Does /synchronize work with changed files ?
Petr Nowak
I write small bat and use it to start script:
"C:\Program Files\WinSCP\WinSCP.exe" /script=script.ftp
Script.ftp:
option batch on
echo on
open pnowak@WEBtest
option transfer binary
synchronize local d:\BackupsWEBtest\ \Zalohy\
close
Script works fine but only first time. Script is not able to synchronize changed files. Does synchronize support changed files synchronizing ?
I have looked unsuccesfully for answer in documentation and forum too.
Thanks in advance for any help ...
Petr Nowak
After several days of work I'm not able to setup script to synchronize changed files from remote to local (local includes older version of synchronized files). If I delete files on local, synchronization works. Otherways it is not able to synchronize and overwrite older files on local. Whats wrong ? Please help.
Petr Nowak
What does it mean "Overwrite confirmations are always off for the synchronize command" ? Does it mean it is impossible to overwrite old file with new version when synchronizing ??? (details of my problem and more notes above...).
No it means thatyou are not asked to confirm the overwrite.
Please read this page carefuly.
