icons are all illegiable
tonym
why are my icons all illegiable - im using win98 version 3.0
everything else works fine except my icons
tonym@pronto.com.au
tonym
icons are illegable
all my icons are hazy - i can see them but i can make out what they say or look like - i can even see the images - they are just hazy/fuzzy
any suggestion on how i can fix it - i downloaded the scpversion 3.0 installation - all the icons at the top of the page/screen - all other applications show the icons as they should......
thanks
Re: icons are illegable
So you mean icons on the toolbar? There is one well know bug in Borland products (WinSCP is made using Borland C++Builder) with displaying icons on some types of graphic cards. It this is your problem, I cannot help you. I'm sorry.
