Local ProxyCommand
kalash
Local ProxyCommand
i like very much the utility WinSCP. I know that is derived from putty, thus, I asked myself why was removed from it the Local ProxyCommand (supported by putty instead). Surfing in internet I discovered a useful utility derived from connect.c (called connect-ntlm) that implements NTLM connection (not yet v2). I tried this utility with putty and works very well. But in WinSCP i cannot try because I cannot configure Local ProxyCommand in any place.
Could be a very useful feature.
Thank you
Bye
Re: Local ProxyCommand
The feature was not included in PuTTY 0.58 (the one WinSCP is based on) yet. For the next major version, WinSCP will be upgraded to PuTTY 0.60 (or later), hence it will include this feature as well.
