Franz Frese
Germany
the length of the username is limited to 50 characters.
winscp403setupintl.exe
ftp
german
Norton IF
martin ◆
Do you mean limitation of input box on login dialog?
Franz Frese
Germany
yes : Session Edit , User Name
The ftp-server I want to connect is :
frauen-geschichtswerkstatt.homepage.t-online.de
the username is (definition by t-online.de)
frauen-geschichtswerkstatt@frauen-geschichtswerkstatt.homepage.t-online.de
martin ◆
I'll increase the limit in the next release. Meanwhile you should be able to set longer username directly in configuration (registry or ini file).
thank you, ini-file works fine
