6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,34,35,35,34,30,20,
< 2008-01-17 16:50:15.117 4D,61,72,20,31,34,20,20,32,30,30,36,20,74,65,6D,70,00,00,00,0F,00,00,00,00,
< 2008-01-17 16:50:15.117 00,00,B1,E4,00,00,00,00,00,00,00,01,00,00,81,A4,46,19,F9,1C,44,16,96,D8,00,
< 2008-01-17 16:50:15.117 00,00,0D,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,45,2D,72,77,2D,2D,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,20,31,36,37,37,20,4A,61,6E,20,31,34,20,31,37,3A,35,37,
< 2008-01-17 16:50:15.117 20,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,0F,00,00,00,00,00,00,06,
< 2008-01-17 16:50:15.117 8D,00,00,00,00,00,00,00,01,00,00,81,80,47,8B,78,61,47,8B,78,61,00,00,00,0F,
< 2008-01-17 16:50:15.117 2E,73,6D,63,2E,70,72,6F,70,65,72,74,69,65,73,00,00,00,47,2D,72,77,2D,72,2D,
< 2008-01-17 16:50:15.117 2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,31,31,38,36,20,41,75,67,20,20,35,20,20,32,30,30,32,20,
< 2008-01-17 16:50:15.117 2E,73,6D,63,2E,70,72,6F,70,65,72,74,69,65,73,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 04,A2,00,00,00,00,00,00,00,01,00,00,81,A4,3D,4E,46,74,3D,4E,46,74,00,00,00,
< 2008-01-17 16:50:15.117 12,64,6D,73,2D,74,65,6B,2D,65,6E,65,72,67,6F,73,62,79,74,00,00,00,4A,64,72,
< 2008-01-17 16:50:15.117 77,78,72,2D,78,72,2D,78,20,20,20,32,33,20,69,73,69,64,61,20,20,20,20,69,73,
< 2008-01-17 16:50:15.117 69,64,61,20,20,20,20,20,20,20,20,31,30,32,34,20,46,65,62,20,32,37,20,20,32,
< 2008-01-17 16:50:15.117 30,30,36,20,64,6D,73,2D,74,65,6B,2D,65,6E,65,72,67,6F,73,62,79,74,00,00,00,
< 2008-01-17 16:50:15.117 0F,00,00,00,00,00,00,04,00,00,00,00,64,00,00,00,64,00,00,41,ED,47,8E,39,B2,
< 2008-01-17 16:50:15.117 44,03,1E,9C,00,00,00,07,64,6D,73,2D,74,65,6B,00,00,00,3F,64,72,77,78,72,2D,
< 2008-01-17 16:50:15.117 78,72,2D,78,20,20,20,20,32,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,20,35,31,32,20,4A,61,6E,20,33,31,20,20,32,30,30,35,20,
< 2008-01-17 16:50:15.117 64,6D,73,2D,74,65,6B,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,
< 2008-01-17 16:50:15.117 00,64,00,00,41,ED,46,C9,71,B2,41,FD,F3,77,00,00,00,0B,2E,73,68,5F,68,69,73,
< 2008-01-17 16:50:15.117 74,6F,72,79,00,00,00,43,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,
< 2008-01-17 16:50:15.117 6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,31,33,30,32,32,
< 2008-01-17 16:50:15.117 20,4A,61,6E,20,32,30,20,20,32,30,30,34,20,2E,73,68,5F,68,69,73,74,6F,72,79,
< 2008-01-17 16:50:15.117 00,00,00,0F,00,00,00,00,00,00,32,DE,00,00,00,00,00,00,00,01,00,00,81,80,40,
< 2008-01-17 16:50:15.117 0D,6B,E3,40,0D,6B,E3,00,00,00,03,75,30,31,00,00,00,3B,64,72,77,78,72,77,78,
< 2008-01-17 16:50:15.117 72,77,78,20,20,20,31,30,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,35,31,32,20,4E,6F,76,20,20,38,20,20,32,30,30,36,20,75,
< 2008-01-17 16:50:15.117 30,31,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,
< 2008-01-17 16:50:15.117 FF,47,8E,FD,DA,45,51,BD,80,00,00,00,04,63,6F,72,65,00,00,00,3C,2D,72,77,2D,
< 2008-01-17 16:50:15.117 2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,20,31,38,36,34,38,38,20,4A,61,6E,20,31,37,20,20,32,30,30,
< 2008-01-17 16:50:15.117 33,20,63,6F,72,65,00,00,00,0F,00,00,00,00,00,02,D8,78,00,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,81,80,3E,27,D8,E0,3E,27,D8,E0,00,00,00,0E,64,6D,73,2D,74,65,6B,2D,
< 2008-01-17 16:50:15.117 62,61,63,6B,75,70,00,00,00,46,64,72,77,78,72,77,78,72,77,78,20,20,20,20,32,
< 2008-01-17 16:50:15.117 20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,20,20,20,35,
< 2008-01-17 16:50:15.117 31,32,20,53,65,70,20,20,34,20,31,35,3A,31,39,20,64,6D,73,2D,74,65,6B,2D,62,
< 2008-01-17 16:50:15.117 61,63,6B,75,70,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,
< 2008-01-17 16:50:15.117 00,00,41,FF,47,73,4D,DD,46,DD,3F,31,00,00,00,07,64,69,73,74,72,69,62,00,00,
< 2008-01-17 16:50:15.117 00,3F,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,
< 2008-01-17 16:50:15.117 20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,4D,61,79,20,31,
< 2008-01-17 16:50:15.117 35,20,20,32,30,30,33,20,64,69,73,74,72,69,62,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 02,00,00,00,00,00,00,00,00,01,00,00,41,ED,46,DD,3F,18,3E,C3,9A,E3,00,00,00,
< 2008-01-17 16:50:15.117 06,6F,72,61,63,6C,65,00,00,00,3E,64,72,77,78,72,2D,78,72,2D,78,20,20,20,31,
< 2008-01-17 16:50:15.117 30,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 35,31,32,20,41,70,72,20,20,39,20,20,32,30,30,35,20,6F,72,61,63,6C,65,00,00,
< 2008-01-17 16:50:15.117 00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,00,00,00,65,00,00,41,ED,47,8F,5B,
< 2008-01-17 16:50:15.117 EA,42,57,A3,6A,00,00,00,04,2E,73,73,68,00,00,00,3C,64,72,77,78,2D,2D,2D,2D,
< 2008-01-17 16:50:15.117 2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,35,31,32,20,41,75,67,20,31,39,20,20,32,30,30,34,20,2E,73,
< 2008-01-17 16:50:15.117 73,68,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,00,00,00,41,
< 2008-01-17 16:50:15.117 C0,43,56,4F,8A,41,24,39,83,00,00,00,0C,73,79,73,64,65,66,30,31,30,34,30,35,
< 2008-01-17 16:50:15.117 00,00,00,44,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2008-01-17 16:50:15.117 20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,31,33,35,36,34,20,41,70,72,
< 2008-01-17 16:50:15.117 20,20,31,20,20,32,30,30,35,20,73,79,73,64,65,66,30,31,30,34,30,35,00,00,00,
< 2008-01-17 16:50:15.117 0F,00,00,00,00,00,00,34,FC,00,00,00,00,00,00,00,01,00,00,81,A4,44,76,E7,87,
< 2008-01-17 16:50:15.117 42,4D,39,0A,00,00,00,07,73,75,6E,2E,6C,6F,67,00,00,00,3F,2D,72,77,2D,72,2D,
< 2008-01-17 16:50:15.117 20,20,20,20,20,20,34,36,35,35,36,20,46,65,62,20,20,37,20,20,32,30,30,37,20,
< 2008-01-17 16:50:15.117 73,75,6E,2E,6C,6F,67,00,00,00,0F,00,00,00,00,00,00,B5,DC,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,01,00,00,81,A4,45,C9,D9,F8,45,C9,D9,33,00,00,00,08,73,75,6E,32,2E,6C,6F,
< 2008-01-17 16:50:15.117 67,00,00,00,40,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,
< 2008-01-17 16:50:15.117 20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,34,32,36,39,38,20,46,65,
< 2008-01-17 16:50:15.117 62,20,20,37,20,20,32,30,30,37,20,73,75,6E,32,2E,6C,6F,67,00,00,00,0F,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,A6,CA,00,00,00,00,00,00,00,01,00,00,81,A4,45,C9,DA,67,45,C9,DA,
< 2008-01-17 16:50:15.117 43,00,00,00,12,2D,2D,6C,61,62,65,6C,3D,6E,63,69,6E,69,5F,66,69,6C,65,00,00,
< 2008-01-17 16:50:15.117 00,4A,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,
< 2008-01-17 16:50:15.117 20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,34,30,39,36,20,41,70,72,20,20,
< 2008-01-17 16:50:15.117 39,20,20,32,30,30,37,20,2D,2D,6C,61,62,65,6C,3D,6E,63,69,6E,69,5F,66,69,6C,
< 2008-01-17 16:50:15.117 65,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,01,00,00,81,A4,
< 2008-01-17 16:50:15.117 46,1A,18,04,46,1A,18,05,00,00,00,0D,2E,62,61,73,68,5F,70,72,6F,66,69,6C,65,
< 2008-01-17 16:50:15.117 00,00,00,45,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2008-01-17 16:50:15.117 20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,20,32,35,20,41,70,72,
< 2008-01-17 16:50:15.117 20,31,30,20,20,32,30,30,35,20,2E,62,61,73,68,5F,70,72,6F,66,69,6C,65,00,00,
< 2008-01-17 16:50:15.117 00,0F,00,00,00,00,00,00,00,19,00,00,00,00,00,00,00,01,00,00,81,A4,46,19,F9,
< 2008-01-17 16:50:15.117 14,42,59,20,59,00,00,00,09,6E,6F,68,75,70,2E,6F,75,74,00,00,00,41,2D,72,77,
< 2008-01-17 16:50:15.117 2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,
< 2008-01-17 16:50:15.117 65,72,20,20,20,20,20,20,20,20,20,20,20,30,20,4D,61,79,20,20,34,20,20,32,30,
< 2008-01-17 16:50:15.117 30,36,20,6E,6F,68,75,70,2E,6F,75,74,00,00,00,0F,00,00,00,00,00,00,00,00,00,
< 2008-01-17 16:50:15.117 00,00,00,00,00,00,01,00,00,81,A4,44,76,E7,83,44,59,90,57,00,00,00,04,74,6D,
< 2008-01-17 16:50:15.117 70,32,00,00,00,3C,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,
< 2008-01-17 16:50:15.117 74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,35,32,34,32,38,38,30,30,20,41,
< 2008-01-17 16:50:15.117 75,67,20,32,30,20,31,30,3A,33,35,20,74,6D,70,32,00,00,00,0F,00,00,00,00,03,
< 2008-01-17 16:50:15.117 20,00,00,00,00,00,00,00,00,00,01,00,00,81,A4,46,C9,36,19,46,C9,36,1C,00,00,
< 2008-01-17 16:50:15.117 00,04,6E,75,6C,6C,00,00,00,3C,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,
< 2008-01-17 16:50:15.117 20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:15.117 20,30,20,4A,61,6E,20,31,37,20,20,32,30,30,37,20,6E,75,6C,6C,00,00,00,0F,00,
< 2008-01-17 16:50:15.117 00,00,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,81,A4,45,AD,D5,DC,45,AD,
< 2008-01-17 16:50:15.117 D6,40,
> 2008-01-17 16:50:15.117 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
> 2008-01-17 16:50:15.117 0C,00,00,0C,0C,00,00,00,04,00,00,00,00,
. 2008-01-17 16:50:15.117 Sent 17 bytes
. 2008-01-17 16:50:15.117 There are 0 bytes remaining in the send buffer
. 2008-01-17 16:50:15.117 Looking for network events
. 2008-01-17 16:50:15.117 Timeout waiting for network events
. 2008-01-17 16:50:15.117 Reading symlink "bin".
> 2008-01-17 16:50:15.117 Type: SSH_FXP_READLINK, Size: 13, Number: 3347
> 2008-01-17 16:50:15.117 13,00,00,0D,13,00,00,00,04,2F,62,69,6E,
. 2008-01-17 16:50:15.117 Detected network event
. 2008-01-17 16:50:15.117 Enumerating network events for socket 732
. 2008-01-17 16:50:15.117 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:15.117 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:15.117 Received 32 bytes (0)
> 2008-01-17 16:50:15.117 Type: SSH_FXP_STAT, Size: 13, Number: 3601
> 2008-01-17 16:50:15.117 11,00,00,0E,11,00,00,00,04,2F,62,69,6E,
. 2008-01-17 16:50:15.117 Received 43 bytes (0)
. 2008-01-17 16:50:15.117 Read 4 bytes (71 pending)
. 2008-01-17 16:50:15.117 Read 28 bytes (43 pending)
< 2008-01-17 16:50:15.117 Type: SSH_FXP_STATUS, Size: 28, Number: 3084
< 2008-01-17 16:50:15.117 65,00,00,0C,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
. 2008-01-17 16:50:15.117 Storing reserved response
. 2008-01-17 16:50:15.117 Read 4 bytes (39 pending)
. 2008-01-17 16:50:15.117 Read 39 bytes (0 pending)
< 2008-01-17 16:50:15.117 Type: SSH_FXP_NAME, Size: 39, Number: 3347
< 2008-01-17 16:50:15.117 68,00,00,0D,13,00,00,00,01,00,00,00,09,2E,2F,75,73,72,2F,62,69,6E,00,00,00,
< 2008-01-17 16:50:15.117 09,2E,2F,75,73,72,2F,62,69,6E,00,00,00,00,
. 2008-01-17 16:50:15.117 Waiting for another 4 bytes
. 2008-01-17 16:50:15.117 Looking for incoming data
. 2008-01-17 16:50:15.117 Received 41 bytes (0)
. 2008-01-17 16:50:15.117 Read 4 bytes (37 pending)
. 2008-01-17 16:50:15.117 Read 37 bytes (0 pending)
< 2008-01-17 16:50:15.117 Type: SSH_FXP_ATTRS, Size: 37, Number: 3601
< 2008-01-17 16:50:15.117 69,00,00,0E,11,00,00,00,0F,00,00,00,00,00,00,24,00,00,00,00,00,00,00,00,02,
< 2008-01-17 16:50:15.117 00,00,41,ED,47,71,02,08,42,CB,FA,CB,
. 2008-01-17 16:50:15.117 Reading symlink "lib".
