file transfer overwrite confirmation major annoyance
remtheory
Hi there,
Despite changing the preferences to NOT use confirmations every time a file gets overwritten and ALSO choosing to ignore future confirmations, I still get the confirmation when overriding files. Majorly annoying. I have the latest version. What am I missing? Is there somewhere else this is called? I'm sure I must be doing something wrong or this would be reported tons of times!
Rachel
Inverse problem!
I'm not getting the "overwrite" confirmation at all, even when I have ticked it in the Preferences. Tried dragging+dropping a file from my desktop to the remote server window (which was successful) and then repeated the process, expecting a "Do you wish to overwite" dialog.
Version 4.0.3 build 345
Re: Inverse problem!
What protocol are you using? Where exactly do you drop file? Are you dragging single file only?
