put seems to copy instead of move
eggie5
I'm using the put command to move some files from a windows computer to a linux computer.
When I use the put command it seems to copy the file, while I would like it to move the files so they don't exist on the windows computer anymore.
how can I facilitate this?
Re: put seems to copy instead of move
This will be supported in the next major version.
