Accessing random IP addresses at connect time
tupan_haravel
Why is WinSCP attempting to access some random IP addresses every time I try to log in to a host? Is it some setting related to updates checking?
If I don't allow the connection to that IP, the login fails.
There is no obvious connection between the IPs, it's sometimes Google, sometimes, RIPE registered domains, they are all over the place.
Re: Accessing random IP addresses at connect time
WinSCP does not do that. Why do you think so?
