Directory list problems on solaris 2.5.1
After trying the latest version of Winscp I found the following bug/feature. On Solaris 2.5.1 we sometimes get directory listings as such:
When the username for the file is 'briodevtest' and the group name is 'bsdb2dv'. This results in an error listing that file or directory and all the subsequent contents in the directory in winscp. The only way you can tell where the user name ends and the group name begins is by looking at the offset of the rest of the line. I will provide some correct directory listings in case it helps.
Normal contents:
Incorrect contents:
drwxr-xr-x 2 briodevtestbsdb2dv 512 Oct 28 2002 briodevtest
Normal contents:
drwxr-x--x 2 1043 staff 512 Jun 29 1999 cry drwxr-xr-x 2 cwq other 512 Apr 18 2001 cwq drwxr-xr-x 6 cyk370 staff 512 Mar 11 09:47 cyk370 drwxr-x--x 2 1011 staff 512 Mar 12 1998 d0b
Incorrect contents:
drwxr-xr-x 2 ellery_troystaff 512 Mar 9 2001 ellery_troy drwxr-xr-x 2 graham_briantotalnet 512 Jan 31 2001 graham_brian
