Maintaining user permissions and ownership on UNIX
garyliffen
Can't find it in the FAQ or answers in the forums so I shall ask here.
I have two sessions open on two UNIX servers. Using drag and drop to transfer works, however the destination server does not retain the perms and ownership of the files. This is frustrating when transferring a large amount of files.
E.g
Source
-rwxrwxr-x 1 root bin testfile
Destination
-rw-r--r-- 1 root root testfile
Is there a preference I need to change or is it just that WinSCP cannot do this and I should be using something else for my Unix to Unix needs ;)
Re: Maintaining user permissions and ownership on UNIX
WinSCP does not support that. The two instances even does not know about each other.
