No root login on sshd
adrian_vg
Uppsala, Sweden
What do I do if "no root login" is set in the sshd_config (for security reasons) and I need scripted access via WinSCP to the logs in /var/log/httpd on the remote side?
Normal users are usually not allowed to access these log as you may know, on linux systems.
Any ideas on this?
TIA.
adrian_vg
Re: No root login on sshd
Nope. Still can't make it work. I added "adrian_vg ALL=(ALL) NOPASSWD: ALL" to sudoers file on my fedora core 5-install. Still no go.
Shouldn't this be enough.
