got error when it opens two different file for extern editor
Fix317
I am trying open .xls file external editor (excel) and it opens first file fine but then when I open second file I get following error
"WinSCP was not able to determine application that was started to open the file. WinSCP Cannot watch for changes in the file and thus it will not upload the changed file back
One possible reason for the problem is that the file was opened is some already running application
If you want to use the application to open files from WinSCP, Consider configuring it as an external editor
Note that the file will remain in temporary folder."
Please help
Re: got error when it opens two different file for extern editor
Well the error message gives a solution. You can also press a Help button to get more details...
