Batch Console is empty during copy
SAM
I created a winscp-script that I start from ant to copy some things to my server. But I cannot see the transfer progress. The console window comes up but its empty.
Is there a way to show the progress in console window?
Thank you
SAM
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
option echo on
# Connect
open user@myserver.com
# Change remote directory
cd /upload
# Force binary mode transfer
option transfer binary
# Upload the file to current working directory
put c:\dir\current\*
#Disconnect
close
# Exit WinSCP
Re: Batch Console is empty during copy
What version of WinSCP are you using? Do you run winscp.com or winscp.exe? How do you run it?
SAM
Im using WinSCP Version 4.03 (Build 345)
Im starting WinSCP within an ANT-Script. Here is the ANT-Target:
<target name="WinSCP upload" depends="nsis">
<exec executable="${winscp.exe}" failonerror="true" output="winscp_out.txt" >
<arg line="/console /script=winscp/upload_file.txt"/>
</exec>
</target>
This results in following call
winscp.exe /console /script=winscp/upload_file.txt
Thank you for the help,
SAM
No, the winscp_out.txt file is empty.
Nothing to see in console also if I remove the output attribute from
SAM
