WinSCP 4.0.5 graphical problem
Autourdupc
Dear,
When launching WinSCP graphical under XP Pro SP2 french, the left panel is not in C:\ as it is indicated in the drop down list.
By default, the left panel is in My Documents, while the drop done list indicate "C:\ Disque Local"
Best regards,
laurent.
Re: WinSCP 4.0.5 graphical problem
This is known issue that has been resolved already. The fix will be included into the next release.
