Error: Cannot initialize SFTP protocol.
al0323
I am using version 4.0.4 (build 346) with explorer like environment.
The protocol is setup as SFTP Yes, Allow SCP Fallback.
When I try to logon to the server, I get the following error:
"Connection has been unexpectedly closed. Server sent command exit status 1. Cannot initialize SFTP protocol. Is the host running a SFTP server?"
My colleague has the same configuration but is running version 3.8.2 and is able to connect.
What could be the problem?
Thank you.
al0323
Re: Error: Cannot initialize SFTP protocol.
Turns out my password on the server had expired. I reset my password and am able to connect fine.
anonymous1241
I had this issue and it turned out to be because I had added a new script to my .cshrc (the csh equivalent to .bashrc) that required a tty in order to run. When WinSCP tunnels over ssh there isn't a tty, so it couldn't run the script and couldn't log in.
Jazzykeith
sftp connection problem
I have Ubuntu Linux running on an Amazon "small" instance server. It has been working ok until now
When logging in I get the message "
OK Reconnect (1 s) Help
This was working ok and no changes to winscp have been made . We can connect via putty with no error. To the best of my knowledge nothing has changed on the Amazon server
Re: sftp connection problem
Can you post a log file both from WinSCP and PuTTY?