> 2008-01-17 16:50:15.117 Type: SSH_FXP_READLINK, Size: 13, Number: 3859
> 2008-01-17 16:50:15.117 13,00,00,0F,13,00,00,00,04,2F,6C,69,62,
> 2008-01-17 16:50:15.117 Type: SSH_FXP_STAT, Size: 13, Number: 4113
> 2008-01-17 16:50:15.117 11,00,00,10,11,00,00,00,04,2F,6C,69,62,
. 2008-01-17 16:50:15.133 Detected network event
. 2008-01-17 16:50:15.133 Enumerating network events for socket 732
. 2008-01-17 16:50:15.133 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:15.133 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:15.133 Received 43 bytes (0)
. 2008-01-17 16:50:15.133 Read 4 bytes (39 pending)
. 2008-01-17 16:50:15.133 Read 39 bytes (0 pending)
< 2008-01-17 16:50:15.133 Type: SSH_FXP_NAME, Size: 39, Number: 3859
< 2008-01-17 16:50:15.133 68,00,00,0F,13,00,00,00,01,00,00,00,09,2E,2F,75,73,72,2F,6C,69,62,00,00,00,
< 2008-01-17 16:50:15.133 09,2E,2F,75,73,72,2F,6C,69,62,00,00,00,00,
. 2008-01-17 16:50:15.133 Waiting for another 4 bytes
. 2008-01-17 16:50:15.133 Looking for incoming data
. 2008-01-17 16:50:15.133 Looking for network events
. 2008-01-17 16:50:15.133 Received 41 bytes (0)
. 2008-01-17 16:50:15.133 Read 4 bytes (37 pending)
. 2008-01-17 16:50:15.133 Read 37 bytes (0 pending)
< 2008-01-17 16:50:15.133 Type: SSH_FXP_ATTRS, Size: 37, Number: 4113
< 2008-01-17 16:50:15.133 69,00,00,10,11,00,00,00,0F,00,00,00,00,00,00,30,00,00,00,00,00,00,00,00,02,
< 2008-01-17 16:50:15.133 00,00,41,ED,46,C9,66,37,3D,3D,00,D9,
< 2008-01-17 16:50:15.133 Status/error code: 1
> 2008-01-17 16:50:15.133 Type: SSH_FXP_CLOSE, Size: 13, Number: 4356
> 2008-01-17 16:50:15.133 04,00,00,11,04,00,00,00,04,00,00,00,00,
. 2008-01-17 16:50:15.133 Sent 17 bytes
. 2008-01-17 16:50:15.133 There are 0 bytes remaining in the send buffer
. 2008-01-17 16:50:15.133 Timeout waiting for network events
. 2008-01-17 16:50:15.133 Startup conversation with host finished.
. 2008-01-17 16:50:15.226 Session upkeep
. 2008-01-17 16:50:15.226 Looking for network events
. 2008-01-17 16:50:15.226 Detected network event
. 2008-01-17 16:50:15.226 Enumerating network events for socket 732
. 2008-01-17 16:50:15.226 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:15.226 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:15.226 Received 28 bytes (0)
. 2008-01-17 16:50:15.258 Session upkeep
. 2008-01-17 16:50:15.258 Looking for network events
. 2008-01-17 16:50:15.258 Timeout waiting for network events
. 2008-01-17 16:50:15.758 Session upkeep
. 2008-01-17 16:50:15.758 Looking for network events
. 2008-01-17 16:50:15.758 Timeout waiting for network events
. 2008-01-17 16:50:16.258 Session upkeep
. 2008-01-17 16:50:16.258 Looking for network events
. 2008-01-17 16:50:16.258 Timeout waiting for network events
. 2008-01-17 16:50:16.758 Session upkeep
. 2008-01-17 16:50:16.758 Looking for network events
. 2008-01-17 16:50:16.758 Timeout waiting for network events
. 2008-01-17 16:50:17.258 Session upkeep
. 2008-01-17 16:50:17.258 Looking for network events
. 2008-01-17 16:50:17.258 Timeout waiting for network events
. 2008-01-17 16:50:17.461 Cached directory change via "u01" to "/u01".
. 2008-01-17 16:50:17.461 Getting current directory name.
. 2008-01-17 16:50:17.461 Listing directory "/u01".
> 2008-01-17 16:50:17.461 Type: SSH_FXP_OPENDIR, Size: 13, Number: 4619
> 2008-01-17 16:50:17.461 0B,00,00,12,0B,00,00,00,04,2F,75,30,31,
. 2008-01-17 16:50:17.461 Sent 17 bytes
. 2008-01-17 16:50:17.461 There are 0 bytes remaining in the send buffer
. 2008-01-17 16:50:17.461 Looking for network events
. 2008-01-17 16:50:17.461 Timeout waiting for network events
. 2008-01-17 16:50:17.461 Read 4 bytes (24 pending)
. 2008-01-17 16:50:17.461 Read 24 bytes (0 pending)
< 2008-01-17 16:50:17.461 Type: SSH_FXP_STATUS, Size: 24, Number: 4356
< 2008-01-17 16:50:17.461 65,00,00,11,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2008-01-17 16:50:17.461 Discarding reserved response
. 2008-01-17 16:50:17.461 Waiting for another 4 bytes
. 2008-01-17 16:50:17.461 Looking for incoming data
. 2008-01-17 16:50:17.461 Detected network event
. 2008-01-17 16:50:17.461 Enumerating network events for socket 732
. 2008-01-17 16:50:17.461 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:17.461 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:17.461 Received 17 bytes (0)
. 2008-01-17 16:50:17.461 Read 4 bytes (13 pending)
. 2008-01-17 16:50:17.461 Read 13 bytes (0 pending)
< 2008-01-17 16:50:17.461 Type: SSH_FXP_HANDLE, Size: 13, Number: 4619
< 2008-01-17 16:50:17.461 66,00,00,12,0B,00,00,00,04,00,00,00,00,
> 2008-01-17 16:50:17.461 Type: SSH_FXP_READDIR, Size: 13, Number: 4876
> 2008-01-17 16:50:17.461 0C,00,00,13,0C,00,00,00,04,00,00,00,00,
. 2008-01-17 16:50:17.461 Received 1129 bytes (0)
. 2008-01-17 16:50:17.461 Read 4 bytes (1125 pending)
. 2008-01-17 16:50:17.461 Read 1125 bytes (0 pending)
< 2008-01-17 16:50:17.461 Type: SSH_FXP_NAME, Size: 1125, Number: 4876
< 2008-01-17 16:50:17.461 68,00,00,13,0C,00,00,00,0A,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,77,78,
< 2008-01-17 16:50:17.461 72,77,78,20,20,20,31,30,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,
< 2008-01-17 16:50:17.461 20,20,20,20,20,20,20,35,31,32,20,4E,6F,76,20,20,38,20,20,32,30,30,36,20,2E,
< 2008-01-17 16:50:17.461 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,
< 2008-01-17 16:50:17.461 8F,5C,00,45,51,BD,80,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,78,72,
< 2008-01-17 16:50:17.461 2D,78,20,20,20,33,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2008-01-17 16:50:17.461 20,20,20,20,20,31,30,32,34,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,2E,2E,
< 2008-01-17 16:50:17.461 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,47,
< 2008-01-17 16:50:17.461 8F,5B,FE,47,6B,8D,DD,00,00,00,0A,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,42,
< 2008-01-17 16:50:17.461 64,72,77,78,72,77,78,72,77,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,
< 2008-01-17 16:50:17.461 72,6F,6F,74,20,20,20,20,20,20,20,20,20,38,31,39,32,20,4A,75,6C,20,32,32,20,
< 2008-01-17 16:50:17.461 20,32,30,30,32,20,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,0F,00,00,00,00,00,
< 2008-01-17 16:50:17.461 00,20,00,00,00,00,00,00,00,00,00,00,00,41,FF,47,73,4E,EF,3D,3C,0E,49,00,00,
< 2008-01-17 16:50:17.461 00,05,69,73,69,64,61,00,00,00,3D,64,72,77,78,72,77,78,72,77,78,20,20,20,20,
< 2008-01-17 16:50:17.461 37,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:17.461 35,31,32,20,44,65,63,20,32,31,20,31,37,3A,34,35,20,69,73,69,64,61,00,00,00,
< 2008-01-17 16:50:17.461 0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,82,AE,FE,
< 2008-01-17 16:50:17.461 47,6B,D1,87,00,00,00,08,64,61,74,61,62,61,73,65,00,00,00,40,64,72,77,78,72,
< 2008-01-17 16:50:17.461 77,78,72,77,78,20,20,20,20,33,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,
< 2008-01-17 16:50:17.461 20,20,20,20,20,20,20,20,20,35,31,32,20,44,65,63,20,32,31,20,31,39,3A,33,31,
< 2008-01-17 16:50:17.461 20,64,61,74,61,62,61,73,65,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,
< 2008-01-17 16:50:17.461 00,00,00,65,00,00,41,FF,47,73,4E,B8,47,6B,EA,5A,00,00,00,0D,64,61,74,61,62,
< 2008-01-17 16:50:17.461 61,73,65,5F,32,36,30,38,00,00,00,45,64,72,77,78,72,77,78,72,77,78,20,20,20,
< 2008-01-17 16:50:17.461 20,33,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,20,20,
< 2008-01-17 16:50:17.461 20,35,31,32,20,41,75,67,20,32,36,20,20,32,30,30,33,20,64,61,74,61,62,61,73,
< 2008-01-17 16:50:17.461 65,5F,32,36,30,38,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,
< 2008-01-17 16:50:17.461 64,00,00,41,FF,47,73,4E,B9,3F,4B,16,05,00,00,00,03,74,6D,70,00,00,00,3B,64,
< 2008-01-17 16:50:17.461 72,77,78,72,77,78,72,77,78,20,20,20,20,32,20,69,73,69,64,61,20,20,20,20,69,
< 2008-01-17 16:50:17.461 73,69,64,61,20,20,20,20,20,20,20,20,32,35,36,30,20,41,75,67,20,32,30,20,31,
< 2008-01-17 16:50:17.461 30,3A,33,33,20,74,6D,70,00,00,00,0F,00,00,00,00,00,00,0A,00,00,00,00,64,00,
< 2008-01-17 16:50:17.461 00,00,64,00,00,41,FF,47,73,4E,F3,46,C9,35,BC,00,00,00,10,69,73,69,64,61,5F,
< 2008-01-17 16:50:17.461 6C,6F,67,5F,62,61,63,6B,75,70,00,00,00,48,64,72,77,78,72,2D,78,72,2D,78,20,
< 2008-01-17 16:50:17.461 20,20,20,32,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,
< 2008-01-17 16:50:17.461 20,20,20,35,31,32,20,4A,61,6E,20,33,31,20,20,32,30,30,35,20,69,73,69,64,61,
< 2008-01-17 16:50:17.461 5F,6C,6F,67,5F,62,61,63,6B,75,70,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,
< 2008-01-17 16:50:17.461 00,64,00,00,00,64,00,00,41,ED,47,73,4E,EB,41,FD,ED,5D,00,00,00,0E,64,6D,73,
< 2008-01-17 16:50:17.461 2D,74,65,6B,2D,62,61,63,6B,75,70,00,00,00,46,64,72,77,78,72,77,78,72,77,78,
< 2008-01-17 16:50:17.461 20,20,20,20,33,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,
< 2008-01-17 16:50:17.461 20,20,20,31,30,32,34,20,4A,61,6E,20,31,36,20,32,32,3A,31,33,20,64,6D,73,2D,
< 2008-01-17 16:50:17.461 74,65,6B,2D,62,61,63,6B,75,70,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,
< 2008-01-17 16:50:17.461 64,00,00,00,64,00,00,41,FF,47,8E,FD,DE,47,8E,57,4D,00,00,00,06,6F,72,61,63,
< 2008-01-17 16:50:17.461 6C,65,00,00,00,3E,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,6F,72,61,
< 2008-01-17 16:50:17.461 63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,41,
< 2008-01-17 16:50:17.461 70,72,20,20,39,20,20,32,30,30,35,20,6F,72,61,63,6C,65,00,00,00,0F,00,00,00,
< 2008-01-17 16:50:17.461 00,00,00,02,00,00,00,00,AB,00,00,00,65,00,00,41,ED,47,73,4E,F1,42,57,A3,5C,
> 2008-01-17 16:50:17.461 Type: SSH_FXP_READDIR, Size: 13, Number: 5132
> 2008-01-17 16:50:17.461 0C,00,00,14,0C,00,00,00,04,00,00,00,00,
. 2008-01-17 16:50:17.461 Received 32 bytes (0)
. 2008-01-17 16:50:17.461 Read 4 bytes (28 pending)
. 2008-01-17 16:50:17.461 Read 28 bytes (0 pending)
< 2008-01-17 16:50:17.461 Type: SSH_FXP_STATUS, Size: 28, Number: 5132
< 2008-01-17 16:50:17.461 65,00,00,14,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2008-01-17 16:50:17.461 Status/error code: 1
> 2008-01-17 16:50:17.461 Type: SSH_FXP_CLOSE, Size: 13, Number: 5380
> 2008-01-17 16:50:17.461 04,00,00,15,04,00,00,00,04,00,00,00,00,
. 2008-01-17 16:50:17.758 Session upkeep
. 2008-01-17 16:50:17.758 Looking for network events
. 2008-01-17 16:50:17.758 Detected network event
. 2008-01-17 16:50:17.758 Enumerating network events for socket 732
. 2008-01-17 16:50:17.758 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:17.758 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:17.758 Received 28 bytes (0)
. 2008-01-17 16:50:18.258 Session upkeep
. 2008-01-17 16:50:18.258 Looking for network events
. 2008-01-17 16:50:18.258 Timeout waiting for network events
. 2008-01-17 16:50:18.758 Session upkeep
. 2008-01-17 16:50:18.758 Looking for network events
. 2008-01-17 16:50:18.758 Timeout waiting for network events
. 2008-01-17 16:50:19.258 Session upkeep
. 2008-01-17 16:50:19.258 Looking for network events
. 2008-01-17 16:50:19.258 Timeout waiting for network events
. 2008-01-17 16:50:19.758 Session upkeep
. 2008-01-17 16:50:19.758 Looking for network events
. 2008-01-17 16:50:19.758 Timeout waiting for network events
. 2008-01-17 16:50:19.930 Cached directory change via "dms-tek-backup" to "/u01/dms-tek-backup".
. 2008-01-17 16:50:19.930 Getting current directory name.
. 2008-01-17 16:50:19.930 Listing directory "/u01/dms-tek-backup".
