error getting name of current remote directory
kmcdermott
Hi all
Went through as many searches as I could find on this error, but no luck.
Client side:
XP SP2
WinSCP 4.04
Server side:
2003 R2 SP2
WRQ/Reflections Secure IT/FSecure
Can connect properly through FSecure client and FileZilla over SFTP, but "error getting name of current remote directory" from WinSCP 3.81 and 4.4
Log:
. 2007-10-10 11:01:47.676 --------------------------------------------------------------------------
. 2007-10-10 11:01:47.676 WinSCP Version 4.0.4 (Build 346) (OS 5.1.2600 Service Pack 2)
. 2007-10-10 11:01:47.676 Login time: Wednesday, October 10, 2007 11:01:47 AM
. 2007-10-10 11:01:47.676 Session name: user@server
. 2007-10-10 11:01:47.676 Host name: 172.16.13.189 (Port: 22)
. 2007-10-10 11:01:47.676 User name: user (Password: No, Key file: No)
. 2007-10-10 11:01:47.676 Tunnel: No
. 2007-10-10 11:01:47.676 Transfer Protocol: SFTP
. 2007-10-10 11:01:47.676 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-10-10 11:01:47.676 Proxy: none
. 2007-10-10 11:01:47.676 SSH protocol version: 2; Compression: No
. 2007-10-10 11:01:47.676 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-10-10 11:01:47.676 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-10-10 11:01:47.676 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-10-10 11:01:47.676 SFTP Bugs: -,-,-
. 2007-10-10 11:01:47.676 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-10-10 11:01:47.676 Shell: default, EOL: 0
. 2007-10-10 11:01:47.676 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-10-10 11:01:47.676 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-10-10 11:01:47.676 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-10-10 11:01:47.676 Cache directory changes: Yes, Permanent: Yes
. 2007-10-10 11:01:47.676 DST mode: 1
. 2007-10-10 11:01:47.801 Looking up host "172.16.13.189"
. 2007-10-10 11:01:47.801 Connecting to 172.16.13.189 port 22
. 2007-10-10 11:01:47.911 Server version: SSH-2.0-WRQReflectionForSecureIT_6.1 Build 21
. 2007-10-10 11:01:47.911 We claim version: SSH-2.0-WinSCP_release_4.0.4
. 2007-10-10 11:01:47.911 Using SSH protocol version 2
. 2007-10-10 11:01:47.911 Using Diffie-Hellman with standard group "group14"
. 2007-10-10 11:01:47.911 Doing Diffie-Hellman key exchange
. 2007-10-10 11:01:48.301 Host key fingerprint is:
. 2007-10-10 11:01:48.317 ssh-dss 1024 d6:6c:e8:8b:71:f1:13:fc:f3:80:69:8e:12:0d:78:93
. 2007-10-10 11:01:48.317 Initialised AES-256 client->server encryption
. 2007-10-10 11:01:48.317 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-10-10 11:01:48.317 Initialised AES-256 server->client encryption
. 2007-10-10 11:01:48.317 Initialised HMAC-SHA1 server->client MAC algorithm
! 2007-10-10 11:01:48.489 Using username "user".
! 2007-10-10 11:01:50.020 Using keyboard-interactive authentication.
! 2007-10-10 11:01:50.208 Password authentication
. 2007-10-10 11:01:50.208 Session password prompt (user's password: )
. 2007-10-10 11:01:54.536 Access granted
. 2007-10-10 11:01:54.536 Opened channel for session
. 2007-10-10 11:01:54.614 Started a shell/command
. 2007-10-10 11:01:54.614 --------------------------------------------------------------------------
. 2007-10-10 11:01:54.614 Using SFTP protocol.
. 2007-10-10 11:01:54.614 Doing startup conversation with host.
> 2007-10-10 11:01:54.630 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2007-10-10 11:01:54.661 Type: SSH_FXP_VERSION, Size: 34, Number: -1
. 2007-10-10 11:01:54.661 SFTP version 3 negotiated.
. 2007-10-10 11:01:54.661 Unknown server extension newline@vandyke.com=0x0D0A
. 2007-10-10 11:01:54.661 We believe the server has signed timestamps bug
. 2007-10-10 11:01:54.661 We will use UTF-8 strings for status messages only
. 2007-10-10 11:01:54.677 Getting current directory name.
