Does winscp3 have CRC checking
tkquestion
How does WinSCP3 guarantee that the file being transferred in not corrupted while in flight. Is there integrity checking that is occurring on the fly?
Re: Does winscp3 have CRC checking
SSH protocol have built in integrity checking, hence file cannot be corrupted while transferred.
tkquestion
SFTP checksum bug fix?
I noticed the following bug fix in the history:
Bug fix: Checksum calculation with SFTP protocol was not working at all.
Two questions:
1. When running in batch mode am I use SCP SFTP mode?
2. Was this error present in 3.8.2?
Re: SFTP checksum bug fix?
This is unrelated to your first question. There was a bug in file checksum calculation that can be requested from Properties dialog. This has nothing to do with SSH session integrity checking.
Depends on your settings.
The feature mentioned above was added in 4.0 beta.
Fishbalm
CRC vs SSH
While SSH guarantees that all packages sent are accurate, it does not guarantee that the entire file was sent. That's why you still need CRC.
Piasecki
Warsaw, Poland
Re: CRC vs SSH
How can I set the WINSCP to make it always CRC checking and in case of some error - automaticaly repeat the file transfer? In my case I have to repeat manually many (5 - 10) times to make the transfer error-free.
E.Piasecki
Re: CRC vs SSH
WinSCP does not have such feature.
It's tracked here:
https://winscp.net/tracker/374
As mentioned there, even if this was implemented, majority of servers won't support it anyway.