> 2008-01-17 16:50:19.930 Type: SSH_FXP_OPENDIR, Size: 28, Number: 5643
> 2008-01-17 16:50:19.930 0B,00,00,16,0B,00,00,00,13,2F,75,30,31,2F,64,6D,73,2D,74,65,6B,2D,62,61,63,
> 2008-01-17 16:50:19.930 6B,75,70,
. 2008-01-17 16:50:19.930 Sent 32 bytes
. 2008-01-17 16:50:19.930 There are 0 bytes remaining in the send buffer
. 2008-01-17 16:50:19.930 Looking for network events
. 2008-01-17 16:50:19.930 Timeout waiting for network events
. 2008-01-17 16:50:19.930 Read 4 bytes (24 pending)
. 2008-01-17 16:50:19.930 Read 24 bytes (0 pending)
< 2008-01-17 16:50:19.930 Type: SSH_FXP_STATUS, Size: 24, Number: 5380
< 2008-01-17 16:50:19.930 65,00,00,15,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2008-01-17 16:50:19.930 Discarding reserved response
. 2008-01-17 16:50:19.930 Waiting for another 4 bytes
. 2008-01-17 16:50:19.930 Looking for incoming data
. 2008-01-17 16:50:19.930 Detected network event
. 2008-01-17 16:50:19.930 Enumerating network events for socket 732
. 2008-01-17 16:50:19.930 Enumerated 1 network events making 1 cumulative events for socket 732
. 2008-01-17 16:50:19.930 Handling network read event on socket 732 with error 0
. 2008-01-17 16:50:19.930 Received 17 bytes (0)
. 2008-01-17 16:50:19.930 Read 4 bytes (13 pending)
. 2008-01-17 16:50:19.930 Read 13 bytes (0 pending)
< 2008-01-17 16:50:19.930 Type: SSH_FXP_HANDLE, Size: 13, Number: 5643
< 2008-01-17 16:50:19.930 66,00,00,16,0B,00,00,00,04,00,00,00,00,
> 2008-01-17 16:50:19.930 Type: SSH_FXP_READDIR, Size: 13, Number: 5900
> 2008-01-17 16:50:19.930 0C,00,00,17,0C,00,00,00,04,00,00,00,00,
. 2008-01-17 16:50:19.930 Sent 17 bytes
. 2008-01-17 16:50:19.930 Received 1903 bytes (0)
. 2008-01-17 16:50:19.930 Read 4 bytes (1899 pending)
. 2008-01-17 16:50:19.930 Read 1899 bytes (0 pending)
< 2008-01-17 16:50:19.930 Type: SSH_FXP_NAME, Size: 1899, Number: 5900
< 2008-01-17 16:50:19.945 68,00,00,17,0C,00,00,00,0F,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,77,78,
< 2008-01-17 16:50:19.945 72,77,78,20,20,20,20,33,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,
< 2008-01-17 16:50:19.945 20,20,20,20,20,20,31,30,32,34,20,4A,61,6E,20,31,36,20,32,32,3A,31,33,20,2E,
< 2008-01-17 16:50:19.945 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,
< 2008-01-17 16:50:19.945 8F,5C,03,47,8E,57,4D,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,77,78,72,
< 2008-01-17 16:50:19.945 77,78,20,20,20,31,30,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,
< 2008-01-17 16:50:19.945 20,20,20,20,20,20,35,31,32,20,4E,6F,76,20,20,38,20,20,32,30,30,36,20,2E,2E,
< 2008-01-17 16:50:19.945 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,
< 2008-01-17 16:50:19.945 8F,5C,00,45,51,BD,80,00,00,00,05,64,2E,6C,6F,67,00,00,00,3D,2D,72,77,2D,72,
< 2008-01-17 16:50:19.945 2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,
< 2008-01-17 16:50:19.945 20,20,20,20,20,20,20,20,20,20,20,30,20,41,75,67,20,20,33,20,20,32,30,30,35,
< 2008-01-17 16:50:19.945 20,64,2E,6C,6F,67,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,AB,00,00,00,
< 2008-01-17 16:50:19.945 65,00,00,81,A4,47,8E,FD,95,42,F0,A6,AC,00,00,00,04,63,6F,72,65,00,00,00,3C,
< 2008-01-17 16:50:19.945 2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,20,
< 2008-01-17 16:50:19.945 64,62,61,20,20,20,20,20,20,20,31,35,32,34,31,39,36,20,44,65,63,20,31,38,20,
< 2008-01-17 16:50:19.945 31,34,3A,34,33,20,63,6F,72,65,00,00,00,0F,00,00,00,00,00,17,41,E4,00,00,00,
< 2008-01-17 16:50:19.945 AB,00,00,00,65,00,00,81,80,47,67,B2,66,47,67,B2,66,00,00,00,11,64,62,2E,62,
< 2008-01-17 16:50:19.945 61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,00,00,00,49,2D,72,77,2D,72,2D,2D,72,
< 2008-01-17 16:50:19.945 2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,20,20,20,
< 2008-01-17 16:50:19.945 20,33,34,34,35,33,30,36,31,20,4A,61,6E,20,31,36,20,32,32,3A,31,33,20,64,62,
< 2008-01-17 16:50:19.945 2E,62,61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,00,00,00,0F,00,00,00,00,02,0D,
< 2008-01-17 16:50:19.945 B6,45,00,00,00,AB,00,00,00,65,00,00,81,A4,47,73,4D,FA,47,8E,57,5B,00,00,00,
< 2008-01-17 16:50:19.945 15,64,62,2E,62,61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,2E,6F,6C,64,00,00,00,
< 2008-01-17 16:50:19.945 4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,
< 2008-01-17 16:50:19.945 20,64,62,61,20,20,20,20,20,20,32,38,39,39,37,38,32,37,20,4F,63,74,20,31,31,
< 2008-01-17 16:50:19.945 20,20,32,30,30,36,20,64,62,2E,62,61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,2E,
< 2008-01-17 16:50:19.945 6F,6C,64,00,00,00,0F,00,00,00,00,01,BA,78,C3,00,00,00,AB,00,00,00,65,00,00,
< 2008-01-17 16:50:19.945 81,A4,47,6B,64,47,45,2C,A6,D3,00,00,00,0D,64,62,2E,62,61,63,6B,75,70,2E,6C,
< 2008-01-17 16:50:19.945 6F,67,00,00,00,45,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,
< 2008-01-17 16:50:19.945 63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,36,36,37,39,32,20,4A,
< 2008-01-17 16:50:19.945 61,6E,20,31,36,20,32,31,3A,33,35,20,64,62,2E,62,61,63,6B,75,70,2E,6C,6F,67,
< 2008-01-17 16:50:19.945 00,00,00,0F,00,00,00,00,00,01,04,E8,00,00,00,AB,00,00,00,65,00,00,81,A4,47,
< 2008-01-17 16:50:19.945 8E,FD,9C,47,8E,4E,8E,00,00,00,11,62,61,63,6B,75,70,2D,32,30,30,37,2D,31,32,
< 2008-01-17 16:50:19.945 2D,32,31,00,00,00,49,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,6F,72,
< 2008-01-17 16:50:19.945 61,63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,
< 2008-01-17 16:50:19.945 44,65,63,20,32,34,20,31,38,3A,30,32,20,62,61,63,6B,75,70,2D,32,30,30,37,2D,
< 2008-01-17 16:50:19.945 31,32,2D,32,31,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,00,00,00,65,
< 2008-01-17 16:50:19.945 00,00,41,ED,47,8E,FD,8C,47,6F,C9,EE,00,00,00,15,69,73,69,64,61,6C,6F,67,5F,
< 2008-01-17 16:50:19.945 30,38,2E,30,31,2E,30,38,2E,74,61,72,00,00,00,4D,2D,72,77,2D,72,2D,2D,72,2D,
< 2008-01-17 16:50:19.945 2D,20,20,20,20,31,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,
< 2008-01-17 16:50:19.945 35,35,32,36,30,31,36,30,20,4A,61,6E,20,20,38,20,30,32,3A,30,30,20,69,73,69,
< 2008-01-17 16:50:19.945 64,61,6C,6F,67,5F,30,38,2E,30,31,2E,30,38,2E,74,61,72,00,00,00,0F,00,00,00,
< 2008-01-17 16:50:19.945 00,03,4B,34,00,00,00,00,64,00,00,00,64,00,00,81,A4,47,82,AF,01,47,82,AF,04,
< 2008-01-17 16:50:19.945 00,00,00,13,64,62,2E,62,61,63,6B,75,70,2E,73,74,6F,75,74,2E,6C,6F,67,00,00,
< 2008-01-17 16:50:19.945 00,4B,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,
< 2008-01-17 16:50:19.945 20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,20,20,30,20,41,75,67,20,20,
< 2008-01-17 16:50:19.945 38,20,20,32,30,30,35,20,64,62,2E,62,61,63,6B,75,70,2E,73,74,6F,75,74,2E,6C,
< 2008-01-17 16:50:19.945 6F,67,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,AB,00,00,00,65,00,00,81,
< 2008-01-17 16:50:19.945 A4,47,73,4D,F2,42,F7,8F,90,00,00,00,15,69,73,69,64,61,6C,6F,67,5F,30,31,2E,
< 2008-01-17 16:50:19.945 31,30,2E,30,37,2E,74,61,72,00,00,00,4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,
< 2008-01-17 16:50:19.945 20,20,31,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,36,33,37,
< 2008-01-17 16:50:19.945 37,31,31,33,36,20,4F,63,74,20,20,31,20,30,32,3A,30,30,20,69,73,69,64,61,6C,
< 2008-01-17 16:50:19.945 6F,67,5F,30,31,2E,31,30,2E,30,37,2E,74,61,72,00,00,00,0F,00,00,00,00,03,CD,
< 2008-01-17 16:50:19.945 12,00,00,00,00,64,00,00,00,64,00,00,81,A4,47,00,1C,71,47,00,1C,74,00,00,00,
< 2008-01-17 16:50:19.945 15,69,73,69,64,61,6C,6F,67,5F,32,39,2E,31,30,2E,30,37,2E,74,61,72,00,00,00,
< 2008-01-17 16:50:19.945 4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,69,
I'm sorry, but it looks like the log file was truncated. The directory listing packet is at the very end, but it is not complete. It contains only following files:
d.log
core
db.backup.err.log
db.backup.err.log.old
db.backup.log
backup-2007-12-21
isidalog_08.01.08.tar
db.backup.stout.log
isidalog_01.10.07.tar
isidalog_29.10.07.tar (incomplete record)
_MMX_
OK, I'll try to get log one more time on monday. But for me it was alsow very strange, that listing was at the end of the file. On monday i'll try to switch to that directory, then to any other, then logoff. Or, maybe, you have other ideas about actions, that i have to make in this conditions?
_MMX_
. 2008-01-21 10:00:21.257 --------------------------------------------------------------------------
. 2008-01-21 10:00:21.257 WinSCP Version 4.0.6 (Build 358) (OS 5.0.2195 Service Pack 4)
. 2008-01-21 10:00:21.257 Login time: Monday, January 21, 2008 10:00:21 AM
. 2008-01-21 10:00:21.257 Session name: root@192.168.2.12
. 2008-01-21 10:00:21.257 Host name: 192.168.2.12 (Port: 22)
. 2008-01-21 10:00:21.257 User name: root (Password: No, Key file: No)
. 2008-01-21 10:00:21.257 Tunnel: No
. 2008-01-21 10:00:21.257 Transfer Protocol: SFTP (SCP)
. 2008-01-21 10:00:21.257 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-01-21 10:00:21.257 Proxy: none
. 2008-01-21 10:00:21.257 SSH protocol version: 2; Compression: No
. 2008-01-21 10:00:21.257 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-01-21 10:00:21.257 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-01-21 10:00:21.257 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-01-21 10:00:21.257 SFTP Bugs: -,-,-
. 2008-01-21 10:00:21.257 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-01-21 10:00:21.257 Shell: default, EOL: 0
. 2008-01-21 10:00:21.257 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-01-21 10:00:21.257 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-01-21 10:00:21.257 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-01-21 10:00:21.257 Cache directory changes: Yes, Permanent: Yes
. 2008-01-21 10:00:21.257 DST mode: 1
. 2008-01-21 10:00:21.272 Looking up host "192.168.2.12"
. 2008-01-21 10:00:21.272 Connecting to 192.168.2.12 port 22
. 2008-01-21 10:00:21.288 Selecting events 63 for socket 744
. 2008-01-21 10:00:21.288 Waiting for the server to continue with the initialisation
. 2008-01-21 10:00:21.288 Looking for incoming data
. 2008-01-21 10:00:21.288 Looking for network events
. 2008-01-21 10:00:21.288 Detected network event
. 2008-01-21 10:00:21.288 Enumerating network events for socket 744
. 2008-01-21 10:00:21.288 Enumerated 18 network events making 18 cumulative events for socket 744
. 2008-01-21 10:00:21.288 Handling network write event on socket 744 with error 0
. 2008-01-21 10:00:21.288 Handling network connect event on socket 744 with error 0
. 2008-01-21 10:00:21.304 Detected network event
. 2008-01-21 10:00:21.304 Enumerating network events for socket 744
. 2008-01-21 10:00:21.304 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:21.304 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:21.304 Server version: SSH-1.99-OpenSSH_2.9p2
. 2008-01-21 10:00:21.304 We believe remote version has SSH-2 RSA padding bug
. 2008-01-21 10:00:21.304 We claim version: SSH-2.0-WinSCP_release_4.0.6
. 2008-01-21 10:00:21.304 Using SSH protocol version 2
. 2008-01-21 10:00:21.304 Waiting for the server to continue with the initialisation
. 2008-01-21 10:00:21.304 Looking for incoming data
. 2008-01-21 10:00:21.304 Looking for network events
. 2008-01-21 10:00:21.304 Doing Diffie-Hellman group exchange
. 2008-01-21 10:00:21.429 Detected network event
. 2008-01-21 10:00:21.429 Enumerating network events for socket 744
. 2008-01-21 10:00:21.429 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:21.429 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:21.429 Doing Diffie-Hellman key exchange
. 2008-01-21 10:00:21.616 Waiting for the server to continue with the initialisation
. 2008-01-21 10:00:21.616 Looking for incoming data
. 2008-01-21 10:00:21.616 Looking for network events
. 2008-01-21 10:00:21.679 Detected network event
. 2008-01-21 10:00:21.679 Enumerating network events for socket 744
. 2008-01-21 10:00:21.679 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:21.679 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:21.897 Selecting events 63 for socket 744
. 2008-01-21 10:00:21.897 Host key fingerprint is:
. 2008-01-21 10:00:21.897 ssh-rsa 1024 b3:a5:fe:2f:5b:60:39:13:0a:6a:71:a9:c3:cc:6f:b3
. 2008-01-21 10:00:21.897 Initialised AES-256 client->server encryption
. 2008-01-21 10:00:21.897 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-01-21 10:00:21.897 Initialised AES-256 server->client encryption
. 2008-01-21 10:00:21.897 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-01-21 10:00:21.897 Waiting for the server to continue with the initialisation
. 2008-01-21 10:00:21.897 Looking for incoming data
. 2008-01-21 10:00:21.897 Looking for network events
. 2008-01-21 10:00:21.991 Detected network event
. 2008-01-21 10:00:21.991 Enumerating network events for socket 744
. 2008-01-21 10:00:21.991 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:21.991 Handling network read event on socket 744 with error 0
! 2008-01-21 10:00:21.991 Using username "root".
. 2008-01-21 10:00:21.991 Waiting for the server to continue with the initialisation
. 2008-01-21 10:00:21.991 Looking for incoming data
. 2008-01-21 10:00:21.991 Looking for network events
. 2008-01-21 10:00:21.991 Keyboard-interactive authentication refused
. 2008-01-21 10:00:21.991 Session password prompt (root@192.168.2.12's password: )
. 2008-01-21 10:00:27.085 Sent password
. 2008-01-21 10:00:27.085 Waiting for the server to continue with the initialisation
. 2008-01-21 10:00:27.085 Looking for incoming data
. 2008-01-21 10:00:27.085 Looking for network events
. 2008-01-21 10:00:27.085 Detected network event
. 2008-01-21 10:00:27.085 Enumerating network events for socket 744
. 2008-01-21 10:00:27.085 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:27.085 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:27.085 Access granted
. 2008-01-21 10:00:27.085 Opened channel for session
. 2008-01-21 10:00:27.101 Detected network event
. 2008-01-21 10:00:27.101 Enumerating network events for socket 744
. 2008-01-21 10:00:27.101 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:27.101 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:27.101 Started a shell/command
. 2008-01-21 10:00:27.101 --------------------------------------------------------------------------
. 2008-01-21 10:00:27.101 Using SFTP protocol.
. 2008-01-21 10:00:27.101 Doing startup conversation with host.
> 2008-01-21 10:00:27.101 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2008-01-21 10:00:27.101 01,00,00,00,05,
. 2008-01-21 10:00:27.101 Sent 9 bytes
. 2008-01-21 10:00:27.101 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:27.101 Looking for network events
. 2008-01-21 10:00:27.101 Timeout waiting for network events
. 2008-01-21 10:00:27.101 Waiting for another 4 bytes
. 2008-01-21 10:00:27.101 Looking for incoming data
. 2008-01-21 10:00:27.163 Detected network event
. 2008-01-21 10:00:27.163 Enumerating network events for socket 744
. 2008-01-21 10:00:27.163 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:27.163 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:27.163 Received 9 bytes (0)
. 2008-01-21 10:00:27.163 Read 4 bytes (5 pending)
. 2008-01-21 10:00:27.163 Read 5 bytes (0 pending)
< 2008-01-21 10:00:27.163 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2008-01-21 10:00:27.163 02,00,00,00,03,
. 2008-01-21 10:00:27.163 SFTP version 3 negotiated.