. 2007-10-10 11:01:54.677 Getting real path for '.'
> 2007-10-10 11:01:54.677 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2007-10-10 11:01:54.677 Type: SSH_FXP_STATUS, Size: 44, Number: 16
< 2007-10-10 11:01:54.677 Status/error code: 4, Message: 16, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:54.677 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:54.677 Cannot get real path for '.'.
* 2007-10-10 11:01:54.677 General failure (server should provide error description).
* 2007-10-10 11:01:54.677 Error code: 4
* 2007-10-10 11:01:54.677 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:54.677 Request code: 16
. 2007-10-10 11:01:55.677 Getting current directory name.
. 2007-10-10 11:01:55.677 Getting real path for '.'
> 2007-10-10 11:01:55.677 Type: SSH_FXP_REALPATH, Size: 10, Number: 272
< 2007-10-10 11:01:55.677 Type: SSH_FXP_STATUS, Size: 44, Number: 272
< 2007-10-10 11:01:55.677 Status/error code: 4, Message: 272, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:55.677 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:55.677 Cannot get real path for '.'.
* 2007-10-10 11:01:55.677 General failure (server should provide error description).
* 2007-10-10 11:01:55.677 Error code: 4
* 2007-10-10 11:01:55.677 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:55.677 Request code: 16
. 2007-10-10 11:01:56.067 Getting current directory name.
. 2007-10-10 11:01:56.067 Getting real path for '.'
> 2007-10-10 11:01:56.067 Type: SSH_FXP_REALPATH, Size: 10, Number: 528
< 2007-10-10 11:01:56.067 Type: SSH_FXP_STATUS, Size: 44, Number: 528
< 2007-10-10 11:01:56.067 Status/error code: 4, Message: 528, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:56.067 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:56.067 Cannot get real path for '.'.
* 2007-10-10 11:01:56.067 General failure (server should provide error description).
* 2007-10-10 11:01:56.067 Error code: 4
* 2007-10-10 11:01:56.067 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:56.067 Request code: 16
. 2007-10-10 11:01:56.442 Listing directory "".
> 2007-10-10 11:01:56.442 Type: SSH_FXP_OPENDIR, Size: 9, Number: 779
< 2007-10-10 11:01:56.442 Type: SSH_FXP_HANDLE, Size: 17, Number: 779
> 2007-10-10 11:01:56.442 Type: SSH_FXP_READDIR, Size: 17, Number: 1036
< 2007-10-10 11:01:56.458 Type: SSH_FXP_NAME, Size: 207, Number: 1036
> 2007-10-10 11:01:56.458 Type: SSH_FXP_READDIR, Size: 17, Number: 1292
< 2007-10-10 11:01:56.458 Type: SSH_FXP_STATUS, Size: 22, Number: 1292
< 2007-10-10 11:01:56.458 Status/error code: 1
> 2007-10-10 11:01:56.458 Type: SSH_FXP_CLOSE, Size: 17, Number: 1540
. 2007-10-10 11:01:56.458 Startup conversation with host finished.
. 2007-10-10 11:01:56.708 Getting current directory name.
. 2007-10-10 11:01:56.708 Getting real path for '.'
> 2007-10-10 11:01:56.708 Type: SSH_FXP_REALPATH, Size: 10, Number: 1808
< 2007-10-10 11:01:56.708 Type: SSH_FXP_STATUS, Size: 21, Number: 1540
. 2007-10-10 11:01:56.708 Discarding reserved response
< 2007-10-10 11:01:56.708 Type: SSH_FXP_STATUS, Size: 44, Number: 1808
< 2007-10-10 11:01:56.708 Status/error code: 4, Message: 1808, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:56.708 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:56.708 Cannot get real path for '.'.
* 2007-10-10 11:01:56.708 General failure (server should provide error description).
* 2007-10-10 11:01:56.708 Error code: 4
* 2007-10-10 11:01:56.708 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:56.708 Request code: 16
. 2007-10-10 11:01:57.880 Getting current directory name.
. 2007-10-10 11:01:57.880 Getting real path for '.'
> 2007-10-10 11:01:57.880 Type: SSH_FXP_REALPATH, Size: 10, Number: 2064
< 2007-10-10 11:01:57.880 Type: SSH_FXP_STATUS, Size: 44, Number: 2064
< 2007-10-10 11:01:57.880 Status/error code: 4, Message: 2064, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:57.895 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:57.895 Cannot get real path for '.'.
