Software caused connection abort
EvR
Obdam, The Netherlands
We use WinSCP for synchronization files on Windows 20003 with remote files on HP-UX 11.23i. WinSCP crashes with:
Network error: Software caused connection abort.
WinSCP 4.0.4 (build 346)
Change in 'F:\xxxxx\xxxxx\inbox' detected.
Error listing directory '/xxxxx/xxxxx'.
Session 'user@x.x.x.x' closed.
Above is information from DOS box, we use srvany to run the sftp client as a service. Settings timeout are maximum 6000. Sending SSH 0 is on. We use server.ini for settings. Error listing directory is random. CHMOD settings remote directory is allright.
2007-10-17 15:13:29.515 --------------------------------------------------------------------------
. 2007-10-17 15:13:29.515 Using SFTP protocol.
. 2007-10-17 15:13:29.515 Doing startup conversation with host.
> 2007-10-17 15:13:29.515 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2007-10-17 15:13:29.686 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2007-10-17 15:13:29.686 SFTP version 3 negotiated.
. 2007-10-17 15:13:29.686 We believe the server has signed timestamps bug
. 2007-10-17 15:13:29.686 We will use UTF-8 strings for status messages only
. 2007-10-17 15:13:29.686 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2007-10-17 15:13:29.686 Getting current directory name.
. 2007-10-17 15:13:29.686 Getting real path for '.'
> 2007-10-17 15:13:29.686 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2007-10-17 15:13:29.686 Type: SSH_FXP_NAME, Size: 45, Number: 16
. 2007-10-17 15:13:29.686 Real path is '/home/userx'
. 2007-10-17 15:13:29.686 Startup conversation with host finished.
. 2007-10-18 06:18:02.000 Collecting synchronization list for local directory 'F:\xxxxx\xxxxx\inbox\' and remote directory '/xxxxx/xxxxx/', mode = 0, params = 186
. 2007-10-18 06:18:02.000 Listing directory "/xxxxx/xxxxx".
> 2007-10-18 06:18:02.000 Type: SSH_FXP_OPENDIR, Size: 21, Number: 267
. 2007-10-18 06:18:02.000 Network error: Software caused connection abort
Maybe you can give us any direction? We have no clue at this moment.
Regards,
Eric
Re: Software caused connection abort
The error can occur if the server stops accepting data from WinSCP. but I doubt it is the case as it does not look like that too many data was actually submitted.