. 2008-01-21 10:00:27.163 We believe the server has signed timestamps bug
. 2008-01-21 10:00:27.163 We will use UTF-8 strings for status messages only
. 2008-01-21 10:00:27.163 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2008-01-21 10:00:27.163 Getting current directory name.
. 2008-01-21 10:00:27.163 Getting real path for '.'
> 2008-01-21 10:00:27.163 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2008-01-21 10:00:27.163 10,00,00,00,10,00,00,00,01,2E,
. 2008-01-21 10:00:27.163 Sent 14 bytes
. 2008-01-21 10:00:27.163 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:27.163 Looking for network events
. 2008-01-21 10:00:27.163 Timeout waiting for network events
. 2008-01-21 10:00:27.163 Waiting for another 4 bytes
. 2008-01-21 10:00:27.163 Looking for incoming data
. 2008-01-21 10:00:27.163 Received 27 bytes (0)
. 2008-01-21 10:00:27.163 Read 4 bytes (23 pending)
. 2008-01-21 10:00:27.163 Read 23 bytes (0 pending)
< 2008-01-21 10:00:27.163 Type: SSH_FXP_NAME, Size: 23, Number: 16
< 2008-01-21 10:00:27.163 68,00,00,00,10,00,00,00,01,00,00,00,01,2F,00,00,00,01,2F,00,00,00,00,
. 2008-01-21 10:00:27.163 Real path is '/'
. 2008-01-21 10:00:27.163 Listing directory "/".
> 2008-01-21 10:00:27.163 Type: SSH_FXP_OPENDIR, Size: 10, Number: 267
> 2008-01-21 10:00:27.163 0B,00,00,01,0B,00,00,00,01,2F,
. 2008-01-21 10:00:27.163 Received 17 bytes (0)
. 2008-01-21 10:00:27.163 Read 4 bytes (13 pending)
. 2008-01-21 10:00:27.163 Read 13 bytes (0 pending)
< 2008-01-21 10:00:27.163 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
< 2008-01-21 10:00:27.163 66,00,00,01,0B,00,00,00,04,00,00,00,00,
> 2008-01-21 10:00:27.163 Type: SSH_FXP_READDIR, Size: 13, Number: 524
> 2008-01-21 10:00:27.163 0C,00,00,02,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:27.163 Sent 17 bytes
. 2008-01-21 10:00:27.179 Detected network event
. 2008-01-21 10:00:27.179 Enumerating network events for socket 744
. 2008-01-21 10:00:27.179 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:27.179 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:27.179 Received 5781 bytes (0)
. 2008-01-21 10:00:27.179 Read 4 bytes (5777 pending)
. 2008-01-21 10:00:27.179 Read 5777 bytes (0 pending)
< 2008-01-21 10:00:27.179 Type: SSH_FXP_NAME, Size: 5777, Number: 524
< 2008-01-21 10:00:27.194 68,00,00,02,0C,00,00,00,35,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,
< 2008-01-21 10:00:27.194 72,2D,78,20,20,20,33,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,31,30,32,34,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,2E,
< 2008-01-21 10:00:27.194 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,47,
< 2008-01-21 10:00:27.194 94,41,F1,47,6B,8D,DD,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,78,72,
< 2008-01-21 10:00:27.194 2D,78,20,20,20,33,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,31,30,32,34,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,2E,2E,
< 2008-01-21 10:00:27.194 94,41,F1,47,6B,8D,DD,00,00,00,0A,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,42,
< 2008-01-21 10:00:27.194 64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,
< 2008-01-21 10:00:27.194 72,6F,6F,74,20,20,20,20,20,20,20,20,20,38,31,39,32,20,4A,75,6C,20,32,32,20,
< 2008-01-21 10:00:27.194 20,32,30,30,32,20,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,0F,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,20,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,C9,64,43,3D,3B,DB,A7,00,00,
< 2008-01-21 10:00:27.194 00,03,76,61,72,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,33,30,20,
< 2008-01-21 10:00:27.194 72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,
< 2008-01-21 10:00:27.194 32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,76,61,72,00,00,00,0F,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,71,0A,39,3D,3B,E2,E9,
< 2008-01-21 10:00:27.194 00,00,00,03,75,73,72,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,33,
< 2008-01-21 10:00:27.194 34,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,31,
< 2008-01-21 10:00:27.194 30,32,34,20,4D,61,79,20,31,35,20,20,32,30,30,33,20,75,73,72,00,00,00,0F,00,
< 2008-01-21 10:00:27.194 00,00,00,00,00,04,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,71,0A,2F,3E,C3,
< 2008-01-21 10:00:27.194 A0,E1,00,00,00,03,65,74,63,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,
< 2008-01-21 10:00:27.194 20,34,32,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,33,35,38,34,20,4A,61,6E,20,31,34,20,31,37,3A,35,35,20,65,74,63,00,00,00,
< 2008-01-21 10:00:27.194 0F,00,00,00,00,00,00,0E,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,84,9A,F9,
< 2008-01-21 10:00:27.194 47,8B,77,FE,00,00,00,03,62,69,6E,00,00,00,3B,6C,72,77,78,72,77,78,72,77,78,
< 2008-01-21 10:00:27.194 20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,39,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,62,69,6E,00,
< 2008-01-21 10:00:27.194 00,00,0F,00,00,00,00,00,00,00,09,00,00,00,00,00,00,00,00,00,00,A1,FF,47,93,
< 2008-01-21 10:00:27.194 E7,88,3D,3B,DC,5E,00,00,00,03,64,65,76,00,00,00,3B,64,72,77,78,72,2D,78,72,
< 2008-01-21 10:00:27.194 2D,78,20,20,20,31,34,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,35,31,32,30,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,64,65,
< 2008-01-21 10:00:27.194 76,00,00,00,0F,00,00,00,00,00,00,14,00,00,00,00,00,00,00,00,03,00,00,41,ED,
< 2008-01-21 10:00:27.194 47,6B,8E,02,47,6B,8D,D8,00,00,00,07,64,65,76,69,63,65,73,00,00,00,3F,64,72,
< 2008-01-21 10:00:27.194 77,78,72,2D,78,72,2D,78,20,20,20,20,36,20,72,6F,6F,74,20,20,20,20,20,73,79,
< 2008-01-21 10:00:27.194 73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,
< 2008-01-21 10:00:27.194 30,30,32,20,64,65,76,69,63,65,73,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,00,03,00,00,41,ED,46,DD,3F,14,3D,3B,DF,B0,00,00,00,06,6B,65,72,
< 2008-01-21 10:00:27.194 6E,65,6C,00,00,00,3E,64,72,77,78,72,2D,78,72,2D,78,20,20,20,31,31,20,72,6F,
< 2008-01-21 10:00:27.194 6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,
< 2008-01-21 10:00:27.194 4A,75,6C,20,32,33,20,20,32,30,30,32,20,6B,65,72,6E,65,6C,00,00,00,0F,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,71,01,F5,3D,3C,FE,
< 2008-01-21 10:00:27.194 FF,00,00,00,03,6C,69,62,00,00,00,3B,6C,72,77,78,72,77,78,72,77,78,20,20,20,
< 2008-01-21 10:00:27.194 20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,39,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,6C,69,62,00,00,00,0F,
< 2008-01-21 10:00:27.194 00,00,00,00,00,00,00,09,00,00,00,00,00,00,00,00,00,00,A1,FF,47,8F,5D,C0,3D,
< 2008-01-21 10:00:27.194 3B,DC,5F,00,00,00,03,6D,6E,74,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,
< 2008-01-21 10:00:27.194 20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,35,31,32,20,4A,75,6E,20,32,38,20,20,32,30,30,34,20,6D,6E,74,00,00,
< 2008-01-21 10:00:27.194 00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,47,84,9A,
< 2008-01-21 10:00:27.194 F6,40,E0,19,B4,00,00,00,03,6F,70,74,00,00,00,3B,64,72,77,78,72,77,78,72,2D,
< 2008-01-21 10:00:27.194 78,20,20,20,20,37,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,35,31,32,20,4A,75,6E,20,32,34,20,20,32,30,30,35,20,6F,70,74,
< 2008-01-21 10:00:27.194 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,FD,44,
< 2008-01-21 10:00:27.194 76,E7,45,42,BB,A6,05,00,00,00,04,70,72,6F,63,00,00,00,3C,64,72,2D,78,72,2D,
< 2008-01-21 10:00:27.194 78,72,2D,78,20,20,20,35,37,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,36,31,31,32,30,20,4A,61,6E,20,32,31,20,30,39,3A,35,35,20,
< 2008-01-21 10:00:27.194 70,72,6F,63,00,00,00,0F,00,00,00,00,00,00,EE,C0,00,00,00,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,41,6D,47,94,41,F1,47,94,41,F1,00,00,00,04,73,62,69,6E,00,00,00,3C,64,72,
< 2008-01-21 10:00:27.194 77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,73,79,
< 2008-01-21 10:00:27.194 73,20,20,20,20,20,20,20,20,20,20,31,30,32,34,20,4F,63,74,20,31,38,20,20,32,
< 2008-01-21 10:00:27.194 30,30,32,20,73,62,69,6E,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,00,03,00,00,41,ED,47,61,2F,EC,3D,B0,04,F2,00,00,00,03,74,6D,70,00,00,00,
< 2008-01-21 10:00:27.194 3B,64,72,77,78,72,77,78,72,77,74,20,20,20,20,34,20,72,6F,6F,74,20,20,20,20,
< 2008-01-21 10:00:27.194 20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,32,37,32,20,4A,61,6E,20,32,31,
< 2008-01-21 10:00:27.194 20,30,33,3A,33,30,20,74,6D,70,00,00,00,0F,00,00,00,00,00,00,01,10,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,03,00,00,43,FF,47,6B,8E,02,47,93,E7,88,00,00,00,04,62,6F,6F,74,
< 2008-01-21 10:00:27.194 00,00,00,3C,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,34,20,72,6F,6F,74,20,
< 2008-01-21 10:00:27.194 20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,4A,75,6C,
< 2008-01-21 10:00:27.194 20,32,32,20,20,32,30,30,32,20,62,6F,6F,74,00,00,00,0F,00,00,00,00,00,00,02,
< 2008-01-21 10:00:27.194 00,00,00,00,00,00,00,00,03,00,00,41,ED,46,1A,08,B3,3D,3B,DC,B8,00,00,00,08,
< 2008-01-21 10:00:27.194 70,6C,61,74,66,6F,72,6D,00,00,00,40,64,72,77,78,72,2D,78,72,2D,78,20,20,20,
< 2008-01-21 10:00:27.194 20,34,20,72,6F,6F,74,20,20,20,20,20,73,79,73,20,20,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,70,6C,61,74,66,6F,72,
< 2008-01-21 10:00:27.194 6D,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,03,00,00,41,ED,
< 2008-01-21 10:00:27.194 47,84,9A,F0,3D,3B,DC,D4,00,00,00,03,6E,65,74,00,00,00,3B,64,72,2D,78,72,2D,
< 2008-01-21 10:00:27.194 78,72,2D,78,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,20,20,20,31,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,
< 2008-01-21 10:00:27.194 6E,65,74,00,00,00,0F,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 41,6D,47,6B,8D,DC,47,6B,8D,DC,00,00,00,06,65,78,70,6F,72,74,00,00,00,3E,64,
< 2008-01-21 10:00:27.194 72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,73,
< 2008-01-21 10:00:27.194 79,73,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,20,35,20,20,
< 2008-01-21 10:00:27.194 32,30,30,32,20,65,78,70,6F,72,74,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,00,03,00,00,41,ED,47,93,8C,20,3D,4E,6F,65,00,00,00,04,68,6F,6D,
< 2008-01-21 10:00:27.194 65,00,00,00,3C,64,72,2D,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,6F,6F,74,
< 2008-01-21 10:00:27.194 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,31,20,44,65,
< 2008-01-21 10:00:27.194 63,20,32,31,20,31,32,3A,35,36,20,68,6F,6D,65,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,01,00,00,00,00,00,00,00,00,00,00,41,6D,47,6B,8D,DC,47,6B,8D,DC,00,00,00,
< 2008-01-21 10:00:27.194 02,64,74,00,00,00,3A,64,72,77,78,72,77,78,72,2D,78,20,20,20,20,32,20,72,6F,
< 2008-01-21 10:00:27.194 6F,74,20,20,20,20,20,62,69,6E,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,
< 2008-01-21 10:00:27.194 4A,75,6C,20,32,32,20,20,32,30,30,32,20,64,74,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 02,00,00,00,00,00,00,00,00,02,00,00,41,FD,46,1F,2E,D9,3D,3B,DF,7F,00,00,00,
< 2008-01-21 10:00:27.194 03,78,66,6E,00,00,00,3B,64,72,2D,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,
< 2008-01-21 10:00:27.194 6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,31,
< 2008-01-21 10:00:27.194 20,44,65,63,20,32,31,20,31,32,3A,35,36,20,78,66,6E,00,00,00,0F,00,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,01,00,00,00,00,00,00,00,00,00,00,41,6D,47,6B,8D,DC,47,6B,8D,DC,00,
< 2008-01-21 10:00:27.194 00,00,03,76,6F,6C,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,
< 2008-01-21 10:00:27.194 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,35,
< 2008-01-21 10:00:27.194 31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,76,6F,6C,00,00,00,0F,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,02,00,00,00,00,00,00,00,00,00,00,00,41,ED,44,76,E7,7B,3D,3B,E2,
< 2008-01-21 10:00:27.194 23,00,00,00,05,54,54,5F,44,42,00,00,00,3D,64,72,77,78,72,2D,78,72,2D,78,20,
< 2008-01-21 10:00:27.194 20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,54,54,5F,44,42,
< 2008-01-21 10:00:27.194 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,
< 2008-01-21 10:00:27.194 1A,07,55,3D,3B,E2,2A,00,00,00,05,63,64,72,6F,6D,00,00,00,3D,64,72,77,78,72,
< 2008-01-21 10:00:27.194 2D,78,72,2D,78,20,20,20,20,34,20,72,6F,6F,74,20,20,20,20,20,6E,6F,62,6F,64,
< 2008-01-21 10:00:27.194 79,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,31,34,20,20,32,30,30,33,
