software requirement document
giota
Hi!I intend to write the software requirement document on this project.Could you please inform me if there is somebody else who has already done it!Thank you in advance!!
giota
hi
Thanks a lot for the url. I find the tech requirements very useful. However, am planing
to write a more detail one which will include the functional requirements as well. When i finish i will upload it to this forum for comments, hopefully someone will find it useful.
Regards
giota
Hi, my document is almost ready but i would like to write something about
1.User Interfaces
(Describe the logical characteristics of each interface between the software product and the users. This may include sample screen images, any GUI standards or product family style guides that are to be followed, screen layout constraints, standard buttons and functions (e.g., help) that will appear on every screen, keyboard shortcuts, error message display standards, and so on. Define the software components for which a user interface is needed. Details of the user interface design should be documented in a separate user interface specification.),
2.Hardware Interfaces
(Describe the logical and physical characteristics of each interface between the software product and the hardware components of the system. This may include the supported device types, the nature of the data and control interactions between the software and the hardware, and communication protocols to be used.),
3.Software Interfaces
(Describe the connections between this product and other specific software components (name and version), including databases, operating systems, tools, libraries, and integrated commercial components. Identify the data items or messages coming into the system and going out and describe the purpose of each. Describe the services needed and the nature of communications. Refer to documents that describe detailed application programming interface protocols. Identify data that will be shared across software components. If the data sharing mechanism must be implemented in a specific way (for example, use of a global data area in a multitasking operating system), specify this as an implementation constraint.)and
4.Communications Interfaces
(Describe the requirements associated with any communications functions required by this product, including e-mail, web browser, network server communications protocols, electronic forms, and so on. Define any pertinent message formatting. Identify any communication standards that will be used, such as FTP or HTTP. Specify any communication security or encryption issues, data transfer rates, and synchronization mechanisms.)
Could you please tell me if there are any information about these areas?
giota wrote:
I finished the software requirement document, so could you please inform me how can i send it to you? :)
You'll find my email address in my forum profile.
I'll try to answer your previous post soon.