* 2007-10-10 11:01:57.895 General failure (server should provide error description).
* 2007-10-10 11:01:57.895 Error code: 4
* 2007-10-10 11:01:57.895 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:57.895 Request code: 16
. 2007-10-10 11:01:58.677 Getting current directory name.
. 2007-10-10 11:01:58.677 Getting real path for '.'
> 2007-10-10 11:01:58.677 Type: SSH_FXP_REALPATH, Size: 10, Number: 2320
< 2007-10-10 11:01:58.677 Type: SSH_FXP_STATUS, Size: 44, Number: 2320
< 2007-10-10 11:01:58.677 Status/error code: 4, Message: 2320, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:58.677 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:58.677 Cannot get real path for '.'.
* 2007-10-10 11:01:58.677 General failure (server should provide error description).
* 2007-10-10 11:01:58.677 Error code: 4
* 2007-10-10 11:01:58.677 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:58.677 Request code: 16
. 2007-10-10 11:01:59.161 Getting current directory name.
. 2007-10-10 11:01:59.161 Getting real path for '.'
> 2007-10-10 11:01:59.161 Type: SSH_FXP_REALPATH, Size: 10, Number: 2576
< 2007-10-10 11:01:59.161 Type: SSH_FXP_STATUS, Size: 44, Number: 2576
< 2007-10-10 11:01:59.161 Status/error code: 4, Message: 2576, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:59.161 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:59.161 Cannot get real path for '.'.
* 2007-10-10 11:01:59.161 General failure (server should provide error description).
* 2007-10-10 11:01:59.161 Error code: 4
* 2007-10-10 11:01:59.161 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:59.161 Request code: 16
. 2007-10-10 11:01:59.770 Getting current directory name.
. 2007-10-10 11:01:59.770 Getting real path for '.'
> 2007-10-10 11:01:59.770 Type: SSH_FXP_REALPATH, Size: 10, Number: 2832
< 2007-10-10 11:01:59.770 Type: SSH_FXP_STATUS, Size: 44, Number: 2832
< 2007-10-10 11:01:59.770 Status/error code: 4, Message: 2832, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:01:59.770 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:01:59.770 Cannot get real path for '.'.
* 2007-10-10 11:01:59.770 General failure (server should provide error description).
* 2007-10-10 11:01:59.770 Error code: 4
* 2007-10-10 11:01:59.770 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:01:59.770 Request code: 16
. 2007-10-10 11:02:00.442 Getting current directory name.
. 2007-10-10 11:02:00.442 Getting real path for '.'
> 2007-10-10 11:02:00.442 Type: SSH_FXP_REALPATH, Size: 10, Number: 3088
< 2007-10-10 11:02:00.442 Type: SSH_FXP_STATUS, Size: 44, Number: 3088
< 2007-10-10 11:02:00.442 Status/error code: 4, Message: 3088, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:02:00.442 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:02:00.442 Cannot get real path for '.'.
* 2007-10-10 11:02:00.442 General failure (server should provide error description).
* 2007-10-10 11:02:00.442 Error code: 4
* 2007-10-10 11:02:00.442 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:02:00.442 Request code: 16
. 2007-10-10 11:02:01.145 Getting current directory name.
. 2007-10-10 11:02:01.145 Getting real path for '.'
> 2007-10-10 11:02:01.145 Type: SSH_FXP_REALPATH, Size: 10, Number: 3344
< 2007-10-10 11:02:01.145 Type: SSH_FXP_STATUS, Size: 44, Number: 3344
< 2007-10-10 11:02:01.145 Status/error code: 4, Message: 3344, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:02:01.145 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:02:01.161 Cannot get real path for '.'.
* 2007-10-10 11:02:01.161 General failure (server should provide error description).
* 2007-10-10 11:02:01.161 Error code: 4
* 2007-10-10 11:02:01.161 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:02:01.161 Request code: 16
. 2007-10-10 11:02:01.661 Getting current directory name.
. 2007-10-10 11:02:01.661 Getting real path for '.'
