Why is WinSCP so slow?
eladts
On a local 100M network I get with WinSCP about 900K/s in SCP and pitiful 70K/s in SFTP. Using any other mothod (OpenSSH SCP, FTP etc) I get rates of about. How come WinSCP is so slow, especially using SFTP? The remote server is OpenSSH on Debian GNU/Linux and the local machine runs WinSCP on Windows XP SP1.
Re: Why is WinSCP so slow?
I'm not sure what does phrase "rates of about" mean in English. Is it "the same" or "above"?
There is no such phrase in English, the sentence is cut. It soluld say "rates of about 10MByte/sec".
Can you try for me PSCP? WinSCP is based on it, so it would help me to detect if problem is on my side or on its side.
GerhardW
Hello Martin!
WinSCP is slow because pscp is slow on sftp2 connections.
https://www.chiark.greenend.org.uk/~sgtatham/putty/wishlist/sftp-slow.html
I had already reported this bug to simon. It seems to be a problem with acknowlegement of the packets.
Ciao,
Gerhard
Um... if you are getting 900k in SCP why are you using SFTP (at 70k)? Hello!?!?!