< 2008-01-21 10:00:27.194 20,63,64,72,6F,6D,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,EA,
< 2008-01-21 10:00:27.194 61,00,00,41,ED,47,6B,E1,BB,3F,3B,96,0F,00,00,00,03,2E,64,74,00,00,00,3B,64,
< 2008-01-21 10:00:27.194 72,77,78,72,2D,78,72,2D,78,20,20,20,31,31,20,72,6F,6F,74,20,20,20,20,20,6F,
< 2008-01-21 10:00:27.194 74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,31,34,20,20,
< 2008-01-21 10:00:27.194 32,30,30,33,20,2E,64,74,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,00,01,00,00,41,ED,47,73,4E,FD,3F,3B,90,C9,00,00,00,0A,2E,64,74,70,72,6F,
< 2008-01-21 10:00:27.194 66,69,6C,65,00,00,00,42,2D,72,77,78,72,2D,78,72,2D,78,20,20,20,20,31,20,72,
< 2008-01-21 10:00:27.194 6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,35,31,31,31,
< 2008-01-21 10:00:27.194 20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,2E,64,74,70,72,6F,66,69,6C,65,00,
< 2008-01-21 10:00:27.194 00,00,0F,00,00,00,00,00,00,13,F7,00,00,00,00,00,00,00,01,00,00,81,ED,42,BB,
< 2008-01-21 10:00:27.194 A6,BD,3D,3B,E8,29,00,00,00,04,64,61,74,61,00,00,00,3C,64,72,77,78,72,2D,78,
< 2008-01-21 10:00:27.194 72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,35,31,32,20,4A,75,6C,20,32,32,20,20,32,30,30,32,20,64,
< 2008-01-21 10:00:27.194 61,74,61,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,01,00,00,
< 2008-01-21 10:00:27.194 41,ED,46,1A,08,B0,3D,3C,10,85,00,00,00,09,2E,6E,65,74,73,63,61,70,65,00,00,
< 2008-01-21 10:00:27.194 00,41,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,35,20,72,6F,6F,74,20,20,20,
< 2008-01-21 10:00:27.194 20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,41,75,67,20,20,
< 2008-01-21 10:00:27.194 35,20,20,32,30,30,32,20,2E,6E,65,74,73,63,61,70,65,00,00,00,0F,00,00,00,00,
< 2008-01-21 10:00:27.194 00,00,02,00,00,00,00,00,00,00,00,01,00,00,41,C0,43,56,4F,7B,3D,4E,50,A1,00,
< 2008-01-21 10:00:27.194 00,00,0B,2E,58,61,75,74,68,6F,72,69,74,79,00,00,00,43,2D,72,77,2D,2D,2D,2D,
< 2008-01-21 10:00:27.194 2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,32,35,35,20,41,75,67,20,31,34,20,20,32,30,30,33,20,2E,
< 2008-01-21 10:00:27.194 58,61,75,74,68,6F,72,69,74,79,00,00,00,0F,00,00,00,00,00,00,00,FF,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,01,00,00,81,80,3F,3B,90,CB,3F,3B,90,C5,00,00,00,06,6E,73,6D,61,
< 2008-01-21 10:00:27.194 69,6C,00,00,00,3E,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,
< 2008-01-21 10:00:27.194 74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,4A,
< 2008-01-21 10:00:27.194 75,6C,20,32,33,20,20,32,30,30,32,20,6E,73,6D,61,69,6C,00,00,00,0F,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,02,00,00,00,00,00,00,00,00,01,00,00,41,C0,43,56,4F,7B,3D,3C,EC,D9,
< 2008-01-21 10:00:27.194 00,00,00,0C,2E,54,54,61,75,74,68,6F,72,69,74,79,00,00,00,44,2D,72,77,2D,2D,
< 2008-01-21 10:00:27.194 2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,20,20,31,34,37,20,41,75,67,20,31,34,20,20,32,30,30,33,
< 2008-01-21 10:00:27.194 20,2E,54,54,61,75,74,68,6F,72,69,74,79,00,00,00,0F,00,00,00,00,00,00,00,93,
< 2008-01-21 10:00:27.194 00,00,00,00,00,00,00,01,00,00,81,80,3F,3B,90,CA,3F,3B,90,C9,00,00,00,04,74,
< 2008-01-21 10:00:27.194 65,6D,70,00,00,00,3C,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,
< 2008-01-21 10:00:27.194 6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,34,35,35,34,30,20,
< 2008-01-21 10:00:27.194 4D,61,72,20,31,34,20,20,32,30,30,36,20,74,65,6D,70,00,00,00,0F,00,00,00,00,
< 2008-01-21 10:00:27.194 00,00,B1,E4,00,00,00,00,00,00,00,01,00,00,81,A4,46,19,F9,1C,44,16,96,D8,00,
< 2008-01-21 10:00:27.194 00,00,0D,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,45,2D,72,77,2D,2D,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,20,31,36,37,37,20,4A,61,6E,20,31,34,20,31,37,3A,35,37,
< 2008-01-21 10:00:27.194 20,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,00,0F,00,00,00,00,00,00,06,
< 2008-01-21 10:00:27.194 8D,00,00,00,00,00,00,00,01,00,00,81,80,47,8B,78,61,47,8B,78,61,00,00,00,0F,
< 2008-01-21 10:00:27.194 2E,73,6D,63,2E,70,72,6F,70,65,72,74,69,65,73,00,00,00,47,2D,72,77,2D,72,2D,
< 2008-01-21 10:00:27.194 2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,31,31,38,36,20,41,75,67,20,20,35,20,20,32,30,30,32,20,
< 2008-01-21 10:00:27.194 2E,73,6D,63,2E,70,72,6F,70,65,72,74,69,65,73,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 04,A2,00,00,00,00,00,00,00,01,00,00,81,A4,3D,4E,46,74,3D,4E,46,74,00,00,00,
< 2008-01-21 10:00:27.194 12,64,6D,73,2D,74,65,6B,2D,65,6E,65,72,67,6F,73,62,79,74,00,00,00,4A,64,72,
< 2008-01-21 10:00:27.194 77,78,72,2D,78,72,2D,78,20,20,20,32,33,20,69,73,69,64,61,20,20,20,20,69,73,
< 2008-01-21 10:00:27.194 69,64,61,20,20,20,20,20,20,20,20,31,30,32,34,20,46,65,62,20,32,37,20,20,32,
< 2008-01-21 10:00:27.194 30,30,36,20,64,6D,73,2D,74,65,6B,2D,65,6E,65,72,67,6F,73,62,79,74,00,00,00,
< 2008-01-21 10:00:27.194 0F,00,00,00,00,00,00,04,00,00,00,00,64,00,00,00,64,00,00,41,ED,47,93,7F,C0,
< 2008-01-21 10:00:27.194 44,03,1E,9C,00,00,00,07,64,6D,73,2D,74,65,6B,00,00,00,3F,64,72,77,78,72,2D,
< 2008-01-21 10:00:27.194 78,72,2D,78,20,20,20,20,32,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,20,35,31,32,20,4A,61,6E,20,33,31,20,20,32,30,30,35,20,
< 2008-01-21 10:00:27.194 64,6D,73,2D,74,65,6B,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,
< 2008-01-21 10:00:27.194 00,64,00,00,41,ED,46,C9,71,B2,41,FD,F3,77,00,00,00,0B,2E,73,68,5F,68,69,73,
< 2008-01-21 10:00:27.194 74,6F,72,79,00,00,00,43,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,
< 2008-01-21 10:00:27.194 6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,31,33,30,32,32,
< 2008-01-21 10:00:27.194 20,4A,61,6E,20,32,30,20,20,32,30,30,34,20,2E,73,68,5F,68,69,73,74,6F,72,79,
< 2008-01-21 10:00:27.194 00,00,00,0F,00,00,00,00,00,00,32,DE,00,00,00,00,00,00,00,01,00,00,81,80,40,
< 2008-01-21 10:00:27.194 0D,6B,E3,40,0D,6B,E3,00,00,00,03,75,30,31,00,00,00,3B,64,72,77,78,72,77,78,
< 2008-01-21 10:00:27.194 72,77,78,20,20,20,31,30,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,35,31,32,20,4E,6F,76,20,20,38,20,20,32,30,30,36,20,75,
< 2008-01-21 10:00:27.194 30,31,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,
< 2008-01-21 10:00:27.194 FF,47,93,9D,2E,45,51,BD,80,00,00,00,04,63,6F,72,65,00,00,00,3C,2D,72,77,2D,
< 2008-01-21 10:00:27.194 2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,20,31,38,36,34,38,38,20,4A,61,6E,20,31,37,20,20,32,30,30,
< 2008-01-21 10:00:27.194 33,20,63,6F,72,65,00,00,00,0F,00,00,00,00,00,02,D8,78,00,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,81,80,3E,27,D8,E0,3E,27,D8,E0,00,00,00,0E,64,6D,73,2D,74,65,6B,2D,
< 2008-01-21 10:00:27.194 62,61,63,6B,75,70,00,00,00,46,64,72,77,78,72,77,78,72,77,78,20,20,20,20,32,
< 2008-01-21 10:00:27.194 20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,20,20,20,35,
< 2008-01-21 10:00:27.194 31,32,20,53,65,70,20,20,34,20,31,35,3A,31,39,20,64,6D,73,2D,74,65,6B,2D,62,
< 2008-01-21 10:00:27.194 61,63,6B,75,70,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,
< 2008-01-21 10:00:27.194 00,00,41,FF,47,8F,62,29,46,DD,3F,31,00,00,00,07,64,69,73,74,72,69,62,00,00,
< 2008-01-21 10:00:27.194 00,3F,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,
< 2008-01-21 10:00:27.194 20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,35,31,32,20,4D,61,79,20,31,
< 2008-01-21 10:00:27.194 35,20,20,32,30,30,33,20,64,69,73,74,72,69,62,00,00,00,0F,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 02,00,00,00,00,00,00,00,00,01,00,00,41,ED,46,DD,3F,18,3E,C3,9A,E3,00,00,00,
< 2008-01-21 10:00:27.194 06,6F,72,61,63,6C,65,00,00,00,3E,64,72,77,78,72,2D,78,72,2D,78,20,20,20,31,
< 2008-01-21 10:00:27.194 30,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 35,31,32,20,41,70,72,20,20,39,20,20,32,30,30,35,20,6F,72,61,63,6C,65,00,00,
< 2008-01-21 10:00:27.194 00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,00,00,00,65,00,00,41,ED,47,94,41,
< 2008-01-21 10:00:27.194 E5,42,57,A3,6A,00,00,00,04,2E,73,73,68,00,00,00,3C,64,72,77,78,2D,2D,2D,2D,
< 2008-01-21 10:00:27.194 2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,35,31,32,20,41,75,67,20,31,39,20,20,32,30,30,34,20,2E,73,
< 2008-01-21 10:00:27.194 73,68,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,00,00,00,41,
< 2008-01-21 10:00:27.194 C0,47,8F,5E,1E,41,24,39,83,00,00,00,0C,73,79,73,64,65,66,30,31,30,34,30,35,
< 2008-01-21 10:00:27.194 00,00,00,44,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2008-01-21 10:00:27.194 20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,31,33,35,36,34,20,41,70,72,
< 2008-01-21 10:00:27.194 20,20,31,20,20,32,30,30,35,20,73,79,73,64,65,66,30,31,30,34,30,35,00,00,00,
< 2008-01-21 10:00:27.194 0F,00,00,00,00,00,00,34,FC,00,00,00,00,00,00,00,01,00,00,81,A4,44,76,E7,87,
< 2008-01-21 10:00:27.194 42,4D,39,0A,00,00,00,07,73,75,6E,2E,6C,6F,67,00,00,00,3F,2D,72,77,2D,72,2D,
< 2008-01-21 10:00:27.194 20,20,20,20,20,20,34,36,35,35,36,20,46,65,62,20,20,37,20,20,32,30,30,37,20,
< 2008-01-21 10:00:27.194 73,75,6E,2E,6C,6F,67,00,00,00,0F,00,00,00,00,00,00,B5,DC,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,01,00,00,81,A4,45,C9,D9,F8,45,C9,D9,33,00,00,00,08,73,75,6E,32,2E,6C,6F,
< 2008-01-21 10:00:27.194 67,00,00,00,40,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,
< 2008-01-21 10:00:27.194 20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,34,32,36,39,38,20,46,65,
< 2008-01-21 10:00:27.194 62,20,20,37,20,20,32,30,30,37,20,73,75,6E,32,2E,6C,6F,67,00,00,00,0F,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,A6,CA,00,00,00,00,00,00,00,01,00,00,81,A4,45,C9,DA,67,45,C9,DA,
< 2008-01-21 10:00:27.194 43,00,00,00,12,2D,2D,6C,61,62,65,6C,3D,6E,63,69,6E,69,5F,66,69,6C,65,00,00,
< 2008-01-21 10:00:27.194 00,4A,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,
< 2008-01-21 10:00:27.194 20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,34,30,39,36,20,41,70,72,20,20,
< 2008-01-21 10:00:27.194 39,20,20,32,30,30,37,20,2D,2D,6C,61,62,65,6C,3D,6E,63,69,6E,69,5F,66,69,6C,
< 2008-01-21 10:00:27.194 65,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,01,00,00,81,A4,
< 2008-01-21 10:00:27.194 46,1A,18,04,46,1A,18,05,00,00,00,0D,2E,62,61,73,68,5F,70,72,6F,66,69,6C,65,
< 2008-01-21 10:00:27.194 00,00,00,45,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2008-01-21 10:00:27.194 20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,20,32,35,20,41,70,72,
< 2008-01-21 10:00:27.194 20,31,30,20,20,32,30,30,35,20,2E,62,61,73,68,5F,70,72,6F,66,69,6C,65,00,00,
< 2008-01-21 10:00:27.194 00,0F,00,00,00,00,00,00,00,19,00,00,00,00,00,00,00,01,00,00,81,A4,46,19,F9,
< 2008-01-21 10:00:27.194 14,42,59,20,59,00,00,00,09,6E,6F,68,75,70,2E,6F,75,74,00,00,00,41,2D,72,77,
< 2008-01-21 10:00:27.194 2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,6F,74,68,
< 2008-01-21 10:00:27.194 65,72,20,20,20,20,20,20,20,20,20,20,20,30,20,4D,61,79,20,20,34,20,20,32,30,
< 2008-01-21 10:00:27.194 30,36,20,6E,6F,68,75,70,2E,6F,75,74,00,00,00,0F,00,00,00,00,00,00,00,00,00,
< 2008-01-21 10:00:27.194 00,00,00,00,00,00,01,00,00,81,A4,44,76,E7,83,44,59,90,57,00,00,00,04,74,6D,
< 2008-01-21 10:00:27.194 70,32,00,00,00,3C,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,
< 2008-01-21 10:00:27.194 74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,35,32,34,32,38,38,30,30,20,41,
< 2008-01-21 10:00:27.194 75,67,20,32,30,20,31,30,3A,33,35,20,74,6D,70,32,00,00,00,0F,00,00,00,00,03,
< 2008-01-21 10:00:27.194 20,00,00,00,00,00,00,00,00,00,01,00,00,81,A4,46,C9,36,19,46,C9,36,1C,00,00,
< 2008-01-21 10:00:27.194 00,04,6E,75,6C,6C,00,00,00,3C,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,
< 2008-01-21 10:00:27.194 20,72,6F,6F,74,20,20,20,20,20,6F,74,68,65,72,20,20,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:27.194 20,30,20,4A,61,6E,20,31,37,20,20,32,30,30,37,20,6E,75,6C,6C,00,00,00,0F,00,
< 2008-01-21 10:00:27.194 00,00,00,00,00,00,00,00,00,00,00,00,00,00,01,00,00,81,A4,45,AD,D5,DC,45,AD,
< 2008-01-21 10:00:27.194 D6,40,
> 2008-01-21 10:00:27.194 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2008-01-21 10:00:27.194 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:27.194 Sent 17 bytes
. 2008-01-21 10:00:27.194 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:27.194 Looking for network events
. 2008-01-21 10:00:27.194 Timeout waiting for network events
. 2008-01-21 10:00:27.194 Reading symlink "bin".