> 2007-10-10 11:02:01.661 Type: SSH_FXP_REALPATH, Size: 10, Number: 3600
< 2007-10-10 11:02:01.661 Type: SSH_FXP_STATUS, Size: 44, Number: 3600
< 2007-10-10 11:02:01.661 Status/error code: 4, Message: 3600, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:02:01.661 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:02:01.661 Cannot get real path for '.'.
* 2007-10-10 11:02:01.661 General failure (server should provide error description).
* 2007-10-10 11:02:01.661 Error code: 4
* 2007-10-10 11:02:01.661 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:02:01.661 Request code: 16
. 2007-10-10 11:02:02.692 Getting current directory name.
. 2007-10-10 11:02:02.692 Getting real path for '.'
> 2007-10-10 11:02:02.692 Type: SSH_FXP_REALPATH, Size: 10, Number: 3856
< 2007-10-10 11:02:02.692 Type: SSH_FXP_STATUS, Size: 44, Number: 3856
< 2007-10-10 11:02:02.692 Status/error code: 4, Message: 3856, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:02:02.692 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:02:02.692 Cannot get real path for '.'.
* 2007-10-10 11:02:02.692 General failure (server should provide error description).
* 2007-10-10 11:02:02.692 Error code: 4
* 2007-10-10 11:02:02.692 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:02:02.692 Request code: 16
. 2007-10-10 11:02:05.895 Getting current directory name.
. 2007-10-10 11:02:05.895 Getting real path for '.'
> 2007-10-10 11:02:05.895 Type: SSH_FXP_REALPATH, Size: 10, Number: 4112
< 2007-10-10 11:02:05.895 Type: SSH_FXP_STATUS, Size: 44, Number: 4112
< 2007-10-10 11:02:05.895 Status/error code: 4, Message: 4112, Server: syserr: No error, file: ., Language: en
* 2007-10-10 11:02:05.895 (ECommand) Error getting name of current remote directory.
* 2007-10-10 11:02:05.895 Cannot get real path for '.'.
* 2007-10-10 11:02:05.895 General failure (server should provide error description).
* 2007-10-10 11:02:05.895 Error code: 4
* 2007-10-10 11:02:05.895 Error message from server (en): syserr: No error, file: .
* 2007-10-10 11:02:05.895 Request code: 16
. 2007-10-10 11:02:06.083 Closing connection.
Keeps saying server "should provide error description" but all that's in the app log:
Event Type:   Information
Event Source:   WRQ Reflection for Secure IT Server
Event Category:   None
Event ID:   0
Date:      10/10/2007
Time:      10:01:48 AM
User:      server\user
Computer:   server
Description:
User user, coming from mymachine.com, authenticated.
Event Source:   WRQ Reflection for Secure IT SFTP Server
Event ID:   0
Date:      10/10/2007
Time:      10:01:48 AM
User:      server\user
Computer:   server
Description:
SFTP-server started by user
Event ID:   0
Date:      10/10/2007
Time:      10:01:50 AM
User:      server\user
Computer:   server
Description:
Opening directory `d:\mwsftp\var\ajp\user\'
Event ID:   0
Date:      10/10/2007
Time:      10:02:00 AM
User:      server\user
Computer:   server
Description:
Local disconnected: Connection closed.
Event ID:   0
Date:      10/10/2007
Time:      10:02:00 AM
User:      server\user
Computer:   server
Description:
connection lost: 'Connection closed.'
Event ID:   0
Date:      10/10/2007
Time:      10:02:00 AM
User:      server\user
Computer:   server
Description:
SFTP-server stopped by user
I have this running on a test system, and all is well. Installed to production system, and things are muckety.
What should I be looking at next?
thanks in advance
Kevin
kmcdermott wrote:
The second half of my original post is all I get on the server in the event logs. Where else should I be looking?
That's strange that the server does not log anything upon returning an error to the client. Isn't it possible to increase logging level on the server? Otherwise you should seek a help with the server vendor.
kmcdermott
I have everything enabled:
Like I said, other clients can connect, just so happens WinSCP is the one I have running and I can't see it right.
I even went as far yesterday to completely remove all security settings in MS, and no difference.
:?: [/img]
Well, most (if not all) other SFTP clients does not follow SFTP specification. They does not ask SFTP server to canonize a path before actually using it. WinSCP does that and that is the operation that fails.
kmcdermott
what's that mean to a rookie like me?
It means that you cannot use WinSCP with the server, unless they fix it.
