Still speed rate problems ??
Cedric
We can find many post on this forum about speed rate problem but some of them a quite old.
I use the 4.02 WinSCP version:
Is there now a solution to this problem ?
Do you know where the problem comes from ?
Would it be solved with the next version ?
Globaly, my question is :
Has this problem been partially solved for the last 3 years ?
Thanks.
Re: Still speed rate problems ??
Definitelly WinSCP is faster than 3 years ago.