> 2008-01-21 10:00:27.210 Type: SSH_FXP_READLINK, Size: 13, Number: 1043
> 2008-01-21 10:00:27.210 13,00,00,04,13,00,00,00,04,2F,62,69,6E,
. 2008-01-21 10:00:27.210 Sent 17 bytes
. 2008-01-21 10:00:27.210 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:27.210 Looking for network events
. 2008-01-21 10:00:27.210 Detected network event
. 2008-01-21 10:00:27.210 Enumerating network events for socket 744
. 2008-01-21 10:00:27.210 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:27.210 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:27.210 Received 32 bytes (0)
> 2008-01-21 10:00:27.210 Type: SSH_FXP_STAT, Size: 13, Number: 1297
> 2008-01-21 10:00:27.210 11,00,00,05,11,00,00,00,04,2F,62,69,6E,
. 2008-01-21 10:00:27.210 Received 43 bytes (0)
. 2008-01-21 10:00:27.210 Read 4 bytes (71 pending)
. 2008-01-21 10:00:27.210 Read 28 bytes (43 pending)
< 2008-01-21 10:00:27.210 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2008-01-21 10:00:27.210 65,00,00,03,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2008-01-21 10:00:27.210 00,00,00,
. 2008-01-21 10:00:27.210 Storing reserved response
. 2008-01-21 10:00:27.210 Read 4 bytes (39 pending)
. 2008-01-21 10:00:27.210 Read 39 bytes (0 pending)
< 2008-01-21 10:00:27.210 Type: SSH_FXP_NAME, Size: 39, Number: 1043
< 2008-01-21 10:00:27.210 68,00,00,04,13,00,00,00,01,00,00,00,09,2E,2F,75,73,72,2F,62,69,6E,00,00,00,
< 2008-01-21 10:00:27.210 09,2E,2F,75,73,72,2F,62,69,6E,00,00,00,00,
. 2008-01-21 10:00:27.210 Waiting for another 4 bytes
. 2008-01-21 10:00:27.210 Looking for incoming data
. 2008-01-21 10:00:27.210 Received 41 bytes (0)
. 2008-01-21 10:00:27.210 Read 4 bytes (37 pending)
. 2008-01-21 10:00:27.210 Read 37 bytes (0 pending)
< 2008-01-21 10:00:27.210 Type: SSH_FXP_ATTRS, Size: 37, Number: 1297
< 2008-01-21 10:00:27.210 69,00,00,05,11,00,00,00,0F,00,00,00,00,00,00,24,00,00,00,00,00,00,00,00,02,
< 2008-01-21 10:00:27.210 00,00,41,ED,47,71,02,08,42,CB,FA,CB,
. 2008-01-21 10:00:27.210 Reading symlink "lib".
> 2008-01-21 10:00:27.210 Type: SSH_FXP_READLINK, Size: 13, Number: 1555
> 2008-01-21 10:00:27.210 13,00,00,06,13,00,00,00,04,2F,6C,69,62,
. 2008-01-21 10:00:27.210 Timeout waiting for network events
> 2008-01-21 10:00:27.210 Type: SSH_FXP_STAT, Size: 13, Number: 1809
> 2008-01-21 10:00:27.210 11,00,00,07,11,00,00,00,04,2F,6C,69,62,
. 2008-01-21 10:00:27.210 Read 4 bytes (80 pending)
. 2008-01-21 10:00:27.210 Read 39 bytes (41 pending)
< 2008-01-21 10:00:27.210 Type: SSH_FXP_NAME, Size: 39, Number: 1555
< 2008-01-21 10:00:27.210 68,00,00,06,13,00,00,00,01,00,00,00,09,2E,2F,75,73,72,2F,6C,69,62,00,00,00,
< 2008-01-21 10:00:27.210 09,2E,2F,75,73,72,2F,6C,69,62,00,00,00,00,
< 2008-01-21 10:00:27.210 Type: SSH_FXP_ATTRS, Size: 37, Number: 1809
< 2008-01-21 10:00:27.210 69,00,00,07,11,00,00,00,0F,00,00,00,00,00,00,30,00,00,00,00,00,00,00,00,02,
< 2008-01-21 10:00:27.210 00,00,41,ED,46,C9,66,37,3D,3D,00,D9,
< 2008-01-21 10:00:27.210 Status/error code: 1
> 2008-01-21 10:00:27.210 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
> 2008-01-21 10:00:27.210 04,00,00,08,04,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:27.210 Startup conversation with host finished.
. 2008-01-21 10:00:27.913 Session upkeep
. 2008-01-21 10:00:27.913 Looking for network events
. 2008-01-21 10:00:27.913 Detected network event
. 2008-01-21 10:00:27.913 Enumerating network events for socket 744
. 2008-01-21 10:00:27.913 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:27.913 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:27.913 Received 28 bytes (0)
. 2008-01-21 10:00:28.413 Session upkeep
. 2008-01-21 10:00:28.413 Looking for network events
. 2008-01-21 10:00:28.413 Timeout waiting for network events
. 2008-01-21 10:00:28.913 Session upkeep
. 2008-01-21 10:00:28.913 Looking for network events
. 2008-01-21 10:00:28.913 Timeout waiting for network events
. 2008-01-21 10:00:29.210 Cached directory change via ".." to "/".
. 2008-01-21 10:00:29.210 Getting current directory name.
. 2008-01-21 10:00:29.272 Directory content loaded from cache.
. 2008-01-21 10:00:29.413 Session upkeep
. 2008-01-21 10:00:29.413 Looking for network events
. 2008-01-21 10:00:29.413 Timeout waiting for network events
. 2008-01-21 10:00:29.913 Session upkeep
. 2008-01-21 10:00:29.913 Looking for network events
. 2008-01-21 10:00:29.913 Timeout waiting for network events
. 2008-01-21 10:00:30.413 Session upkeep
. 2008-01-21 10:00:30.413 Looking for network events
. 2008-01-21 10:00:30.413 Timeout waiting for network events
. 2008-01-21 10:00:30.913 Session upkeep
. 2008-01-21 10:00:30.913 Looking for network events
. 2008-01-21 10:00:30.913 Timeout waiting for network events
. 2008-01-21 10:00:31.413 Session upkeep
. 2008-01-21 10:00:31.413 Looking for network events
. 2008-01-21 10:00:31.413 Timeout waiting for network events
. 2008-01-21 10:00:31.913 Session upkeep
. 2008-01-21 10:00:31.913 Looking for network events
. 2008-01-21 10:00:31.913 Timeout waiting for network events
. 2008-01-21 10:00:32.335 Cached directory change via "u01" to "/u01".
. 2008-01-21 10:00:32.335 Getting current directory name.
. 2008-01-21 10:00:32.335 Listing directory "/u01".
> 2008-01-21 10:00:32.335 Type: SSH_FXP_OPENDIR, Size: 13, Number: 2315
> 2008-01-21 10:00:32.335 0B,00,00,09,0B,00,00,00,04,2F,75,30,31,
. 2008-01-21 10:00:32.335 Sent 17 bytes
. 2008-01-21 10:00:32.335 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:32.335 Looking for network events
. 2008-01-21 10:00:32.335 Timeout waiting for network events
. 2008-01-21 10:00:32.335 Read 4 bytes (24 pending)
. 2008-01-21 10:00:32.335 Read 24 bytes (0 pending)
< 2008-01-21 10:00:32.335 Type: SSH_FXP_STATUS, Size: 24, Number: 2052
< 2008-01-21 10:00:32.335 65,00,00,08,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2008-01-21 10:00:32.351 Discarding reserved response
. 2008-01-21 10:00:32.351 Waiting for another 4 bytes
. 2008-01-21 10:00:32.351 Looking for incoming data
. 2008-01-21 10:00:32.351 Looking for network events
. 2008-01-21 10:00:32.351 Detected network event
. 2008-01-21 10:00:32.351 Enumerating network events for socket 744
. 2008-01-21 10:00:32.351 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:32.351 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:32.351 Received 17 bytes (0)
. 2008-01-21 10:00:32.351 Read 4 bytes (13 pending)
. 2008-01-21 10:00:32.351 Read 13 bytes (0 pending)
< 2008-01-21 10:00:32.351 Type: SSH_FXP_HANDLE, Size: 13, Number: 2315
< 2008-01-21 10:00:32.351 66,00,00,09,0B,00,00,00,04,00,00,00,00,
> 2008-01-21 10:00:32.351 Type: SSH_FXP_READDIR, Size: 13, Number: 2572
> 2008-01-21 10:00:32.351 0C,00,00,0A,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:32.351 Sent 17 bytes
. 2008-01-21 10:00:32.351 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:32.351 Timeout waiting for network events
. 2008-01-21 10:00:32.351 Received 1129 bytes (0)
. 2008-01-21 10:00:32.351 Read 4 bytes (1125 pending)
. 2008-01-21 10:00:32.351 Read 1125 bytes (0 pending)
< 2008-01-21 10:00:32.351 Type: SSH_FXP_NAME, Size: 1125, Number: 2572
< 2008-01-21 10:00:32.351 68,00,00,0A,0C,00,00,00,0A,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,77,78,
< 2008-01-21 10:00:32.351 72,77,78,20,20,20,31,30,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,
< 2008-01-21 10:00:32.351 20,20,20,20,20,20,20,35,31,32,20,4E,6F,76,20,20,38,20,20,32,30,30,36,20,2E,
< 2008-01-21 10:00:32.351 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,
< 2008-01-21 10:00:32.351 94,41,F6,45,51,BD,80,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,78,72,
< 2008-01-21 10:00:32.351 2D,78,20,20,20,33,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2008-01-21 10:00:32.351 20,20,20,20,20,31,30,32,34,20,44,65,63,20,32,31,20,31,32,3A,35,36,20,2E,2E,
< 2008-01-21 10:00:32.351 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,00,00,00,00,00,00,00,41,ED,47,
< 2008-01-21 10:00:32.351 94,41,F1,47,6B,8D,DD,00,00,00,0A,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,42,
< 2008-01-21 10:00:32.351 64,72,77,78,72,77,78,72,77,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,
< 2008-01-21 10:00:32.351 72,6F,6F,74,20,20,20,20,20,20,20,20,20,38,31,39,32,20,4A,75,6C,20,32,32,20,
< 2008-01-21 10:00:32.351 20,32,30,30,32,20,6C,6F,73,74,2B,66,6F,75,6E,64,00,00,00,0F,00,00,00,00,00,
< 2008-01-21 10:00:32.351 00,20,00,00,00,00,00,00,00,00,00,00,00,41,FF,47,73,4E,EF,3D,3C,0E,49,00,00,
< 2008-01-21 10:00:32.351 00,05,69,73,69,64,61,00,00,00,3D,64,72,77,78,72,77,78,72,77,78,20,20,20,20,
< 2008-01-21 10:00:32.351 37,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:32.351 35,31,32,20,44,65,63,20,32,31,20,31,37,3A,34,35,20,69,73,69,64,61,00,00,00,
< 2008-01-21 10:00:32.351 0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,82,AE,FE,
< 2008-01-21 10:00:32.351 47,6B,D1,87,00,00,00,08,64,61,74,61,62,61,73,65,00,00,00,40,64,72,77,78,72,
< 2008-01-21 10:00:32.351 77,78,72,77,78,20,20,20,20,33,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,
< 2008-01-21 10:00:32.351 20,20,20,20,20,20,20,20,20,35,31,32,20,44,65,63,20,32,31,20,31,39,3A,33,31,
< 2008-01-21 10:00:32.351 20,64,61,74,61,62,61,73,65,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,
< 2008-01-21 10:00:32.351 00,00,00,65,00,00,41,FF,47,73,4E,B8,47,6B,EA,5A,00,00,00,0D,64,61,74,61,62,
< 2008-01-21 10:00:32.351 61,73,65,5F,32,36,30,38,00,00,00,45,64,72,77,78,72,77,78,72,77,78,20,20,20,
< 2008-01-21 10:00:32.351 20,33,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,20,20,
< 2008-01-21 10:00:32.351 20,35,31,32,20,41,75,67,20,32,36,20,20,32,30,30,33,20,64,61,74,61,62,61,73,
< 2008-01-21 10:00:32.351 65,5F,32,36,30,38,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,
< 2008-01-21 10:00:32.351 64,00,00,41,FF,47,73,4E,B9,3F,4B,16,05,00,00,00,03,74,6D,70,00,00,00,3B,64,
< 2008-01-21 10:00:32.351 72,77,78,72,77,78,72,77,78,20,20,20,20,32,20,69,73,69,64,61,20,20,20,20,69,
< 2008-01-21 10:00:32.351 73,69,64,61,20,20,20,20,20,20,20,20,32,35,36,30,20,41,75,67,20,32,30,20,31,
< 2008-01-21 10:00:32.351 30,3A,33,33,20,74,6D,70,00,00,00,0F,00,00,00,00,00,00,0A,00,00,00,00,64,00,
< 2008-01-21 10:00:32.351 00,00,64,00,00,41,FF,47,73,4E,F3,46,C9,35,BC,00,00,00,10,69,73,69,64,61,5F,
< 2008-01-21 10:00:32.351 6C,6F,67,5F,62,61,63,6B,75,70,00,00,00,48,64,72,77,78,72,2D,78,72,2D,78,20,
< 2008-01-21 10:00:32.351 20,20,20,32,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,20,
< 2008-01-21 10:00:32.351 20,20,20,35,31,32,20,4A,61,6E,20,33,31,20,20,32,30,30,35,20,69,73,69,64,61,
< 2008-01-21 10:00:32.351 5F,6C,6F,67,5F,62,61,63,6B,75,70,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,
< 2008-01-21 10:00:32.351 00,64,00,00,00,64,00,00,41,ED,47,73,4E,EB,41,FD,ED,5D,00,00,00,0E,64,6D,73,
< 2008-01-21 10:00:32.351 2D,74,65,6B,2D,62,61,63,6B,75,70,00,00,00,46,64,72,77,78,72,77,78,72,77,78,
< 2008-01-21 10:00:32.351 20,20,20,20,33,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,20,
< 2008-01-21 10:00:32.351 20,20,20,31,30,32,34,20,4A,61,6E,20,32,30,20,32,32,3A,31,32,20,64,6D,73,2D,
< 2008-01-21 10:00:32.351 74,65,6B,2D,62,61,63,6B,75,70,00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,
< 2008-01-21 10:00:32.351 64,00,00,00,64,00,00,41,FF,47,93,9D,38,47,93,9D,30,00,00,00,06,6F,72,61,63,
< 2008-01-21 10:00:32.351 6C,65,00,00,00,3E,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,6F,72,61,
< 2008-01-21 10:00:32.351 63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,41,
< 2008-01-21 10:00:32.351 70,72,20,20,39,20,20,32,30,30,35,20,6F,72,61,63,6C,65,00,00,00,0F,00,00,00,
< 2008-01-21 10:00:32.351 00,00,00,02,00,00,00,00,AB,00,00,00,65,00,00,41,ED,47,73,4E,F1,42,57,A3,5C,
> 2008-01-21 10:00:32.351 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
> 2008-01-21 10:00:32.351 0C,00,00,0B,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:32.351 Received 32 bytes (0)
. 2008-01-21 10:00:32.351 Read 4 bytes (28 pending)
. 2008-01-21 10:00:32.351 Read 28 bytes (0 pending)
< 2008-01-21 10:00:32.351 Type: SSH_FXP_STATUS, Size: 28, Number: 2828
< 2008-01-21 10:00:32.351 65,00,00,0B,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2008-01-21 10:00:32.351 Status/error code: 1
> 2008-01-21 10:00:32.351 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
> 2008-01-21 10:00:32.351 04,00,00,0C,04,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:32.413 Session upkeep
. 2008-01-21 10:00:32.413 Looking for network events
. 2008-01-21 10:00:32.413 Detected network event
. 2008-01-21 10:00:32.413 Enumerating network events for socket 744
. 2008-01-21 10:00:32.413 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:32.413 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:32.413 Received 28 bytes (0)
. 2008-01-21 10:00:32.913 Session upkeep
. 2008-01-21 10:00:32.913 Looking for network events
. 2008-01-21 10:00:32.913 Timeout waiting for network events
. 2008-01-21 10:00:33.413 Session upkeep
. 2008-01-21 10:00:33.413 Looking for network events
. 2008-01-21 10:00:33.413 Timeout waiting for network events
. 2008-01-21 10:00:33.913 Session upkeep
. 2008-01-21 10:00:33.913 Looking for network events
. 2008-01-21 10:00:33.913 Timeout waiting for network events
. 2008-01-21 10:00:34.413 Session upkeep
. 2008-01-21 10:00:34.413 Looking for network events
. 2008-01-21 10:00:34.413 Timeout waiting for network events
. 2008-01-21 10:00:34.913 Session upkeep
. 2008-01-21 10:00:34.913 Looking for network events
. 2008-01-21 10:00:34.913 Timeout waiting for network events
. 2008-01-21 10:00:35.101 Cached directory change via "dms-tek-backup" to "/u01/dms-tek-backup".
