Command of scp copying process
ThomasW
I tried to use the scp command - without using WinSCP - to copy files from a remote PC working with suse Linux to my local PC working with Windows XP. It never succeeded.
Which is the command or mechanism of WinSCP for copying files from a Linux to a Windows system; is WinSCP using internally the scp command of OpenSSH or some other?
Thanks for all good hints.
Thomas Wiedmann
Re: Command of scp copying process
It does, if you select SCP protocol.
ThomasW
How can this be done, i. e. what has to be done or which software/tool has to be installed or configured to carry out or to call the scp protocol? Could you give an example?
Some time ago I tried this using the scp command in the Windows command shell to carry out an scp process by script - but unfortunately it didn't work (meaning: no files had been copied from the remote Linux system to my local PC installed with Windows XP).
Thomas Wiedmann
TS
Windows does not ship with an scp (or sFTP) binary built-in. If you try to run scp, you probably get a command not found error. If something does run when you type scp, you'd have to consult with whoever wrote that program to figure out why it's not working.
WinSCP does have a scripting interface so that you can use it from the command-line.
Curious
I too am wondering what the command is. I'm SSHing from a Windows machine to my OSX box, and would like to know what command to successfully SCP a file is. Typical SCP requires both of the computers to be UNIX based.
