Finding the Plug-in!
I have downloaded WinSCP but I can't find it on my computer! Anyone have any idea where it hides? I know I have installed it becuase it appears in the 'Add/Remove Programs' tool!
Re: Finding the Plug-in!
From the subject, it looks like you have download WinSCP plugin to FAR. you will find it in FAR plugin menu. If you do not use FAR, the plugin is of not use for your. Uninstall it and download WinSCP application installation package.
