Winscp Scripting with variables
Quindel
Would it be possible to have the scripting work with variables? I'd like to define all my directories at the top of the script file so I don't need to have someone scan the script and edit/change the directories manually or do the ftp outside of the script. It would be nice to define them in variables at the top and then pull in the variable names into the cd and lcd commands, etc. Set them using the set command or something.
Thank you.
Re: Winscp Scripting with variables
It is on TODO list. However you should be able to easily generate the script using some scripting language.
