'Check file size' in Command-line
Ron2
WinSCP is a great tool with many possibilities. But sometimes i am not able to see the best way to use it.
I work only in command-line-mode, because many tasks have to work without human interaction. Everything works fine now, but i have a last problem/task.
My old ftp-program has the possibilty to check the file size of the transferred files. There is a specific checkbox 'check file size' to activate this mode. I want to use something like this with WinSCP, but i don't know which way is the best.
I only want to get some files (no folders) from a remote directory and i want to check the file size or something like that to be sure that the files are exactly the same. I can use /synchronize in command-mode, but is this the best way to get want i want?
Thanks a lot for your help
Ron
cedric
If I have well understood your problem, i have the same.
I wish you had an aswer to your question !
I need to use winSCP in command-line mode and I woul llike to change"Comparison cirteria" of "Synchronize".
How can I make it in command-line mode ?
Please helpme :roll:
Cedric.
It's on TODO list :-)
