SSH - Key is of wrong type
SSH_User
I try to authenticate with RSA Keys. When I try to use the Key that perfectly runs with putty from the same machine I get these error (WinSCP 3)
Trying public key authentication.
Key is of wrong type (PuTTY SSH2 private key)
Unable to authenticate
I tried ot gererate a new Puuty Key from orig. OpenSSH Key - but hte error still occurs.
What habe I done wrong?
Greetings
User
Re: SSH - Key is of wrong type
Which version of Putty are you using? 0.53b or latest developement snapshot?
Use Puttygen to convert your key to native Putty format.