. 2008-01-21 10:00:35.101 Getting current directory name.
. 2008-01-21 10:00:35.101 Listing directory "/u01/dms-tek-backup".
> 2008-01-21 10:00:35.101 Type: SSH_FXP_OPENDIR, Size: 28, Number: 3339
> 2008-01-21 10:00:35.101 0B,00,00,0D,0B,00,00,00,13,2F,75,30,31,2F,64,6D,73,2D,74,65,6B,2D,62,61,63,
> 2008-01-21 10:00:35.101 6B,75,70,
. 2008-01-21 10:00:35.101 Sent 32 bytes
. 2008-01-21 10:00:35.101 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:35.101 Looking for network events
. 2008-01-21 10:00:35.101 Timeout waiting for network events
. 2008-01-21 10:00:35.101 Read 4 bytes (24 pending)
. 2008-01-21 10:00:35.101 Read 24 bytes (0 pending)
< 2008-01-21 10:00:35.101 Type: SSH_FXP_STATUS, Size: 24, Number: 3076
< 2008-01-21 10:00:35.101 65,00,00,0C,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2008-01-21 10:00:35.101 Discarding reserved response
. 2008-01-21 10:00:35.101 Waiting for another 4 bytes
. 2008-01-21 10:00:35.101 Looking for incoming data
. 2008-01-21 10:00:35.101 Detected network event
. 2008-01-21 10:00:35.101 Enumerating network events for socket 744
. 2008-01-21 10:00:35.101 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:35.101 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:35.101 Received 17 bytes (0)
. 2008-01-21 10:00:35.101 Read 4 bytes (13 pending)
. 2008-01-21 10:00:35.101 Read 13 bytes (0 pending)
< 2008-01-21 10:00:35.101 Type: SSH_FXP_HANDLE, Size: 13, Number: 3339
< 2008-01-21 10:00:35.101 66,00,00,0D,0B,00,00,00,04,00,00,00,00,
> 2008-01-21 10:00:35.101 Type: SSH_FXP_READDIR, Size: 13, Number: 3596
> 2008-01-21 10:00:35.101 0C,00,00,0E,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:35.101 Sent 17 bytes
. 2008-01-21 10:00:35.116 Waiting for another 4 bytes
. 2008-01-21 10:00:35.116 Looking for incoming data
. 2008-01-21 10:00:35.116 Looking for network events
. 2008-01-21 10:00:35.116 Detected network event
. 2008-01-21 10:00:35.116 Enumerating network events for socket 744
. 2008-01-21 10:00:35.116 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:35.116 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:35.116 Received 1903 bytes (0)
. 2008-01-21 10:00:35.116 Read 4 bytes (1899 pending)
. 2008-01-21 10:00:35.116 Read 1899 bytes (0 pending)
< 2008-01-21 10:00:35.116 Type: SSH_FXP_NAME, Size: 1899, Number: 3596
< 2008-01-21 10:00:35.116 68,00,00,0E,0C,00,00,00,0F,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,77,78,
< 2008-01-21 10:00:35.116 72,77,78,20,20,20,20,33,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,
< 2008-01-21 10:00:35.116 20,20,20,20,20,20,31,30,32,34,20,4A,61,6E,20,32,30,20,32,32,3A,31,32,20,2E,
< 2008-01-21 10:00:35.116 00,00,00,0F,00,00,00,00,00,00,04,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,
< 2008-01-21 10:00:35.116 94,41,F9,47,93,9D,30,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,77,78,72,
< 2008-01-21 10:00:35.116 77,78,20,20,20,31,30,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,
< 2008-01-21 10:00:35.116 20,20,20,20,20,20,35,31,32,20,4E,6F,76,20,20,38,20,20,32,30,30,36,20,2E,2E,
< 2008-01-21 10:00:35.116 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,
< 2008-01-21 10:00:35.116 94,41,F6,45,51,BD,80,00,00,00,05,64,2E,6C,6F,67,00,00,00,3D,2D,72,77,2D,72,
< 2008-01-21 10:00:35.116 2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,
< 2008-01-21 10:00:35.116 20,20,20,20,20,20,20,20,20,20,20,30,20,41,75,67,20,20,33,20,20,32,30,30,35,
< 2008-01-21 10:00:35.116 20,64,2E,6C,6F,67,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,AB,00,00,00,
< 2008-01-21 10:00:35.116 65,00,00,81,A4,47,8E,FD,95,42,F0,A6,AC,00,00,00,04,63,6F,72,65,00,00,00,3C,
< 2008-01-21 10:00:35.116 2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,20,
< 2008-01-21 10:00:35.116 64,62,61,20,20,20,20,20,20,20,31,35,32,34,31,39,36,20,44,65,63,20,31,38,20,
< 2008-01-21 10:00:35.116 31,34,3A,34,33,20,63,6F,72,65,00,00,00,0F,00,00,00,00,00,17,41,E4,00,00,00,
< 2008-01-21 10:00:35.116 AB,00,00,00,65,00,00,81,80,47,67,B2,66,47,67,B2,66,00,00,00,11,64,62,2E,62,
< 2008-01-21 10:00:35.116 61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,00,00,00,49,2D,72,77,2D,72,2D,2D,72,
< 2008-01-21 10:00:35.116 2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,20,20,20,
< 2008-01-21 10:00:35.116 20,33,34,37,34,39,34,32,31,20,4A,61,6E,20,32,30,20,32,32,3A,31,32,20,64,62,
< 2008-01-21 10:00:35.116 2E,62,61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,00,00,00,0F,00,00,00,00,02,12,
< 2008-01-21 10:00:35.116 3B,ED,00,00,00,AB,00,00,00,65,00,00,81,A4,47,73,4D,FA,47,93,9D,38,00,00,00,
< 2008-01-21 10:00:35.116 15,64,62,2E,62,61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,2E,6F,6C,64,00,00,00,
< 2008-01-21 10:00:35.116 4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,20,
< 2008-01-21 10:00:35.116 20,64,62,61,20,20,20,20,20,20,32,38,39,39,37,38,32,37,20,4F,63,74,20,31,31,
< 2008-01-21 10:00:35.116 20,20,32,30,30,36,20,64,62,2E,62,61,63,6B,75,70,2E,65,72,72,2E,6C,6F,67,2E,
< 2008-01-21 10:00:35.116 6F,6C,64,00,00,00,0F,00,00,00,00,01,BA,78,C3,00,00,00,AB,00,00,00,65,00,00,
< 2008-01-21 10:00:35.116 81,A4,47,6B,64,47,45,2C,A6,D3,00,00,00,0D,64,62,2E,62,61,63,6B,75,70,2E,6C,
< 2008-01-21 10:00:35.116 6F,67,00,00,00,45,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,
< 2008-01-21 10:00:35.116 63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,36,36,37,39,32,20,4A,
< 2008-01-21 10:00:35.116 61,6E,20,32,30,20,32,31,3A,33,35,20,64,62,2E,62,61,63,6B,75,70,2E,6C,6F,67,
< 2008-01-21 10:00:35.116 00,00,00,0F,00,00,00,00,00,01,04,E8,00,00,00,AB,00,00,00,65,00,00,81,A4,47,
< 2008-01-21 10:00:35.116 8E,FD,9C,47,93,94,83,00,00,00,11,62,61,63,6B,75,70,2D,32,30,30,37,2D,31,32,
< 2008-01-21 10:00:35.116 2D,32,31,00,00,00,49,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,6F,72,
< 2008-01-21 10:00:35.116 61,63,6C,65,20,20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,35,31,32,20,
< 2008-01-21 10:00:35.116 44,65,63,20,32,34,20,31,38,3A,30,32,20,62,61,63,6B,75,70,2D,32,30,30,37,2D,
< 2008-01-21 10:00:35.116 31,32,2D,32,31,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,00,00,00,65,
< 2008-01-21 10:00:35.116 00,00,41,ED,47,93,9D,2E,47,6F,C9,EE,00,00,00,15,69,73,69,64,61,6C,6F,67,5F,
< 2008-01-21 10:00:35.116 30,38,2E,30,31,2E,30,38,2E,74,61,72,00,00,00,4D,2D,72,77,2D,72,2D,2D,72,2D,
< 2008-01-21 10:00:35.116 2D,20,20,20,20,31,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,
< 2008-01-21 10:00:35.116 35,35,32,36,30,31,36,30,20,4A,61,6E,20,20,38,20,30,32,3A,30,30,20,69,73,69,
< 2008-01-21 10:00:35.116 64,61,6C,6F,67,5F,30,38,2E,30,31,2E,30,38,2E,74,61,72,00,00,00,0F,00,00,00,
< 2008-01-21 10:00:35.116 00,03,4B,34,00,00,00,00,64,00,00,00,64,00,00,81,A4,47,82,AF,01,47,82,AF,04,
< 2008-01-21 10:00:35.116 00,00,00,13,64,62,2E,62,61,63,6B,75,70,2E,73,74,6F,75,74,2E,6C,6F,67,00,00,
< 2008-01-21 10:00:35.116 00,4B,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,6F,72,61,63,6C,65,20,
< 2008-01-21 10:00:35.116 20,20,64,62,61,20,20,20,20,20,20,20,20,20,20,20,20,20,30,20,41,75,67,20,20,
< 2008-01-21 10:00:35.116 38,20,20,32,30,30,35,20,64,62,2E,62,61,63,6B,75,70,2E,73,74,6F,75,74,2E,6C,
< 2008-01-21 10:00:35.116 6F,67,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,AB,00,00,00,65,00,00,81,
< 2008-01-21 10:00:35.116 A4,47,73,4D,F2,42,F7,8F,90,00,00,00,15,69,73,69,64,61,6C,6F,67,5F,30,31,2E,
< 2008-01-21 10:00:35.116 31,30,2E,30,37,2E,74,61,72,00,00,00,4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,
< 2008-01-21 10:00:35.116 20,20,31,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,36,33,37,
< 2008-01-21 10:00:35.116 37,31,31,33,36,20,4F,63,74,20,20,31,20,30,32,3A,30,30,20,69,73,69,64,61,6C,
< 2008-01-21 10:00:35.116 6F,67,5F,30,31,2E,31,30,2E,30,37,2E,74,61,72,00,00,00,0F,00,00,00,00,03,CD,
< 2008-01-21 10:00:35.116 12,00,00,00,00,64,00,00,00,64,00,00,81,A4,47,00,1C,71,47,00,1C,74,00,00,00,
< 2008-01-21 10:00:35.116 15,69,73,69,64,61,6C,6F,67,5F,32,39,2E,31,30,2E,30,37,2E,74,61,72,00,00,00,
< 2008-01-21 10:00:35.116 4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,69,73,69,64,61,20,20,20,
< 2008-01-21 10:00:35.116 20,69,73,69,64,61,20,20,20,20,38,33,34,31,31,34,35,36,20,4F,63,74,20,32,39,
< 2008-01-21 10:00:35.116 20,30,32,3A,30,31,20,69,73,69,64,61,6C,6F,67,5F,32,39,2E,31,30,2E,30,37,2E,
< 2008-01-21 10:00:35.116 74,61,72,00,00,00,0F,00,00,00,00,04,F8,C2,00,00,00,00,64,00,00,00,64,00,00,
< 2008-01-21 10:00:35.116 81,A4,47,25,14,D8,47,25,14,DC,00,00,00,15,69,73,69,64,61,6C,6F,67,5F,30,38,
< 2008-01-21 10:00:35.116 2E,30,39,2E,30,37,2E,74,61,72,00,00,00,4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,
< 2008-01-21 10:00:35.116 20,20,20,31,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,36,32,
< 2008-01-21 10:00:35.116 34,39,33,31,38,34,20,53,65,70,20,20,38,20,30,32,3A,30,31,20,69,73,69,64,61,
< 2008-01-21 10:00:35.116 6C,6F,67,5F,30,38,2E,30,39,2E,30,37,2E,74,61,72,00,00,00,0F,00,00,00,00,03,
< 2008-01-21 10:00:35.116 B9,92,00,00,00,00,64,00,00,00,64,00,00,81,A4,46,E1,CA,3C,46,E1,CA,3F,00,00,
< 2008-01-21 10:00:35.116 00,15,69,73,69,64,61,6C,6F,67,5F,32,32,2E,31,31,2E,30,37,2E,74,61,72,00,00,
< 2008-01-21 10:00:35.116 00,4D,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,69,73,69,64,61,20,20,
< 2008-01-21 10:00:35.116 20,20,69,73,69,64,61,20,20,20,20,38,30,39,30,38,32,38,38,20,4E,6F,76,20,32,
< 2008-01-21 10:00:35.116 32,20,30,32,3A,30,32,20,69,73,69,64,61,6C,6F,67,5F,32,32,2E,31,31,2E,30,37,
< 2008-01-21 10:00:35.116 2E,74,61,72,00,00,00,0F,00,00,00,00,04,D2,90,00,00,00,00,64,00,00,00,64,00,
< 2008-01-21 10:00:35.116 00,81,A4,47,44,B8,E9,47,44,B8,ED,00,00,00,15,69,73,69,64,61,6C,6F,67,5F,31,
< 2008-01-21 10:00:35.116 35,2E,31,32,2E,30,37,2E,74,61,72,00,00,00,4D,2D,72,77,2D,72,2D,2D,72,2D,2D,
< 2008-01-21 10:00:35.116 20,20,20,20,31,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,20,38,
< 2008-01-21 10:00:35.116 33,35,33,39,34,35,36,20,44,65,63,20,31,35,20,30,32,3A,30,32,20,69,73,69,64,
< 2008-01-21 10:00:35.116 61,6C,6F,67,5F,31,35,2E,31,32,2E,30,37,2E,74,61,72,00,00,00,0F,00,00,00,00,
< 2008-01-21 10:00:35.116 04,FA,B6,00,00,00,00,64,00,00,00,64,00,00,81,A4,47,63,0B,7B,47,63,0B,7F,
> 2008-01-21 10:00:35.116 Type: SSH_FXP_READDIR, Size: 13, Number: 3852
> 2008-01-21 10:00:35.116 0C,00,00,0F,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:35.116 Sent 17 bytes
. 2008-01-21 10:00:35.116 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:35.116 Timeout waiting for network events
. 2008-01-21 10:00:35.116 Received 32 bytes (0)
. 2008-01-21 10:00:35.116 Read 4 bytes (28 pending)
. 2008-01-21 10:00:35.116 Read 28 bytes (0 pending)
< 2008-01-21 10:00:35.116 Type: SSH_FXP_STATUS, Size: 28, Number: 3852
< 2008-01-21 10:00:35.116 65,00,00,0F,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2008-01-21 10:00:35.116 Status/error code: 1
> 2008-01-21 10:00:35.116 Type: SSH_FXP_CLOSE, Size: 13, Number: 4100
> 2008-01-21 10:00:35.116 04,00,00,10,04,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:35.413 Session upkeep
. 2008-01-21 10:00:35.413 Looking for network events
. 2008-01-21 10:00:35.413 Detected network event
. 2008-01-21 10:00:35.413 Enumerating network events for socket 744
. 2008-01-21 10:00:35.413 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:35.413 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:35.413 Received 28 bytes (0)
. 2008-01-21 10:00:35.913 Session upkeep
. 2008-01-21 10:00:35.913 Looking for network events
. 2008-01-21 10:00:35.913 Timeout waiting for network events
. 2008-01-21 10:00:36.413 Session upkeep
. 2008-01-21 10:00:36.413 Looking for network events
. 2008-01-21 10:00:36.413 Timeout waiting for network events
. 2008-01-21 10:00:36.913 Session upkeep
. 2008-01-21 10:00:36.913 Looking for network events
. 2008-01-21 10:00:36.913 Timeout waiting for network events
. 2008-01-21 10:00:37.413 Session upkeep
. 2008-01-21 10:00:37.413 Looking for network events
. 2008-01-21 10:00:37.413 Timeout waiting for network events
. 2008-01-21 10:00:37.913 Session upkeep
. 2008-01-21 10:00:37.913 Looking for network events
. 2008-01-21 10:00:37.913 Timeout waiting for network events
. 2008-01-21 10:00:38.413 Session upkeep
. 2008-01-21 10:00:38.413 Looking for network events
. 2008-01-21 10:00:38.413 Timeout waiting for network events
. 2008-01-21 10:00:38.913 Session upkeep
. 2008-01-21 10:00:38.913 Looking for network events
. 2008-01-21 10:00:38.913 Timeout waiting for network events
. 2008-01-21 10:00:39.351 Session upkeep
. 2008-01-21 10:00:39.351 Looking for network events
. 2008-01-21 10:00:39.351 Timeout waiting for network events
. 2008-01-21 10:00:39.366 Session upkeep
. 2008-01-21 10:00:39.366 Looking for network events
. 2008-01-21 10:00:39.366 Timeout waiting for network events
. 2008-01-21 10:00:39.413 Session upkeep
. 2008-01-21 10:00:39.413 Looking for network events
. 2008-01-21 10:00:39.413 Timeout waiting for network events
. 2008-01-21 10:00:39.913 Session upkeep
. 2008-01-21 10:00:39.913 Looking for network events
. 2008-01-21 10:00:39.913 Timeout waiting for network events
. 2008-01-21 10:00:40.413 Session upkeep
. 2008-01-21 10:00:40.413 Looking for network events
. 2008-01-21 10:00:40.413 Timeout waiting for network events
. 2008-01-21 10:00:40.913 Session upkeep
. 2008-01-21 10:00:40.913 Looking for network events
. 2008-01-21 10:00:40.913 Timeout waiting for network events
. 2008-01-21 10:00:41.413 Session upkeep
. 2008-01-21 10:00:41.413 Looking for network events
. 2008-01-21 10:00:41.413 Timeout waiting for network events
. 2008-01-21 10:00:41.913 Session upkeep
. 2008-01-21 10:00:41.913 Looking for network events
. 2008-01-21 10:00:41.913 Timeout waiting for network events
. 2008-01-21 10:00:42.413 Session upkeep
. 2008-01-21 10:00:42.413 Looking for network events
. 2008-01-21 10:00:42.413 Timeout waiting for network events
. 2008-01-21 10:00:42.913 Session upkeep
. 2008-01-21 10:00:42.913 Looking for network events
. 2008-01-21 10:00:42.913 Timeout waiting for network events
. 2008-01-21 10:00:43.413 Session upkeep
. 2008-01-21 10:00:43.413 Looking for network events
. 2008-01-21 10:00:43.413 Timeout waiting for network events
. 2008-01-21 10:00:43.913 Session upkeep
. 2008-01-21 10:00:43.913 Looking for network events
. 2008-01-21 10:00:43.913 Timeout waiting for network events
. 2008-01-21 10:00:44.413 Session upkeep
. 2008-01-21 10:00:44.413 Looking for network events
. 2008-01-21 10:00:44.413 Timeout waiting for network events
. 2008-01-21 10:00:44.772 Cached directory change via ".." to "/u01".
. 2008-01-21 10:00:44.772 Getting current directory name.
. 2008-01-21 10:00:44.772 Directory content loaded from cache.
. 2008-01-21 10:00:44.913 Session upkeep
. 2008-01-21 10:00:44.913 Looking for network events
. 2008-01-21 10:00:44.913 Timeout waiting for network events
. 2008-01-21 10:00:45.413 Session upkeep
. 2008-01-21 10:00:45.413 Looking for network events
. 2008-01-21 10:00:45.413 Timeout waiting for network events
. 2008-01-21 10:00:45.913 Session upkeep
. 2008-01-21 10:00:45.913 Looking for network events
. 2008-01-21 10:00:45.913 Timeout waiting for network events
. 2008-01-21 10:00:46.413 Session upkeep
. 2008-01-21 10:00:46.413 Looking for network events
. 2008-01-21 10:00:46.413 Timeout waiting for network events
. 2008-01-21 10:00:46.851 Changing directory to "database".
. 2008-01-21 10:00:46.851 Getting real path for '/u01/database'
> 2008-01-21 10:00:46.851 Type: SSH_FXP_REALPATH, Size: 22, Number: 4368
> 2008-01-21 10:00:46.851 10,00,00,11,10,00,00,00,0D,2F,75,30,31,2F,64,61,74,61,62,61,73,65,
. 2008-01-21 10:00:46.851 Sent 26 bytes
. 2008-01-21 10:00:46.851 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:46.851 Looking for network events
. 2008-01-21 10:00:46.851 Timeout waiting for network events
. 2008-01-21 10:00:46.851 Read 4 bytes (24 pending)
. 2008-01-21 10:00:46.851 Read 24 bytes (0 pending)
< 2008-01-21 10:00:46.851 Type: SSH_FXP_STATUS, Size: 24, Number: 4100
< 2008-01-21 10:00:46.851 65,00,00,10,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2008-01-21 10:00:46.851 Discarding reserved response
. 2008-01-21 10:00:46.851 Waiting for another 4 bytes
. 2008-01-21 10:00:46.851 Looking for incoming data
. 2008-01-21 10:00:46.851 Detected network event
. 2008-01-21 10:00:46.851 Enumerating network events for socket 744
. 2008-01-21 10:00:46.851 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:46.851 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:46.851 Received 51 bytes (0)
. 2008-01-21 10:00:46.851 Read 4 bytes (47 pending)
. 2008-01-21 10:00:46.851 Read 47 bytes (0 pending)
< 2008-01-21 10:00:46.851 Type: SSH_FXP_NAME, Size: 47, Number: 4368
< 2008-01-21 10:00:46.851 68,00,00,11,10,00,00,00,01,00,00,00,0D,2F,75,30,31,2F,64,61,74,61,62,61,73,
< 2008-01-21 10:00:46.851 65,00,00,00,0D,2F,75,30,31,2F,64,61,74,61,62,61,73,65,00,00,00,00,
. 2008-01-21 10:00:46.851 Real path is '/u01/database'
. 2008-01-21 10:00:46.851 Trying to open directory "/u01/database".
> 2008-01-21 10:00:46.851 Type: SSH_FXP_LSTAT, Size: 22, Number: 4615
> 2008-01-21 10:00:46.851 07,00,00,12,07,00,00,00,0D,2F,75,30,31,2F,64,61,74,61,62,61,73,65,
. 2008-01-21 10:00:46.851 Received 41 bytes (0)
. 2008-01-21 10:00:46.851 Read 4 bytes (37 pending)
. 2008-01-21 10:00:46.851 Read 37 bytes (0 pending)
< 2008-01-21 10:00:46.851 Type: SSH_FXP_ATTRS, Size: 37, Number: 4615
< 2008-01-21 10:00:46.851 69,00,00,12,07,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,00,00,00,65,
< 2008-01-21 10:00:46.851 00,00,41,FF,47,73,4E,B8,47,6B,EA,5A,
. 2008-01-21 10:00:46.851 Getting current directory name.
. 2008-01-21 10:00:46.851 Listing directory "/u01/database".
> 2008-01-21 10:00:46.851 Type: SSH_FXP_OPENDIR, Size: 22, Number: 4875
> 2008-01-21 10:00:46.851 0B,00,00,13,0B,00,00,00,0D,2F,75,30,31,2F,64,61,74,61,62,61,73,65,
. 2008-01-21 10:00:46.851 Received 17 bytes (0)
. 2008-01-21 10:00:46.851 Read 4 bytes (13 pending)
. 2008-01-21 10:00:46.851 Read 13 bytes (0 pending)
< 2008-01-21 10:00:46.851 Type: SSH_FXP_HANDLE, Size: 13, Number: 4875
< 2008-01-21 10:00:46.851 66,00,00,13,0B,00,00,00,04,00,00,00,00,
> 2008-01-21 10:00:46.851 Type: SSH_FXP_READDIR, Size: 13, Number: 5132
> 2008-01-21 10:00:46.851 0C,00,00,14,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:46.851 Sent 17 bytes
. 2008-01-21 10:00:46.866 Detected network event
. 2008-01-21 10:00:46.866 Enumerating network events for socket 744
. 2008-01-21 10:00:46.866 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:46.866 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:46.866 Received 317 bytes (0)
. 2008-01-21 10:00:46.866 Read 4 bytes (313 pending)
. 2008-01-21 10:00:46.866 Read 313 bytes (0 pending)
< 2008-01-21 10:00:46.866 Type: SSH_FXP_NAME, Size: 313, Number: 5132
< 2008-01-21 10:00:46.866 68,00,00,14,0C,00,00,00,03,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,77,78,
< 2008-01-21 10:00:46.866 72,77,78,20,20,20,20,33,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,20,20,
< 2008-01-21 10:00:46.866 20,20,20,20,20,20,20,35,31,32,20,44,65,63,20,32,31,20,31,39,3A,33,31,20,2E,
< 2008-01-21 10:00:46.866 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,00,00,00,65,00,00,41,FF,47,
< 2008-01-21 10:00:46.866 94,42,05,47,6B,EA,5A,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,77,78,72,
< 2008-01-21 10:00:46.866 77,78,20,20,20,31,30,20,69,73,69,64,61,20,20,20,20,69,73,69,64,61,20,20,20,
< 2008-01-21 10:00:46.866 20,20,20,20,20,20,35,31,32,20,4E,6F,76,20,20,38,20,20,32,30,30,36,20,2E,2E,
< 2008-01-21 10:00:46.866 00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,64,00,00,00,64,00,00,41,FF,47,
< 2008-01-21 10:00:46.866 94,41,F6,45,51,BD,80,00,00,00,05,6F,72,61,6C,33,00,00,00,3D,64,72,77,78,72,
< 2008-01-21 10:00:46.866 77,78,72,77,78,20,20,20,20,32,20,6F,72,61,63,6C,65,20,20,20,64,62,61,20,20,
< 2008-01-21 10:00:46.866 20,20,20,20,20,20,20,20,20,35,31,32,20,44,65,63,20,32,31,20,31,39,3A,34,33,
< 2008-01-21 10:00:46.866 20,6F,72,61,6C,33,00,00,00,0F,00,00,00,00,00,00,02,00,00,00,00,AB,00,00,00,
< 2008-01-21 10:00:46.866 65,00,00,41,FF,47,6F,D1,8D,47,6B,ED,1A,
> 2008-01-21 10:00:46.866 Type: SSH_FXP_READDIR, Size: 13, Number: 5388
> 2008-01-21 10:00:46.866 0C,00,00,15,0C,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:46.866 Sent 17 bytes
. 2008-01-21 10:00:46.866 There are 0 bytes remaining in the send buffer
. 2008-01-21 10:00:46.866 Looking for network events
. 2008-01-21 10:00:46.866 Timeout waiting for network events
. 2008-01-21 10:00:46.866 Waiting for another 4 bytes
. 2008-01-21 10:00:46.866 Looking for incoming data
. 2008-01-21 10:00:46.866 Received 32 bytes (0)
. 2008-01-21 10:00:46.866 Read 4 bytes (28 pending)
. 2008-01-21 10:00:46.866 Read 28 bytes (0 pending)
< 2008-01-21 10:00:46.866 Type: SSH_FXP_STATUS, Size: 28, Number: 5388
< 2008-01-21 10:00:46.866 65,00,00,15,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2008-01-21 10:00:46.866 Status/error code: 1
> 2008-01-21 10:00:46.866 Type: SSH_FXP_CLOSE, Size: 13, Number: 5636
> 2008-01-21 10:00:46.866 04,00,00,16,04,00,00,00,04,00,00,00,00,
. 2008-01-21 10:00:46.913 Session upkeep
. 2008-01-21 10:00:46.913 Looking for network events
. 2008-01-21 10:00:46.913 Detected network event
. 2008-01-21 10:00:46.913 Enumerating network events for socket 744
. 2008-01-21 10:00:46.913 Enumerated 1 network events making 1 cumulative events for socket 744
. 2008-01-21 10:00:46.913 Handling network read event on socket 744 with error 0
. 2008-01-21 10:00:46.913 Received 28 bytes (0)
. 2008-01-21 10:00:47.413 Session upkeep
. 2008-01-21 10:00:47.413 Looking for network events
. 2008-01-21 10:00:47.413 Timeout waiting for network events
. 2008-01-21 10:00:47.913 Session upkeep
. 2008-01-21 10:00:47.913 Looking for network events
. 2008-01-21 10:00:47.913 Timeout waiting for network events
. 2008-01-21 10:00:48.351 Session upkeep
. 2008-01-21 10:00:48.351 Looking for network events
. 2008-01-21 10:00:48.351 Timeout waiting for network events
. 2008-01-21 10:00:48.413 Session upkeep
. 2008-01-21 10:00:48.413 Looking for network events
. 2008-01-21 10:00:48.413 Timeout waiting for network events
. 2008-01-21 10:00:48.913 Session upkeep
. 2008-01-21 10:00:48.913 Looking for network events
. 2008-01-21 10:00:48.913 Timeout waiting for network events
. 2008-01-21 10:00:48.991 Closing connection.
. 2008-01-21 10:00:48.991 Selecting events 0 for socket 744
Re: Some files are invisible in WinSCP
Directory listing as reported by server indeed does not contain the files you miss. Only following files are included:
d.log
core
db.backup.err.log
db.backup.err.log.old
db.backup.log
backup-2007-12-21
isdialog_08.01.08.tar
db.backup.stout.log
isdialog_01.10.07.tar
isdialog_29.10.07.tar
isdialog_08.09.07.tar
isdialog_22.11.07.tar
isdialog_15.12.07.tar
So it is your SFTP server that omits them.
